Projection postulate and the state of a system
In summary: Yes, this means that a Stern-Gerlach magnet does not actually measure the spin on the atom. The only actual measurement is when the atom is detected at the screen and the QM of spin states is inferred from that. Until it hits the screen, the atom remains in a superposition of spin states. So, the spin measurement is not a direct measurement, but an indirect one. This is why the projection postulate is important, as it explains how the superposition of spin states collapses into a definite spin state upon measurement. In summary, the author discusses the projection postulate in quantum mechanics, which states that after a measurement, the quantum system is in a new state that is the normalized projection of the original state onto the corresponding
Kashmir
468
74
Quantum Mechanics, McIntyre states the projection postulate as:
"After a measurement of ##A## that yields the result ##a_n##,the quantum system is in a new state that is the normalized projection of the original system ket onto the ket (or kets) corresponding to the result of the measurement"
"##\left|\psi^\prime\right> = \frac{P_n\left|\psi\right>}{\sqrt{\left<\psi\right|P_n\left|\psi\right>}}.##"
Then we do a Stern Gerlach type experiment as shown in figure below (The X, Z are analyzers that measure the x, z spin of incoming stream of atoms. The up arrow is up spin.
At the right end is the final counter)
The author then says that the state of atoms input to the final Z analyzer is ##\begin{aligned}\left|\psi_{2}\right\rangle &=\frac{\left(P_{+x}+P_{-x}\right)\left|\psi_{1}\right\rangle}{\sqrt{\left\langle\psi_{1}\left|\left(P_{+x}+e_{-x}\right)\right| \psi_{1}\right\rangle}} \\ &=\frac{\left(P_{+x}+P_{-x}\right)|+\rangle}{\sqrt{\left\langle+\left|\left(P_{+x}+P_{-x}\right)\right|+\right\rangle}} . \end{aligned}## because "both states are used, the relevant projection operator is the sum of the two projection operators foreach port, ##P_{+x}+P_{-x}##, where ##P_{+x}=|+\rangle_{x x}\langle+## and ##P_{-x}=|-\rangle_{x x}(-\mid##"I'm not able to understand why should the state input to the final Z analyzer be ##\begin{aligned}\left|\psi_{2}\right\rangle &=\frac{\left(P_{+x}+P_{-x}\right)|+\rangle}{\sqrt{\left\langle+\left|\left(P_{+x}+P_{-x}\right)\right|+\right\rangle}} . \end{aligned}##
How does this follow from the projection postulate?
What do you think it should be? What does your calculation give?
I assume McIntyre has covered the concept of superposition of states.
McIntyre does talk about superposition states earlier. Here it is
"A general spin- ##1 / 2## state vector ##|\psi\rangle## can be expressed as a combination of the basis kets ##|+\rangle## and ##|-\rangle##
##|\psi\rangle=a|+\rangle+b|-\rangle##" So basically a superposition state is not an eigenstate but a linear combination of them.
Okay, so what else could ##|\psi_2 \rangle## be? If it's not as above, what do you calculate it to be?
Some of the atoms will have ##|+\rangle xx##and others will have ##|-\rangle xx## some will be spin up along x-axis and others spin down.
Kashmir said:
Some of the atoms will have ##|+\rangle x##and others will have ##|-\rangle x##
Ah, okay. Yes, this is the heart of QM. As Feynman said, all the mysteries of QM stem from this one point.
Classically, yes, an atom would emerge from the X-system either as ##x+## or as ##x-##. We might not know which, but it would definitely be one or the other.
QM says something very different. QM says that each atom emerges in a superposition of ##|x+ \rangle## and ##|x- \rangle##.
In other words, classical mechanics and QM make different predictions for what would happen when we put the atoms through the second Z-system:
Classical mechanics says that the 50% of atoms that are ##x+## get split 50-50 into ##z+## and ##z-##. And, so do the 50% that are ##x-##. We expect, therefore, a 50-50 split coming out of the second Z-system.
QM says that the spin state that emerges from the X-system is an equal superposition of ##|x+ \rangle## and ##|x- \rangle##. And, in fact, each atom is still effectively in a state of ##|z+\rangle##. So, QM predicts that all the atoms will come out the second Z-system in the up direction.
In truth, this is an idealised experiment, but similar experiments have shown that QM is correct and classical mechanics fails to make the correct predictions.
This is the motivation to study QM and the states-as-complex-amplitudes formalism.
Likes vanhees71 and Kashmir
PS does this mean that a Stern-Gerlach magnet does not actually measure the spin on the atom? Yes! The only actual measurement is when the atom is detected at the screen and the QM of spin states is inferred from that. Until it hits the screen, the atom remains in a superposition.
Likes vanhees71
Thank you,it is really surprising! . But still I'm not able to understand how the projection postulate gives me the superposition state. The author says "So we need only calculate the probability of passage through the third analyzer. The crucial step is determining the input state, for which we use the projection postulate. Since both states are used, the relevant projection operator is the sum of the two projection operators for each port, ##P_{+x}+P_{-x}## where ##P_{+x}=|+\rangle_{x x}\left(+\mid\right.## and ##P_{-x}=|-\rangle_{x x}\langle-|##. Thus the state after the second analyzer is
\begin{aligned}
\left|\psi_{2}\right\rangle &=\frac{\left(P_{+x}+P_{-x}\right)\left|\psi_{1}\right\rangle}{\sqrt{\left\langle\psi_{1}\left|\left(P_{+x}+P_{-x}\right)\right| \psi_{1}\right\rangle}} . \\
\end{aligned}
\begin{aligned}
\end{aligned}
That's just the superposition of states written out in projection notation.
Likes vanhees71
I'm not able to understand :(
FAQ: Projection postulate and the state of a system
What is the Projection Postulate?
The Projection Postulate is a fundamental principle in quantum mechanics that states that the state of a quantum system can be described by a wave function, and the act of measuring a physical quantity of the system will cause the wave function to collapse to one of its eigenstates.
How does the Projection Postulate relate to the state of a system?
The Projection Postulate is used to determine the state of a quantum system after a measurement has been made. It allows us to calculate the probability of obtaining a particular measurement outcome by projecting the wave function onto the corresponding eigenstate.
Can the Projection Postulate be applied to all quantum systems?
Yes, the Projection Postulate is a fundamental principle in quantum mechanics and can be applied to all quantum systems, regardless of their complexity or size.
What is the difference between the state of a system before and after measurement according to the Projection Postulate?
Before measurement, the state of a quantum system is described by a wave function that contains information about all possible outcomes of a measurement. After measurement, the wave function collapses to a single eigenstate, representing the specific outcome that was observed.
How does the Projection Postulate relate to the uncertainty principle?
The Projection Postulate is closely related to the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle with absolute certainty. The Projection Postulate allows us to calculate the probability of obtaining a particular measurement outcome, rather than determining the exact state of the system.
