Projectiles, 2D Motion, Bullet falling
In summary: Thank you for your time.In summary, the gun was fired from the top of a tall building and the bullet went through a window and hit the wall. The bullet had a constant acceleration and the bullet eventually moved 6.0 m after traveling for some time t. If you were to travel on the freeway at some constant velocity v for some time t, then how far would you travel? How far would you travel if you were going 60mph for 2 hours? 3 hours? 3.1415926535 hours?
copitlory8
86
From the top of a tall building, a gun is fired. The bullet leaves the gun at a speed of 340 m/s, parallel to the ground. As the drawing shows, the bullet puts a hole in a window of another building and hits the wall that faces the window. (y = 0.48 m, and x = 6.0 m.) Using the data in the drawing, determine the distances D and H, which locate the point where the gun was fired. Assume that the bullet does not slow down as it passes through the window.
acceleration: 9.8m/s^2
sin, cos, tan. a^2+b^2=c^2
Vfy2=Viy2+2ady
tan-1(.48/6)=4.57392126 degrees
.48^2+6^2=6.019169378^2 meters
The bullet falls at a constant acceleration (gravity = 9.8m/s^2). Its horizontal velocity is constant, since it does not accelerate due to gravity. A little birdie seems to have told you the horizontal velocity of the bullet (tweet tweet, it's 340 m/s.) How does its horizontal position D relate to the time it has traveled and the velocity in which it is moving (look up "kinematic equations" in your books index, or ask yourself: if I travel v miles per hour for t hours, how far have I traveled?
Now you have to answer the question of how high the bullet was fired from. You can find the time that the bullet traveled from the first question, so all you have to ask is "how does position relate to constant acceleration?" Again, consult "kinematic equations" in the index of your textbook. If your textbook doesn't address these equations, then you are being cheated and you should either PM me or post on this thread, and I will help you further.
You could make life easier by just spelling things out for me since I am dumb and have a 50% in IB Physics
Maybe you have a 50% because you've convinced yourself that you are dumb. We aren't even halfway through the semester here, and hard work proves to be a miracle maker. I start almost every semester with 65% or less on tests in my classes, but I have managed to turn every one of those 60%'s into at least an 80%. I started Calc I with a 57% on my first test, and I finished with an A. I started E&M with a 59%, and Mechanics with a 69%. I finished all these classes with A's. I got a 57% on my first probability exam, then, in a fit of incredible stupidity, I misread the final exam time and got a 0% on my final exam. Somehow I got a C (70-79%) in the class.
The bullet is moving across the ground at a CONSTANT speed of 340 m/s. It eventually moves 6.0 m after traveling for some time t. Now ask yourself this: If you travel on the freeway at some CONSTANT velocity v (let's say 60mph) for some time t (let's say 1 hour), then how far have you traveled? Now how far would you travel if you were going 60mph for 2 hours? 3 hours? 3.1415926535 hours?
Now you have to ask yourself, "what if I was traveling at 60mph, and I eventually went 60 miles? How long did I travel? If I traveled 120 miles at 60mph, how long did I travel? 188.49556 miles? At some known constant speed, how long would I have to travel to go this far?"
Again, look up "kinematic equations in your textbook."Does your textbook address these? (if it does not, I suggest suing the person that made the book.) If you still have questions, please ask me by PM or respond to this thread.
Related to Projectiles, 2D Motion, Bullet falling
1. What is a projectile?
A projectile is any object that is launched, thrown, or dropped and moves through the air under the force of gravity. Examples of projectiles include balls, arrows, and bullets.
2. How is 2D motion related to projectiles?
2D motion refers to motion that occurs in two dimensions, usually represented on a graph with an x-axis and a y-axis. Projectile motion is an example of 2D motion because objects move both horizontally and vertically as they travel through the air.
3. What factors affect the trajectory of a projectile?
The trajectory of a projectile is affected by its initial velocity, angle of launch, and the force of gravity. Air resistance can also play a role in altering the trajectory of a projectile.
4. Why does a bullet fall to the ground?
A bullet falls to the ground due to the force of gravity acting on it. As soon as the bullet is fired from a gun, it begins to fall towards the ground at a rate of 9.8 meters per second squared.
5. How can we calculate the distance a projectile will travel?
The distance a projectile will travel can be calculated using the formula d = v0t + (1/2)at2, where d is the distance, v0 is the initial velocity, t is the time, and a is the acceleration due to gravity. This formula applies to projectiles launched horizontally or at an angle.
