Projectile motion with only distance, an angle and a ratio
In summary, A projectile with an initial launch angle of θ=41.86° and a distance to the wall of d=11.06 m strikes the wall with a speed that is a fraction f=0.925 of the initial speed. To find the initial velocity, the equation v=fu can be used, along with the equations v_x=u_x=u*cos(θ) and v_y=u_y-gt=u*sin(θ)-gt. The value of d does not directly factor into these equations, so further information or equations may be needed to solve for the initial velocity.
Julie Yum
launch angle of θ=41.86°. The distance to the wall is d=11.06 m, and it strikes the wall with speed that is a fraction f=0.925 of the initial speed, while it is still gaining height (i.e., it has not the highest point of the trajectory). What is the initial velocity? Express your answer in m/s.
V(initial)=v(final)/0.925
Good morning from CET (+DST). According to this forum's philosophy, your goal should be to learn to solve this kind of problems and to find the answer yourself (with assistance of a more experienced member). Therefore you are expected to show effort to solve the problem, so please let us know what you've achieved so far, what formulas/equations/principles you think you can use and describe with which of the steps of the solution you have problems with. So what are your ideas?
@Julie Yum this looks like quite a difficult problem. It will test your algebra and your mathematical understanding of the equations of projectile motion.
So far I have created a multiple formulas to relate the problem to one variable, but I am not sure if I am doing it correctly. I have included a link to the image with my work so far. Please let me know if I am on the right track, or if I should start totally over.
https://drive.google.com/open?id=1IOu8GFxsn8uUyy96XoYpBVFcTIGmX6Op
Here is a link to what I have so far: https://drive.google.com/open?id=1IOu8GFxsn8uUyy96XoYpBVFcTIGmX6Op
What I have seems very complex, long and hard to describe using a keyboard type format, so I excluded it from the forum. However, I have found a way to show what I have as a link. I would appreciate any feedback if possible.
This problem is not really suited to plugging in all those numbers. For one thing, it's almost impossible to tell whether you are on the right track. It's just a mass of numbers in which the actual physics is buried.
I find ##u, v## easier than ##v_0, v_1##. In any case, you should be looking at an algebraic approach, with ##d, f, \theta, t## as the variables.
The first step is to write down what you are given. I would start with:
##v = fu##, hence ##v^2 = f^2u^2##
##v_x = u_x = u\cos\theta##,
##v_y = u_y - gt = u\sin\theta - gt##
Now, can you continue from there? Where does ##d## come in?
What does u and f represent in the formula?
##u## is the initial speed. ##f## is given in the question you posted.
You can use ##v_0## instead of ##u##, but I find ##u## easier.
Here is a link to my work, as you have advised me, please let me know if this seems like the direction i should head.
https://drive.google.com/open?id=1jzoSRc4l44SapTDsZS1_4LWnbba1O50M
Your calculation for ##t## is not correct. ##d## is a horizontal distance.
Would this seem more like it?
https://drive.google.com/open?id=1TEuQbkn5YkszZbLTtcFelfTiPgDzVWFG
The first equation looks better now:
##v_y = u\sin\theta - \frac{gd}{u\cos\theta}##
Although, as you can see, I would prefer ##gd## to ##108.4986##!
Now, you need another equation in ##v_y##. Remember that ##v^2 = v_x^2 + v_y^2##.
... actually, you are nearly there with that second equation.
Any tips on how to isolate for u?
https://drive.google.com/open?id=18knkzNBXae8VPcX9df6Q52TLjFJ105pB
Yes, a better approach is:
##v_x^2 + v_y^2 = f^2u^2##
##v_y^2 = f^2u^2 - u^2\cos^2\theta##
Which leads to another equation for ##v_y##. You can then equate this with the equation for ##v_y## you already have.
You really should type it out here; most helpers (me included) will not open such files and so will not look at your work. Read the post "Guidelines for students and helpers" for more on this issue.
You do not need to type every single step; you can just type summaries along the way, so you can say things like "using the first two equations we get..." and "solving the above equation we find that ... ", inserting the solution formulas, but. If you use LaTeX, that is all quite easy; see, https://www.physicsforums.com/help/latexhelp/
How would I continue to isolate for u?
I think that's not your latest attempt.
Oh sorry.
This is the link: https://drive.google.com/open?id=1XHJIkiWteVRzxxOrPtf4g50eWOXOFCA8
Julie Yum said:
Oh sorry.
Okay, so you have:
##v_y = u \sqrt{f^2 - \cos^2\theta} = u\sin\theta - \frac{gd}{u\cos\theta}##
Try multiplying thru by ##u## and you are nearly there.
PeroK said:
Okay, so you have:
Does this seem like a logical process?
https://drive.google.com/open?id=1c-cH_MS6Z1DKseQg6SRo2gYQE7W7nebw
And thanks for your help! It really helped me with getting through this question.
You made a mistake there with ##-gd## becoming ##+gd##.
Also, it was a bit simpler
##u \sqrt{f^2 - \cos^2\theta} = u\sin\theta - \frac{gd}{u\cos\theta}##
##u(\sin\theta - \sqrt{f^2 - \cos^2\theta}) = \frac{gd}{u\cos\theta}##
##u^2(\sin\theta - \sqrt{f^2 - \cos^2\theta}) = \frac{gd}{\cos\theta}##
And that's good enough. You have numeric values for everything in that equation except ##u##.
Would I use -9.81 or +9.81 for g?
How was g used in those kinematic equations?
That last equation Is like its one dimensional version: ##\ v = v_0 +at\,,\ ## where a is the acceleration.
So ##\ a=-g\,.\ ## Right?
So, what is acceleration? It's ##\ a=-9.81\,##m/s2.
Looks as though ##\ -g=-9.81\,##m/s2.
Related to Projectile motion with only distance, an angle and a ratio
1. What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity. It is a special type of motion that combines both horizontal and vertical motion.
2. Can projectile motion be described with only distance, an angle, and a ratio?
Yes, projectile motion can be described with only distance, an angle, and a ratio. These three parameters are enough to determine the initial velocity and direction of the object, which can then be used to predict its motion.
3. How is the angle of projection related to the range of a projectile?
The angle of projection is the angle at which the object is launched into the air. The range of a projectile is the maximum horizontal distance it travels before hitting the ground. The range is directly proportional to the sine of the angle of projection, meaning that the greater the angle of projection, the greater the range.
4. What is the relationship between the initial velocity and the angle of projection in projectile motion?
The initial velocity and the angle of projection are directly related in projectile motion. The initial velocity can be broken down into horizontal and vertical components, with the horizontal component being determined by the cosine of the angle of projection and the vertical component determined by the sine of the angle of projection.
5. How does air resistance affect projectile motion?
Air resistance, also known as drag, can have a significant effect on projectile motion. It acts in the opposite direction of the object's motion and can cause the object to slow down and deviate from its predicted path. In most cases, air resistance is negligible, but in some cases, it must be taken into account to accurately describe the motion of a projectile.
