Projectile motion with air friction
In summary, the conversation discusses the use of equations to approximate projectile motion with air resistance. The equations are listed and explained on a website, but the results obtained by the individual are not valid. The conversation also mentions the initial values used for the calculations, including velocity, angle, mass, and diameter, and clarifies that the equations were obtained from a PDF.
I'm trying to understand the motion of projectile motion under the influence of air resistance. A website such as this details the necessary equations available to approximate this model: http://claymore.engineer.gvsu.edu/~michels/index_files/Golf%20Ball%20Paper%20Final%20draft.pdf
However, i am unable to calculate vaild results.
I'm using the constant air friction equation
x(t)=(24τV cosθ)/(C_D Re) e^(-((C_D Re)/24τ)t)+(24τV cosθ)/(C_D Re)
y(t)=〖(V sinθ+24τg/(C_D Re))( -24τ/(C_D Re) e^(-((C_D Re)/24τ)t) )+((V sinθ+24τ/(C_D Re))(24τ/(C_D Re)))-(24τ/(C_D Re))t
Reading on the linked website will provide in detail what these variables equal.
My results are
Velocity:v=2.85ms
Angle 60 degrees
mass: 0.004kg
Diameter: 0.016m
This is all done in the fluid of air
at around 20°C
In what way are these not valid results?
[aside: the link is not valid]
Sorry what I'm meant to say is that my results are my initial values. When i sub these into the equation listed the results i obtain are invalid. Try the link again it should be vaild. If not just type into google search and click the most common url located
106267 said:
...my results are my initial values. When i sub these into the equation listed the results i obtain are invalid.
However I now have the pdf linked to. Thanks.
Thank you for sharing your efforts in understanding projectile motion with air resistance. It is a complex phenomenon and can be challenging to accurately model. The equations you have provided are correct and are commonly used to approximate the motion of a projectile in the presence of air resistance. However, there are a few factors that may be affecting your results.
Firstly, it is important to note that air resistance is dependent on the shape and size of the object, as well as the properties of the fluid it is moving through. The equations you have used assume a spherical object with a diameter of 0.016m. If your object is not a perfect sphere or has a different diameter, this could affect your results.
Additionally, the value of the drag coefficient (C_D) is also dependent on the shape and size of the object. It is possible that the C_D value you have used in your calculations is not accurate for your particular object. It may be helpful to conduct experiments or research to determine a more accurate C_D value for your specific object.
Furthermore, the equations you have used assume a constant air resistance, which may not be the case in reality. Air resistance can vary based on factors such as wind speed and direction, temperature, and altitude. These variations can also affect the accuracy of your results.
Finally, it is important to double-check your calculations and make sure all units are consistent. Any errors in your calculations can greatly affect your results.
Overall, I would suggest further research and experimentation to improve the accuracy of your results. Additionally, seeking guidance from a physics instructor or conducting a peer review of your calculations may also be helpful in identifying any potential errors.
Related to Projectile motion with air friction
1. What is projectile motion with air friction?
Projectile motion with air friction is a form of motion in which a body, such as a thrown object or a falling object, experiences the effects of both gravity and air resistance. This results in a curved path of motion rather than a straight line.
2. How does air friction affect projectile motion?
Air friction, also known as air resistance, is a force that opposes the motion of an object through air. This force increases as the object's speed and surface area increase, causing a decrease in the object's velocity and a change in its path of motion.
3. What factors influence the amount of air friction on a projectile?
The amount of air friction on a projectile is influenced by several factors, including the object's shape, size, and speed, as well as the density and viscosity of the air it is moving through. Additionally, the presence of obstacles or turbulence in the air can also affect the amount of air friction.
4. Can the effects of air friction be ignored in projectile motion calculations?
In most cases, the effects of air friction cannot be ignored in projectile motion calculations. This is because air friction can significantly alter the path and velocity of a projectile, especially at high speeds. However, in certain situations where air resistance is minimal, such as with small and slow-moving objects, it may be possible to neglect the effects of air friction.
5. What are some real-life examples of projectile motion with air friction?
Some common examples of projectile motion with air friction include throwing a ball, shooting a basketball, and launching a rocket. Other real-life examples can be seen in sports, such as golfing, skiing, and archery, where air friction plays a significant role in the trajectory of the object.
