Projectile motion with air resistance
In summary, the homework statement is that Newton's second law applies to projectile motion, the mass is m, the drag is F_r = - alpha *v, where alpha is a positive retarding coefficient. The origin is the ground and at time t = 0 the horizontal and vertical velocities are positive. a) Write down Newton's second law for the horizontal component of the velocity, v_x (t). Solve for v_x (t) with given initial conditions and use the characteristic time, tau = m/alpha in your answer. Give physical reasoning as to why m increases with tau and why alpha decreases with tau. b) Integrate v_x (t) from a to determine
ma18
93
This is a standard projectile motion problem, the mass is m, the drag is F_r = - alpha *v, where alpha is a positive retarding coefficient. The origin is the ground and at time t = 0 the horizontal and vertical velocities are positive
b) Integrate v_x (t) from a to determine x(t) with given initial conditions. What is x(t) with the limit t goes to infinity? What would be the horizontal position at t = tau?
c) Convert the DE from a into an equation for v_x (x). Solve for v_x (x) with the given initial conditions and use tau in your answer.
F = ma
a)
F_x = m*v'_x = - alpha*v_x
v'_x/v_x = d/dt *ln(v_x) = - alpha * v_x
ln v_x = - alpha/m t + ln v_x0
v_x (t) = v_x0 * e^(-t/tau)
b) I am stuck here, I integrate to get
integral v_x (t) = x(t) = v_x0 *e^(1-t/tau) / (1-t/tau) * A (where A is an arbitrary constant of integration)
But solving for A with the condition that x(t=0) = 0 I get A = 0
c) I am stuck here too,
m dv_x/dx * dx/dt = - alpha * v(t)
I don't know how the convert the second v(t) into a v(x)
Any help would be much appreciated.
Hello, I'm a little confused. The relation $$dx/dt = v_x = v_{x0} e^{(-t/\tau)}$$ is confirmed. After integral, I got $$x = -\tau v_{x0} e^{(-t/\tau)} + c$$ while c is a constant. Then I can get ##c=\tau v_{x0}##. Does it work?
tommyxu3 said:
Hello, I'm a little confused. The relation $$dx/dt = v_x = v_{x0} e^{(-t/\tau)}$$ is confirmed. After integral, I got $$x = -\tau v_{x0} e^{(-t/\tau)} + c$$ while c is a constant. Then I can get ##c=-\tau v_{x0}##. Does it work?
Oh, I see I did the integral wrong, thanks.
But when I put it in for x(t=0) = 0 I get:
0 = - tau *v_x0 * e^(0) + c
c = tau *v_x0
Not c=0, but that is fine.
Can you help me with c)?
Thanks a lot!
I typed ##c=0## at first and found it wrong just later and I thought you hadn't seen it yet...
OK, I have corrected it and it should be what you said! :)
$$x =\tau v_{x0}(1-e^{\frac{-t}{\tau}})$$
For the convert, based on what we have known: $$x =\tau v_{x0}(1-e^{\frac{-t}{\tau}}),v_x=v_{x0}e^{\frac{-t}{\tau}} ,$$we can get ##e^{\frac{-t}{\tau}}## in ##x## and let it into ##v_{x}## so we get $$v_x=v_{x0} (1-\frac{x}{\tau v_{x0}}).$$
Does this what the problem require? ##(v_{x0}(x))##
I think it expects you arrive at the answer a different way but that is still correct.
There is also other parts to this question
d) Write down the DE for the vertical portion and solve for v_y with the given initial conditions
I got this to be v_y = (v_y0 - g*tau) e^(-t/tau) + g*tau and this is correct.
e) Determine t_a, the time at which the projectile reaches max height. As alpha --> 0, tau --> infinity. Use ln(1+x) = x - x^2/2+... for x<1 to determine lim (tau --> infinity) t_a
For this I set v_y = 0 as it would be at the max time, then rearranged and solved for t:(v_y0 - g*tau) e^(-t/tau) + g*tau = 0
e^(-t/tau) = -g*tau/(v_y0 - g*tau)
t = t_a = -tau ln (-g*tau/(v_y0 - g*tau))
Taking the limit as tau ---> infinity
Using L.H's rule the term inside the ln goes to 1, and thus ln(1) goes to 0 but the tau goes to infinity, so t_a goes to 0. However, I know I messed this up somewhere, can you see my mistake?
f) Determine y(t) by integrating v_y(t). Use the fact that e^x = 1 + x + x^2/2+... to determine lim t-< infinity y(t)
So for the integration I got:
y(t) = tau e^(-t/tau) (g*tau-v_y0)+g*t*tau
Using the property of e^x
tau * e ^ (t/tau) = tau (1 - t/tau + t^2/tau^2) = tau - t + t^2/tau
The last term goes to zero as tau goes to infinity.
