Projectiles launched at an angle.
In summary, the problem is to find the maximum height of a motorcycle jump based on a horizontal distance of 76.5m and an angle of 12 degrees. The equations used to solve this problem are the initial velocity equation, the time equation, and the displacement equation. After solving for the initial velocity, time, and displacement, the maximum height is found to be 60.74m when the motorcycle is traveling at 13.58m/s and it takes 5.758 seconds to reach this height.
Aracon504
In 1991, Doug Danger rode a motorcycle to jump a horizontal distance of 76.5m. Find the maximm height of the jump if his angle with respect to the ground was 12.0?.
Initial Velocity= ?g?x/2(sin ?)(cos ?)
?t= ?x/vi(cos ?)
?y= vi(sin ?)?t+1/2g(?t)^2
vi= ?(9.81m/s/s)(76.5m)/2(sin 12?)(cos 12?)
vi= 43.3 m/s
?t= 76.5m/(43.3m/s)(cos 12?)
?t= 1.8s
?y= (43.3m/s)(sin 12?)(1.8s)+.5(-9.81m/s/s)(1.8s)^2
Not sure if this is right...
I got V = 60.74 m/s and t = 2.575 s. Your answer of 43.3 m/s and 1.8 seconds will produce 76.23 meter horizontal distance.
I used Vcos(12)*t = 76.5 and 0 = Vsin(12) - gt to get t = Vsin(12)/g... so t = 0.0212V, multiplied by 2, t = 0.424V, then, V = 13.58 m/s, t = 5.758 s from here you may use
H = Vcos(12)t - 0.5gt^2
Thanks for the help.
FAQ: Projectiles launched at an angle.
1. What is a projectile launched at an angle?
A projectile launched at an angle refers to an object that is thrown or propelled into the air at an angle, as opposed to being launched straight up or straight down. This angle can be measured relative to the ground or any other reference point.
2. How does the angle of launch affect the trajectory of a projectile?
The angle of launch is a crucial factor in determining the trajectory of a projectile. The steeper the angle, the higher the object will go and the shorter the distance it will travel horizontally. On the other hand, a smaller angle will result in a longer horizontal distance but a lower maximum height.
3. What are the key factors that influence the range of a projectile launched at an angle?
The range of a projectile launched at an angle is primarily affected by three factors: initial velocity, angle of launch, and acceleration due to gravity. These factors work together to determine how far the object will travel before hitting the ground.
4. How does air resistance impact the motion of a projectile launched at an angle?
Air resistance, also known as drag, can have a significant impact on the motion of a projectile launched at an angle. As the object moves through the air, it experiences a force in the opposite direction of its motion, which can alter its trajectory and decrease its range.
5. What are some real-world applications of projectiles launched at an angle?
Projectiles launched at an angle are used in various real-world applications, such as sports (e.g. throwing a football or shooting a basketball), military operations, and space exploration. Understanding the physics behind these projectiles can help in optimizing their trajectory and achieving desired outcomes.
