Projection tensor in from (m+n) dim down on n-dim
In summary, we can construct a projection tensor onto a subspace of a tangent space using the coordinate basis and its metric duals, and this projection tensor satisfies certain properties.
center o bass
560
Suppose that we have an (n+m)-dimensional tangent space ##T_p^{n+m}## which we decompose into the direct sum of two tangent spaces ##T_p^{n+m} = T_p^n \oplus T_p^m##. We have a coordinate basis in some region of the manifold ##\left\{\partial_{\mu}\right\}_{\mu=1}^{n+m}## from which we want to construct an adopted basis ##\left\{e_a, e_k\right\}## such that ##e_a \in T_p^{n}## and ##e_k \in T_p^m## with ##a = 1,2,\ldots , n## and ##k = 1, 2, \ldots m##. Now if ##m=1## one can easily construct a projection operator which projects down on the ##n##-dimensional tangent-space ##T_p^n## by
$$P = \mathbb{1} - \frac{e_{n+1}\otimes e^{n+1}}{g_{(n+1)(n+1)}} $$
where I have defined ##e_k \equiv e_{n+1}## and the metric-dual ##e^k = g(e_k, \ )##, where ##g## is the metric tensor and ##\mathbb{1}## is the identity tensor. As a projection tensor must, we have that ##P## satisfies
$$P P = \mathbb{1} - 2 \frac{e_{n+1}\otimes e^{n+1}}{g_{(n+1)(n+1)}} + \frac{1}{g^2_{(n+1)(n+1)}} e_{n+1} \otimes e^{n+1} e^{n+1}(e_{n+1}) = \mathbb{1} - \frac{e_{n+1}\otimes e^{n+1}}{g_{(n+1)(n+1)}} = P.$$
On the other hand, when ##m > 1## the similar expression
##P = \mathbb{1} - \sum_{k=1}^m\frac{e_{k}\otimes e^{k}}{g_{kk}}##
does not automatically satisfy ##PP = P##, since
$$PP = \mathbb{1} - 2 \sum_{k=1}^m\frac{e_{k}\otimes e^{k}}{g_{kk}} + \sum_k \sum_l \frac{g_{kl}}{g_{kk}g_{ll}}e_k \otimes e^l. $$
So it's only a projection tensor if ##g_{kl} = g_{kk} \delta_{kl}## no, sum. Is there a general formula for the projection tensor down on ##T_p^n## that satisfies the required relations and for which we need not have ##g_{kl} = g_{kk}\delta_{kl}##?
Hello,
Thank you for your interesting question. In general, the projection tensor onto a subspace of a tangent space can be written as
$$P = \sum_{i=1}^n \frac{e_i \otimes e^i}{g_{ii}},$$
where ##e_i## are the basis vectors of the subspace and ##e^i## are the corresponding metric duals. This projection tensor satisfies the properties ##P^2 = P## and ##P(e_i) = e_i##, as required for a projection tensor.
In the case where ##m > 1##, the projection onto the subspace ##T_p^n## would be given by
$$P = \sum_{i=1}^n \frac{e_i \otimes e^i}{g_{ii}} + \sum_{j=n+1}^{n+m} \frac{e_j \otimes e^j}{g_{jj}},$$
where ##e_j## are the basis vectors of the remaining ##m## dimensions. This projection tensor would also satisfy the properties of a projection tensor.
I hope this helps. Let me know if you have any further questions.
Related to Projection tensor in from (m+n) dim down on n-dim
1. What is a projection tensor?
A projection tensor is a mathematical tool used in linear algebra and geometry to project a higher dimensional space onto a lower dimensional space. It essentially maps points from a higher dimensional space onto a subspace.
2. How is a projection tensor represented?
A projection tensor is typically represented by a square matrix with elements that determine the projection onto the subspace. It can also be represented using tensor notation, which is a more compact way of writing linear algebra equations.
3. What is the purpose of a projection tensor?
The purpose of a projection tensor is to transform a higher dimensional space into a lower dimensional space while preserving certain properties, such as orthogonality or distance. This can be useful in various fields, such as computer graphics, physics, and machine learning.
4. How is a projection tensor calculated?
The calculation of a projection tensor depends on the specific problem it is being used for. In general, it involves finding a basis for the subspace onto which the projection will be made, and then using this basis to construct the projection matrix. This can be done using techniques such as Gram-Schmidt orthogonalization or singular value decomposition.
5. Can a projection tensor be used for non-linear projections?
No, a projection tensor can only be used for linear projections. Non-linear projections require more complex mathematical tools, such as tensors with higher order components.
  • Differential Geometry
