Projectile Motion - Time in Air
In summary, the problem involves finding the appropriate launch angle for an arrow to hit a target 150m away, with a speed of 60 m/s and at the same height as the bow. Using the equations t = 2vsinθ/g, t = √2y/g, and Δy = (vsinθ)^2/2g, we can calculate the time the arrow spends in the air. After several attempts, it is determined that the correct launch angle is 30 degrees and the arrow will spend approximately 0.86 seconds in the air.
air-in
What angles should an arrow be launched if it leaves the bow @ speed of 60 m/s and is trying to hit a target that is 150 m away? Assume target is same height as bow.
Suppose the arrow is fired at an angle of 30 degrees & misses the target & hits the ground 1.8 m below from where it started. How much time was it in the air?
1. t = 2vsinθ/g
2. t = √2y/g
3. Δy = (vsinθ)^2/2g
I have attempted this the bold section of this problem a few different ways, but I am not convinced that any of them are correct. Could someone please tell me if any of them are correct, and if not, explain to me how to do it.
Attempt 1: t = 2(60)sin30/9.8
t = 6.1s
Attempt 2: t = √2(1.8)/9.8
t = .61s
Attempt 3: 1.8 = (vsin30)^2/2(9.8)
v = 8.4 m/s
t = 2(8.4)sin30/9.8
t = .86s
Have you remembered to take into account the fact that the arrow lands 1.8m below it's original launch height?
Wouldn't that be Δy, which I tried using in attempts 2 and 3?
Now that you have edited your solution I believe that you are correct..
Attempt 4: 1.8 = (60sinθ)^2/2(9.8)
θ = 23.7 degrees
t = 2(60)sin23.7/9.8
t = 4.2s
To hit a target 150 m away with a speed of 60 m/s, the arrow should be launched at an angle of approximately 45 degrees. This is because at this angle, the horizontal distance traveled by the arrow will be equal to the distance to the target. However, this does not take into account air resistance and other factors that may affect the trajectory of the arrow.
For the second part of the problem, the arrow was fired at an angle of 30 degrees and missed the target, hitting the ground 1.8 m below its starting point. To find the time in air, we can use the equation t = √2y/g, where y is the vertical displacement and g is the acceleration due to gravity. Plugging in the given values, we get t = √2(1.8)/9.8 = 0.61 seconds.
Your first attempt is incorrect because it does not take into account the vertical displacement of the arrow.
Your second attempt is correct, as it uses the correct equation and takes into account the vertical displacement of the arrow.
Your third attempt is incorrect because it assumes that the arrow is launched at an initial velocity of 60 m/s, which is not the case. The arrow is launched at a speed of 60 m/s, but at an angle of 30 degrees, the initial velocity in the horizontal direction is only 30 m/s.
Your fourth attempt is incorrect because it uses the wrong angle. The arrow was fired at an angle of 30 degrees, not 23.7 degrees.
Related to Projectile Motion - Time in Air
1. What is projectile motion and how is it different from regular motion?
Projectile motion refers to the motion of an object that is moving through the air, such as a ball being thrown or a bullet being fired. It is different from regular motion because it involves both horizontal and vertical movement, whereas regular motion only involves movement in one direction.
2. How does the time in air affect the trajectory of a projectile?
The time in air is directly related to the horizontal distance traveled by a projectile. The longer the object is in the air, the further it will travel horizontally. This is due to the constant velocity in the horizontal direction, as there is no force acting on the object to change its speed.
3. What factors can affect the time in air of a projectile?
The time in air of a projectile can be affected by the initial velocity, the angle of release, and air resistance. The higher the initial velocity and the smaller the angle of release, the longer the time in air will be. Air resistance can also decrease the time in air by slowing down the object's velocity.
4. How do you calculate the time in air of a projectile?
The time in air can be calculated using the formula t = 2v*sinθ/g, where t is the time in seconds, v is the initial velocity, θ is the angle of release, and g is the acceleration due to gravity (9.8 m/s²). This formula assumes no air resistance and a flat surface.
5. What is the importance of understanding the time in air of a projectile?
Understanding the time in air of a projectile is important in various fields such as sports, physics, and engineering. It allows for accurate predictions of the trajectory of objects, which can be useful in sports like baseball and football. In physics and engineering, it is crucial for designing and analyzing the movement of projectiles, such as in projectile motion experiments or in the design of rockets and missiles.
