Projectile motion without Vi or time known
In summary: Keep in mind that you want to solve for the time when the package hits the ground.In summary, an airplane is trying to deliver medical supplies by dropping them from the cargo bay during a fly-over mission. The supplies are dropped with no initial velocity relative to the plane and at a height of 100m above the target. To hit the target, the airplane needs to have a speed that can be found using the equations x_f = x_o + v_i t + 1/2at^2 and x = x_0 + v_i cos(15) t. The velocity of the package before hitting the ground can be found using the equations y = y_0 + v_i sin(15) t - 1/
jennknoe
1.An airplane is trying to deliver medical supplies by dropping them from the cargo bay during a fly-over mission (they have no initial velocity RELATIVE to the plane). Due to mountains in the area, when the plane drops the supplies, it is moving at an angle of 15o above horizontal, and it is at a height of 100m above the target.
a) Find the speed of the airplane needs to have in order to hit the target if the horizontal distance to the target is 1km.
b)Find the velocity of the package of medical supplies just before they hit the ground.
Xf = X0 + Vi + 1/2at2
So to be honest, I'm definitely not that good at physics, and this course is really difficult for me. So sorry if I ask a lot of questions and don't help out too much.
I tried first trying to find time it takes the package to get reach the ground. But I wasn't sure how to find this with no initial velocity with the plane. Then I also noticed that I had to find the time taken for it to travel on the 15 degrees down to horizontal, then how long it would take to fall the rest of the 100m. Any help would be great!
Thanks everyone,
Jenny
I assume "dropping" means they impart no velocity to the package relative to the plan. That is, they literally let go of the package and let it fall. That means its initial velocity is exactly the same as the plane's velocity.
From there you can find the next part (hint: there's nothing special about falling back to the drop altitude -- keep going).
First of all your equation is not quite right. It should be
[tex] x_f = x_o + v_i t + \frac{1}{2} a t^2 [/tex]
You just forgot the "t" in the second term on the right side of the equation.
Also notice that there is only acceleration in the y dimension. So your x dimension equation should be
[tex] x = x_0 + v_i cos(15) t [/tex]
and since your y dimension is accelerated, your equation in the y dimension is
[tex] y = y_0 + v_i sin (15) t - \frac{1}{2} g t^2 [/tex]
where g is a positive quantity.
Make sure that you understand where these equations come from, then try using them and see where you get.
FAQ: Projectile motion without Vi or time known
What is Projectile Motion?
Projectile motion is the motion of an object through the air that is subject only to the acceleration of gravity. This type of motion is characterized by a curved path, where the object follows a parabolic trajectory.
How is Projectile Motion Different from Uniform Motion?
Projectile motion is different from uniform motion because it involves both horizontal and vertical motion, while uniform motion only involves motion in one direction. Additionally, in projectile motion, the acceleration is not constant as it is affected by the force of gravity.
What Are the Factors that Affect Projectile Motion?
The factors that affect projectile motion include the initial velocity, the angle of projection, the mass of the object, and the force of gravity. These variables can all impact the trajectory and distance traveled by the object.
Can Projectile Motion be Described by Equations?
Yes, projectile motion can be described by a set of equations that take into account the initial velocity, angle of projection, time, and acceleration due to gravity. These equations, such as the projectile motion equation and the kinematic equations, can be used to calculate various aspects of the motion.
How is Projectile Motion Used in Real Life?
Projectile motion is used in various real-life scenarios, such as in sports like basketball and baseball, where players need to accurately project the trajectory of an object to score. It is also used in military operations, such as launching missiles, and in engineering, such as designing roller coasters and other amusement park rides.
