Projectiles Launched At An Angle
In summary, Wayne Brian threw a spear a distance of 201.24 meters. The initial speed of the spear is 50.5 meters/seconds.
sprtsgy0372
Wayne Brian threw a spear a distance of 201.24 meters. Suppose he threw the spear at a 35.0 degree angle with respect to the horizontal. What was the initial speed of the spear?
Data Known-
Delta X: 201.24 m
Theta (angle): 35.0 degrees
Acceleration (Y): -9.81 meters/seconds/seconds
Equations-
Velocity(Vx)=Vi(Cosine Theta)
Velocity(Vy)=Vi(Sine Theta)
Time= (Delta X)/Vi(Cosine Theta)
Delta Y= (Vi(Sine Theta)*(Time)) + (1/2(Acceleration Y)*(Time^2))
Delta X= Vi(Cosine Theta)*(2*(Vi*Sine Theta)/(Accelartion Y))
How would you solve the problem when all equations require the intial velocity, and there is none given?
Welcome to PF!
You know that (Δx)/(vicosθ) is the time required for the projectile to go up and then come back down again. (If it stayed in the air longer, it would have moved farther horizontally. The time spent in the air, along with the horizontal velocity, determines Δx).
You also know that this time spent in the air (t) is equal to twice the time required for the initial vertical velocity (visinθ) to decrease to zero. In other words, the time spent in the air is twice the time spent reaching the maximum height.
So, now you have two equations, and two unknowns (t and vi). You can therefore solve the problem.
Thanks for your response, but I was told by a friend that I could use this equation...
Delta X= Vi(Cosine Theta)*(2(Vi*Sine Theta)/(Acceleration Y))
He said that I would just simplify this equation and plug in the values that I have given to me. Then he said I would just solve for Vi.
So, it ends up looking like this...
201.24 = ((2Vi^2)*(Cos 35)(Sin 35))/(9.81)
(201.24*9.81)/(Cos 35)(Sin 35) = 2Vi^2
Square Root ((201.24*9.81)/2(Cos 35)(Sin 35)) = Vi
Vi= 50.5 meters/seconds
Does this look right?
Yeah. That's because the part in red is equal to t. In other words, what you have there is what you would have ended up with if you had combined the two equations that I told you to use in my response. Our advice is consistent, the difference is, your friend did half the work for you by using the second equation that I gave you to solve for t in terms of vi, and then plugging that into the first equation I gave you, leading to the result quoted above. Of course, it would have been much better if you had arrived at that result yourself. :wink:
Okay, thanks for you're help though. I just have a little trouble understanding things when I can't visualize them on a board, because I'm definitely a person who has to see things to understand them. So, thanks again.
FAQ: Projectiles Launched At An Angle
1. What is the formula for calculating the range of a projectile launched at an angle?
The formula for calculating the range of a projectile launched at an angle is R = (V²sin2θ)/g, where R is the range, V is the initial velocity, θ is the launch angle, and g is the acceleration due to gravity.
2. How does the launch angle affect the range of a projectile?
The launch angle has a significant impact on the range of a projectile. A launch angle of 45 degrees will result in the maximum range, while angles greater or less than 45 degrees will result in a shorter range.
3. What is the difference between the maximum height and the range of a projectile launched at an angle?
The maximum height of a projectile launched at an angle is the highest point the projectile reaches in its trajectory, while the range is the horizontal distance covered by the projectile. These values are not necessarily the same and are affected by factors such as launch angle and initial velocity.
4. Can a projectile launched at an angle have a negative range?
Yes, a projectile launched at an angle can have a negative range if it is launched at a downward angle. In this case, the range would be measured as a negative value, indicating that the projectile landed behind the point of origin.
5. How does air resistance affect the trajectory of a projectile launched at an angle?
Air resistance can have a significant impact on the trajectory of a projectile launched at an angle. It can cause the projectile to slow down and deviate from its intended path, reducing its range and height. The impact of air resistance is greater for projectiles with larger surface areas and lower initial velocities.
