Projectile Motion of a snowball
In summary: I get your point now,the snowball will not hit the ground at t = 0.5 sec,so I have to find the height of the tree.In summary, a child throws a snowball with a horizontal velocity of 18 m/s towards a tree from a distance of 9.0 m and a height above the ground of 1.5 m. After what interval does the snowball hit the tree? The snowball will hit the tree at 1.8 seconds. Determine the snowball's velocity as it strikes the tree. The
nblu
56
Q: A child throws a snowball with a horizontal velocity of 18 m/s directly toward a tree,
a) After what interval does the snowball hit the tree?
b) At what height above the ground will the snowball hit the tree?
c) Determine the snowball's velocity as it strikes the tree.
I have done a) and c) but I cannot do b).
I know that when the snowball hits the tree the velocity will be zero,
so Vf = 0, and it happens at 1.8 so I know that t =1.8 but I have no clue
what to do next. Which equation should I use?
Thanks in advance
Thanks in advance
may be it is a good idea that you show us the work you have done and we can then point out to you when you have gone wrong (if there are actually any mistakes)
by the way did the question tell you the height of the child?
I just typed the question right out of the work book so 1.5m above the ground
is the only height I got in this question :(
a) since i know that d[tex]_{y}[/tex] = 1.5m and a = -9.8m/s[tex]^{2}[/tex]
i substituted into the equation, d[tex]_{y}[/tex] = v[tex]_{iy}[/tex][tex]\Delta[/tex]t + 1/2a[tex]\Delta[/tex]t[tex]^{2}[/tex],
v[tex]_{iy}[/tex], which is the initial vertical velocity, it is zero, so i end up getting 1.8 for t. therefore, the snowball will hit the tree at 1.8 sec
yeah, I realized that after I posted
that's only tell you how long it would take to hit the ground (if the tree is not there)!
for c), i know that v[tex]_{fx}[/tex] = v[tex]_{ix}[/tex] = 18m/s, therefore,
subsitute into v[tex]_{fy}[/tex] = v[tex]_{iy}[/tex] + a x t, since v[tex]_{iy}[/tex] = 0,
and a = -9.8m/s[tex]^{2}[/tex], i get;
v[tex]_{fy}[/tex] = -17.64
v[tex]_{f}[/tex] = (18)[tex]^{2}[/tex] + (-17.64)[tex]^{2}[/tex]
v[tex]_{f}[/tex] = 25m/s
tan[tex]\theta[/tex] = 17.64 / 18
[tex]\theta[/tex] = 44 degrees.
Therefore, the velocity is 25 m/s @ 44 degrees above surface
uh oh then I'm in a big trouble lol
so I have to find how tall the tree is?
do you realize so far you haven't used the info about 9m from tree? :smile:
oh oh, so I've used a different equation and i get a different t value,
d[tex]_{x}[/tex] = v[tex]_{ix}[/tex] t + 1/2 a t[tex]^{2}[/tex]
9.0m = (18m/s)(t) + 1/2(-9.8)(t[tex]^{2}[/tex])
9.0m = t(18m/s - 4.9m/s[tex]^{2}[/tex] t)
t = 0, OR
4.9m/s t = 18m/s
t = 3.6 seconds
would this be a new answer, or did i just do something stupid? lol
by the way, there is NO acceleration/deceleration in the x direction...i don't think...
oh you're right.. my bad,
then I'm really stuck..
if my first answer was only telling "how long it will take for the snowball to hit ground",
how can i find the tree's height and relate this equation to it?
you don't need tree height. all you need is how long it will take to hit tree (x-dir) and then that time will tell you how far it has dropped during that time (y-dir), and eventually you can get velocity in x and y then do a vector sum.
i'm sorry but i have no clue,
i thought my answer to a) was right but since it's wrong
i don't know where to start anymore..
hint: velocity in x direction will not change since there is no acceleration in that direction and then u r given the distance (9m) plus initial velocity in x dir,.. so how do you find the time it takes to reach the tree ?
d[tex]_{x}[/tex] = v[tex]_{x}[/tex] x t
t = 9.0 m / 18 m/s
t = 0.5 s
is this wrong?
sounds good, now check that and see how far it have dropped in that time and hopefully it is still above ground! otherwise there is a contradiction :smile:
Thank You,
So I used this equation to find the height at t = 0.5, [tex]\Delta[/tex]d[tex]^{}_{y}[/tex] = v[tex]^{}_{iy}[/tex][tex]\Delta[/tex]t + 1/2a[tex]\Delta[/tex]t[tex]^{2}[/tex]
since v[tex]^{}_{iy}[/tex] = 0,
[tex]\Delta[/tex]d[tex]^{}_{y}[/tex] = 1/2(-9.8m/s[tex]^{2}[/tex])(0.5)[tex]^{2}[/tex]
[tex]\Delta[/tex]d[tex]^{}_{y}[/tex] = -1.2 m
I get negative answer :(
Did I use a wrong formula?
formula is ok, coordinate system used has been confused (by youself)
in setting a = -9.8m/s^2, you have basically chosen the positive y direction to be upwards.
so your displacement of -1.2m is of course meaning 1.2m downwards from starting point.
now, you should be able to finish the entire problem without any more of my help.
cheers
cheers
oooh so since the kid is located 1.5m up, it would be 1.5 -1.2 = 30cm
and that's the height the tree was hit with the snowball.
i get it now!
thanks for the looong two days of help :)
Is this correct?
FAQ: Projectile Motion of a snowball
1. What is projectile motion?
Projectile motion refers to the motion of an object that is launched into the air and moves along a curved path due to the force of gravity.
2. How does the mass of a snowball affect its projectile motion?
The mass of a snowball does not affect its projectile motion. The force of gravity acts on all objects equally, regardless of their mass. This means that a snowball of any mass will follow the same curved path when thrown.
3. What factors can affect the distance a snowball travels?
The distance a snowball travels is affected by the initial velocity, angle of launch, air resistance, and the force of gravity. These factors can change the trajectory and speed of the snowball, resulting in different distances traveled.
4. Can a snowball's trajectory be predicted accurately?
Yes, the trajectory of a snowball can be predicted accurately using mathematical equations and considering the factors that affect it. However, external factors such as wind or uneven terrain may affect the trajectory in real-life scenarios.
5. Is the motion of a snowball considered a projectile only when thrown in a horizontal direction?
No, a snowball's motion is considered a projectile regardless of the direction it is thrown in. As long as the snowball is launched into the air and moves along a curved path due to gravity, it is considered a projectile.
