Projectile motion of a cannon ball versus time
In summary: So the solution would be:y=y_0+v_0tsin(45°)-1/2gt^2y=2.5+300sin(45°)+1/2gt^2y=525+300sin(45°)+1/2gt^2y=1175+300sin(45°)+1/2gt^2x=531+300cos(45°)x=1175+100cos(45°)+531In summary, the projectile must be launched at time ##t
Archimedess
23
A cannon is inclined about the horizontal by an angle of 45° and it launches projectiles with initial velocity of ##v_p=300m/s##. A small airplane moves horizontally with a constant velocity of ##-100m/s##(so it is directed to the cannon) at high of ##500m##. If at ##t=0s##, the position of the airplane is ##7000m## away from the cannon, determine:
a) the time of which the projectile must be launch to hit the airplane.
b) what are the coordinates of the impact? at what time?
The result of point a) is wrong, I don't understand why?
starting with b)
From the system:
$$y=y_0+v_0sin(45°)-1/2gt^2$$
$$x=x_0+v_0cos(45°)$$
I found:
$$t=2.5s$$ and $$x=531m$$
so, the total time is $$t=\frac{x_(impact)-x_(airplane)}{v_(airplane)}64.7s$$
point a)
this should be ##64.7s-2.5s=62.2## because ##2.5s## is the time of the projectile to reach the coordinates ##(531m,500m)##.
Thanks for helping..
starting with b)
From the system:
I found:
point a)
this should be ##64.7s-2.5s=62.2## because ##2.5s## is the time of the projectile to reach the coordinates ##(531m,500m)##.Thanks for helping..
Let the cannon be located at (0,0) and the plane start from ##(-L,H) = (-7000,500)## at time ##t=0##. (Here I am supposing that distances and velocities to the right are positive and to the left are negative.) If the cannon fires to the left at time ##t_0##, what are the cannonball coordinates ##(x_c(t), y_c(t))## at a time ##t > t_0?## What are the airplane coordinates ##(x_p(t),y_p(t)## at time ##t > 0?## At the collision point/time you need ##(x_c(t),y_c(t)) = (x_p(t),y_p(t)),## and that gives two equations for the two unknowns ##t## and ##t_0.##
There are two roots for ##t_0## and ##t##; what are their physical meanings?
How would you do the question if the cannon fires to the right, so the cannonball chases a plane that has already past?
starting with b)
From the system:
I found:
point a)
I don't see anything wrong with your solution other than typos. Since this equation ##
## is quadratic, there is another possible solution.
Sorry if the problem was unclear but the planes starts at ##(L,H) = (7000,500)##
Ok, so I guess the solutions were wrong.
I'd exclude ##t_2## since it's about ##40s##..
You were not unclear. I took the plane to be flying from west to east and the cannon pointing west. You are taking the plane flying from east to west and the cannon pointing east. Neither of us is wrong, but whatever convention you use ought to be spelled out explicitly.
I don't see anything wrong with 40.7s. Why would you exclude it?
There are two legitimate solutions. As I asked you in #2, can you explain the physical meanings of the two solutions? To enhance your understanding, try to give plots of the airplane and cannonball orbits in the two cases.
Well, I guess ##t_2## is the time it takes to reach the maximum heigh and come back to ##500m## before it drops into the terrain. Since the total time is about ##42.5s-40s=2.5s##.
Right. So the cannonball can hit the plane while it (the cannonball) is rising, or it can hit the plane while it is falling. That is why I suggested you draw pictures.
Wait, the time for the cannonball to reach a height of 500m (the second time) is 40.7s, right? So what do 42.5s and 2.5s represent in this equation?
If the intersection of the trajectories is at 40.7s, what is the horizontal distance traveled by the cannonball at that point? How does that compare to the initial distance of the airplane from the cannon?
I'm not sure that is true. You haven't investigated all of the solutions, yet. I have found four potential solutions and you have only looked at one of them so far.
Four? If I choose the second option, which is ##40s## the projectile will completely miss the airplane.. what are the other 2 solution?
The ones where the aircraft is flying west and the cannon is pointing west.
In 40.7 seconds the cannonball will have traveled nearly 8500m "down range" - so unless the plane is moving away from the cannon it could never be there, no matter how fast it is flying.
Thanks so much for the help and your time guys btw..
Once the plane flies over the cannon, it would be flying away from it. Before you completely reject this as a possible solution, consider that this kind of "tail chase" is a tactic used in real situations.
Related to Projectile motion of a cannon ball versus time
1. What is projectile motion?
Projectile motion is the motion of an object that is launched into the air and then moves along a curved path under the influence of gravity.
2. How does the motion of a cannon ball change over time?
The motion of a cannon ball changes over time due to the force of gravity, which causes it to accelerate downwards. As the cannon ball moves through the air, it also experiences air resistance, which slows it down and affects its trajectory.
3. What factors affect the projectile motion of a cannon ball?
The factors that affect the projectile motion of a cannon ball include the initial velocity of the ball, the angle at which it is launched, the force of gravity, and air resistance. The mass and shape of the cannon ball can also play a role in its motion.
4. How do you calculate the trajectory of a cannon ball?
The trajectory of a cannon ball can be calculated using the equations of projectile motion, which take into account the initial velocity, angle of launch, and acceleration due to gravity. These equations can be solved using calculus or by using projectile motion calculators.
5. How is the motion of a cannon ball different from a free-falling object?
The motion of a cannon ball is different from a free-falling object in that the cannon ball has an initial horizontal velocity, whereas a free-falling object is only affected by gravity and has no initial velocity. This results in a curved path for the cannon ball, while a free-falling object follows a straight path towards the ground.