So we get
y(t) = (tau - t) (g*tau-v)+gt*tau
= g*tau^2
which goes to infinity.
This is wrong as well but again I am not sure where my mistake is.
Any help would be much appreciated again, thanks a lot!
For (d) I got a little difference from yours... mine is $$v_y=(v_{y0}+g\tau)e^{(\frac{-t}{\tau})}-g\tau,$$ but this time I cannot find my wrong turn while yours is correct...
Let me regard yours is correct, and then we get $$v_y=(v_{y0}-g\tau)e^{(\frac{-t}{\tau})}+g\tau.$$Solve t and get $$t_a=-\tau \ln{\frac{g\tau}{-v_{y0}+g\tau}}.$$When ##\tau\rightarrow\infty##, $$t_a=-\ln{(1-\frac{g}{v_{y0}}\tau)^\tau}$$ $$\rightarrow-\ln{e^{\frac{-g}{v_{y0}}}}=\frac{g}{v_{y0}}.$$
So, it may be ##\frac{g}{v_{y0}}.##
After I post it, I find it containing lots of errors... Maybe just regard it as reference and let me check again!
I got it!
When ##\tau\rightarrow\infty##, $$t_a=\ln{(1-\frac{v_{y0}}{g\tau})^\tau}$$ $$\rightarrow\ln{e^{\frac{v_{y0}}{g}}}=\frac{v_{y0}}{g}.$$
So, it may be ##\frac{v_{y0}}{g}.##
#7 is apparently absurd. Please ignore it! :p
For your ##y(t)##, I'm not sure if you neglected the constant of integral. I got ##y=\tau(v_{y0}-g\tau)(1-e^{\frac{-t}{\tau}})## for ##y_0=0.## Then I can get $$y\approx\tau(v_{y0}-g\tau)(\frac{t}{\tau})+gt\tau=v_{y0}t.$$
There's nothing to do. The only difference between v(t) and v(x) is which variable you write the velocity in terms of. Either way, it's the velocity. It's probably just a typo, but it should be ##v_x(t)##, not ##v(t)##, on the righthand side.
How did you arrive at that value for y?
So we have
v_y = (v_y0 - g *tau) e^(-t/tau)+g*tau
Integrating we get
y = - tau * v_y0 * e^(t/tau) + g*tau^2*e^(-t/tau)+gt*tau + C
= tau * e^(-t/tau) (g*tau-v_y0) + gt*tau + C
taking y(t=0) = 0
0 = tau (g*tau-v_y0) + C
C = tau (v_y0 - g*tau)
y = tau*e^(-t/tau) ( g tau - v_y0) + gt tau + tau*v_y0 - g*tau^2
Yes, I got y for the same way as yours.
Is the relation I wrote what the problem require?
Related to Projectile motion with air resistance
1. What is projectile motion with air resistance?
Projectile motion with air resistance is the study of how an object moves through the air when it is thrown or propelled. It takes into account the effects of air resistance, which is the force that opposes the motion of the object.
2. How does air resistance affect projectile motion?
Air resistance affects projectile motion by creating an opposing force that acts in the opposite direction of the object's motion. This force increases as the object's speed increases, and it can cause the object to slow down and deviate from its intended path.
3. How is air resistance calculated in projectile motion?
Air resistance is typically calculated using the drag force equation, which takes into account the object's velocity, cross-sectional area, and the air density. This equation can be modified for different shapes and sizes of objects.
4. What factors can affect the trajectory of a projectile with air resistance?
Several factors can affect the trajectory of a projectile with air resistance, including the object's initial velocity, mass, surface area, and shape. Other external factors such as wind, temperature, and air density can also play a role.
5. How is projectile motion with air resistance different from projectile motion without air resistance?
In projectile motion without air resistance, the only force acting on the object is the force of gravity, which causes the object to follow a parabolic path. With air resistance, the opposing force of air resistance causes the object to deviate from this path and experience a decrease in speed.
