Projectile motion of arrow shot parallel to ground
In summary, the question asks how fast an arrow was shot from a bow in an archery tournament, given that the arrow traveled 58.0 meters and made a 3.00° angle with the ground. Using kinematic equations and assuming no initial vertical velocity, we can find the initial horizontal velocity to be approximately 73.68 m/s. However, this is not the correct answer because the arrow follows a parabolic path, meaning it has a vertical component of velocity. To solve for the correct initial velocity, we need to calculate the parabolic path that intersects with the ground at the given angle and distance. This requires considering the final velocity triangle
cmkluza
118
You are watching an archery tournament when you start wondering how fast an arrow is shot from the bow. Remembering your physics, you ask one of the archers to shoot an arrow parallel to the ground. You find the arrow stuck in the ground 58.0 m away, making a 3.00° angle with the ground. How fast was the arrow shot?
Kinematic equations are useful, I think.
##d = v_it + \frac{1}{2}at^2##
As I wrote this out I realized a huge flaw in my logic - I assumed there to be no initial vertical velocity because the arrow was shot parallel, but then assumed the path the arrow took was a triangle right from the start (which would imply it's being shot at an angle, not parallel to the ground). Thus, my work below is definitely incorrect, but it's all I've got so far so I'll leave it. Where can I start with the given information?
I started by forming a triangle (angles 90, 87, and 3 degrees). Using the sine rule, I found the vertical height the arrow was shot from:
##\frac{h}{\sin(3)} = \frac{58}{\sin(87)} \longrightarrow h = \frac{58\sin(3)}{\sin(87)} \approx 3.04##m
It stated the arrow was shot parallel to the ground, so I assume an initial vertical velocity of zero. I then use acceleration of gravity (9.81) to try to solve for total time the arrow is in the air:
##d = v_it + \frac{1}{2}at^2 \longrightarrow 3.04 = \frac{1}{2}(9.81)t^2 \longrightarrow t^2 = \frac{2 \times 3.04}{9.81} \approx 0.62 \longrightarrow t = \sqrt{0.62} \approx 0.79##
With this, I assume I can solve for initial horizontal velocity, which (as it was shot parallel to the ground) should be the entire initial velocity, and there should be no horizontal acceleration:
##d = v_it + \frac{1}{2}at^2 \longrightarrow 58 = v_i(0.79) \longrightarrow v_i = \frac{58}{0.79} \approx 73.68##.
However, this is not the answer. Any hints on what I'm doing wrong?
The arrow follows a parabolic path. Were you given the initial height off the ground?
That makes sense, but I didn't know if I was supposed to make some assumptions, since I didn't know what I could do with the given information.
I copied and pasted all the information that problem statement had, so all the information we're given is initial shot is parallel to the ground, travels 58 m, and the arrow makes a 3 degree angle with ground.
Well that's a bit harder, but still workable, I think. You need to calculate the parabolic path that intersects with the ground at that angle that far away.
I'll be honest, I have no idea where to start in order to calculate that, I've never had to work with parabolas in that way before.
The triangle method would work if the arrow traveled in a straight line. Your assumption that the arrow was initially shot in the horizontal direction is correct. By the time the arrow hits the ground it has acquired a vertical component as well. The right triangle you should be thinking about is a final velocity triangle. That's the one that has the 3o angle as part of it.
What derivative would you take to get the angle of the parabola with the ground at any point x away from the peak (the archer is at the origin)... :smile:
This question is all about employing some of the details of projectile motion and how they're related. It's a bit tricky to recognize where to start, but if you consider the scant given information clearly the impact angle with the ground is important. What do you know about the impact angle (besides its value that is)?
kuruman's hint is better -- you probably don't need to use a derivative to answer this question. :smile:
I'm still not sure what I'm doing wrong. I managed to work out the following, but it's still incorrect:
In the horizontal direction:
##a=0##
##v_{ix}=v_{fx}=v_f\sin(3)##
##d=58##
I plugged these into the following equation:
##d=v_it+\frac{1}{2}at^2 \longrightarrow 58=v_f\sin(3)t \longrightarrow v_f=\frac{58}{\sin(3)t}##
In the vertical direction:
##a=9.81##
##v_{iy}=0##
##v_{fy}=v_f\cos(3)##
I used the above value for ##v_f## in the following equation to find ##t##:
##v_{fy}=v_{iy}+at \longrightarrow v_f\cos(3)=at \longrightarrow (\frac{58}{\sin(3)t})\cos(3)=9.81t \longrightarrow \frac{58\cos(3)}{9.81\sin(3)}=t^2 \longrightarrow t \approx 10.6##
With a value for time, and since I don't need to worry about a vertical initial velocity, I can just use values from the horizontal direction with this time to get an initial velocity:
##d=v_{ix}t+\frac{1}{2}at^2 \longrightarrow 58 = v_{ix}(10.6) \longrightarrow v_{ix}=v_i \approx 5.46##.
And yet this is still incorrect. What am I doing wrong now? Have I mixed up some vertical and horizontal values where I shouldn't have?
cmkluza said:
vix=vfx=vfsin(3)vix=vfx=vfsin⁡(3)v_{ix}=v_{fx}=v_f\sin(3)
That looks wrong. The sin() function is almost zero for small angles, but the arrow's horizontal velocity should stay unchanged through the light.
Use kuruman's hint, and draw the right triangle for the final vertical and horizontal velocities as the arrow strikes the ground. Then write the equation for the vertical velocity as a function of time. Then can you see how you can solve this? :smile:
Likes cmkluza
Just about what I was going to say. Remember, in this problem, the horizontal component of the velocity is the initial speed and stays constant until the arrow hits the ground.
Likes cmkluza
Alright, I'm terrible at getting sines and cosines correct. I had drawn it out and originally used cosine for horizontal movement and sine for vertical, but one of my results was off, and for some reason I thought I needed to switch these. I understand now.
Not sure how I mixed it up, but I understand what you're saying now. Essentially, I can go back to my equation solving for time in my previous post and properly substitute in sines and cosines to get the following:
##t = \sqrt{\frac{58\sin(3)}{9.81\cos(3)}} \approx 0.56##
Then I can substitute the proper value of time to get the proper value for initial velocity:
##58 = v_i(0.56) \longrightarrow v_i = \frac{58}{0.56} \approx 104.2##
Thanks for all the help!
Hmm, I get a different answer. Do you know if your answer is correct? Can you show your steps again to get to that equation?
See next post...
Nevermind, I found my error. I believe your solution is correct. :smile:
Likes cmkluza
Related to Projectile motion of arrow shot parallel to ground
What is projectile motion?
Projectile motion is the motion of an object through the air under the influence of gravity. It is a combination of horizontal and vertical motion.
How does the angle of release affect the distance traveled by an arrow?
The angle of release affects the distance traveled by an arrow because it determines the initial vertical and horizontal velocities of the arrow. A higher angle of release will result in a longer distance traveled.
Why does the arrow eventually fall to the ground instead of continuing in a straight line?
The arrow eventually falls to the ground due to the force of gravity acting on it. As the arrow travels through the air, it experiences a downward acceleration due to gravity, causing it to follow a curved path until it reaches the ground.
How does air resistance affect the trajectory of the arrow?
Air resistance can affect the trajectory of the arrow by slowing it down and causing it to lose its horizontal velocity. This can result in a shorter distance traveled and a steeper trajectory.
What factors can impact the accuracy of predicting the projectile motion of an arrow?
Some factors that can impact the accuracy of predicting projectile motion include air resistance, wind, and the release angle and velocity of the arrow. Additionally, the shape and weight distribution of the arrow can also affect its trajectory.
