Projectile motion, potential and kinetic energy
In summary: At the point of interest, PEy=KEy=½KEi=¼mu2.So what is the height of that in terms of u and...In summary, the homework statement states that you need to think about the relationship between kinetic and potential energy. You will need to consider the KE at different heights and what will happen to the KE when the horizontal velocity is the same.
Suyash Singh
168
https://www.physicsforums.com/attachments/upload_2018-4-29_12-40-30-png.224871/
1/2mv^2=10
1/2m(ucos60)^2=10
1/2mu^2/4=10
mu^2=80
what to do now?
This is not an easy problem. You'll need to think about the relationship between kinetic and potential energy.
Hint: the 10J is irrelevant. You can forget about that.
Suyash Singh said:
https://www.physicsforums.com/attachments/224871
1/2mv^2=10
1/2m(ucos60)^2=10
1/2mu^2/4=10
mu^2=80
what to do now?
So what was the initial KE? What will it be at height y?
I see this is a duplicate of https://www.physicsforums.com/threads/projectile-motion.946149/
Likes Suyash Singh
someone removed my attachment
Ke + pe = total energy
Ke remains same?
because horizontal velocity is same
I am not sure:(
But max height=u^2sin^2(theta)/2g
In your post 1 you found
Suyash Singh said:
mu^2=80
Yes, so how much KE will be lost in rising height y? And what will the KE be then?
KE(at y)=KE-mgy
KE lost is mgy
KE-mgy=mgy
KE=2mgy
1/2mv^2=2mgy
1/2v^2=2gy
y=(1/4) (v^2/g)
Suyash Singh said:
KE-mgy=mgy
KE=2mgy
1/2mv^2=2mgy
Your lack of detail has confused you. What exactly is that KE in the first two lines? The KE when?
Likes PeroK
the loss in ke is the gain in pe
That is not what I asked.
You obtained an equation KE=2mgy, where y is the height you are trying to find. But what KE is that? The KE at what point in the process? Check back through your working to make sure.
it is the KE at height y
No.
In posts 8 and 9 you wrote:
Suyash Singh said:
KE(at y)=KE-mgy
KE lost is mgy
Suyash Singh said:
KE-mgy=mgy
KE=2mgy
Rewrite those statements in a way that makes it clear what KE each of those KE terms refers to. E.g. KE(x) for the KE at height x.
Likes Suyash Singh
haruspex said:
No.
oh sorry i made silly mistake
KE(y)=KE-mgy
when,
KE(y)=PE(y)
=mgy
KE=2mgy
so initial kinetic enregy is 2 times of potential energy at height y (y is the height where KE(y)=PE(y))
but how come kinetic energy decreases if horizontal velocity is same
Because this is total KE, made up of horizontal and vertical contributions.
KE at height y
KE(y)=mgy
PE(y)=mgy
Suyash Singh said:
KE at height y
KE(y)=mgy
PE(y)=mgy
Yes, but you already have
Suyash Singh said:
mu^2=80
(So the initial KE is?)
And
Suyash Singh said:
KE=2mgy
Likes Suyash Singh
And
1/2mu^2=40
2mgy=40
y=20/mg
y=2/m
Suyash Singh said:
1/2mu^2=40
2mgy=40
y=20/mg
y=2/m
It is almost always a bad idea to plug in numbers before the final step. Keep everything symbolic as long as you can. I wish now that I had got you to make that switch first.
The useful part of what you have so far is that y=E/4g, where E is the initial KE.
Your original calculation of that KE was wrong anyway. You had ½m(u cos 60)2=Efinal. What is cos260?
1/4
But he said that 10 joules is useless
1/2m(u^2 1/4)=10
mu^2=80
Quite so, which is a good reason for not plugging that value into equations. You can keep it as a variable name, but it will cancel out later.
Let's start over...
If the launch speed is u and the mass m, the initial KE, KEi=½mu2.
As you say, the KE at the top, KEf, is 1/4 of that, so mu2/8.
So, what is the PE at the top, PEf?
So what is the height at the top in terms of u and g?
So what is the height of that in terms of u and g?
Likes Suyash Singh
Let's start over...
Ok
KEi=1/2 mu^2
KEf=1/8 mu^2
PEi=0
PEf=mg(h)
h is the max height
mg(h)=1/2 mu^2 - 1/8mu^2
mgh=3mu^2/8
gh=3/8 u^2
h=(3u^2)/(8g)
mgy=1/2 mv^2 = 1/4mu^2
mgy=1/4mu^2
gy=1/4 u^2
y=u^2/4g
y/h=u^2/4g x 8g/3u^2
y=2h/3
Omg this question was so hard!
It was not easy, but perhaps you have learned the benefits of:
  • Keeping everything symbolic
  • Using a distinct symbol for each variable
  • Clearly defining the variables
Likes Suyash Singh
FAQ: Projectile motion, potential and kinetic energy
What is projectile motion?
Projectile motion refers to the motion of an object that is launched into the air and then moves under the influence of gravity alone. This type of motion follows a curved path known as a parabola.
How is potential energy related to projectile motion?
Potential energy is the energy an object possesses due to its position or configuration. In projectile motion, potential energy is highest at the highest point of the object's trajectory and decreases as the object moves closer to the ground.
What is kinetic energy in relation to projectile motion?
Kinetic energy is the energy an object possesses due to its motion. In projectile motion, kinetic energy is highest at the lowest point of the object's trajectory and decreases as the object moves higher in the air.
How is projectile motion affected by air resistance?
Air resistance can affect the trajectory of a projectile by slowing it down and altering its path. This is because air resistance acts in the opposite direction of motion, causing a decrease in the object's velocity and a change in its direction.
Is there a way to calculate the maximum height and distance a projectile can reach?
Yes, the maximum height and distance of a projectile can be calculated using equations that take into account the initial velocity, angle of launch, and acceleration due to gravity. These equations can vary depending on the specific scenario and the presence of air resistance.
