Projective geometry question: 4 points no 3 on a line
In summary, in a projective plane, if four points A,B,C,D do not lie on a line, but the lines AB and BC have a common point E, then E must be equal to B. Additionally, this implies that the three lines AB, BC, CD have no common point, and the same is true for any other three of the lines AB, BC, CD, DA. This is shown by demonstrating that if E is not equal to B, then A,B, and C must all lie on the same line, which contradicts the axiom that no three points can lie on a line in a projective plane. This also highlights the importance of not violating this axiom, as it would lead to inconsistencies in the system.
anniecvc
28
a) Suppose that A,B,C,D are four "points" in a projective plane, no three of which are on a "line." Consider the "lines" AB, BC, CD, DA. Show that if AB and BC have a common point E, then E = B.
b) From a) deduce that the three lines AB, BC, CD have no common point , and the same is true of any three of the lines AB, BC, CD, DA.
Axioms of a projective geometry:
1) Any two "points" are contained in a unique "line"
2) Any two "lines" contain a unique "point"
3) There are four different "points," no three of which are in a "line"
I proceeded by contradiction. Assume E is not equal to B.
AB and BC have common point E by assumption so ABE are on a line and BCE are on a line. (I was tempted to say aha! contradiction - 3 points on a line right here, but it's not illegal, only illegal for the 4 points A,B,C,D to have 3 on line.)
The E must connect to D by a line via Axoim 1.
Either ED is along line DCE or DAE.
If along DCE => B,C,D are along the same line
if along DAE => D,A,B are along the same line.
This contradictions that no 3 of the 4 points A,B,C,D are on a line.
Therefore E must be equal to D.
Don't think my argument is sensical.
And, for part b, I'm confused since doesn't Axiom 2 state that any 2 lines must contain a point?
You should follow your first aha! ABE are on a line, and BCE are on a line. Both lines contain B and E. If B and E are different, then they must be the same line by axiom 1), yes? Wouldn't that mean that A,B and C are on the same line? It does say, no three of which are on a "line."
For part b):- show from part a) that the only common point between any 2 of the 4 lines is the common endpoint. Therefore AB and CD have no common point. In fact if you choose any 3 of the four lines you will find that there is one line which does not share any of it's endpoints with one another. you can check this by hand, there are only 4 possibilities.
FOOD FOR THOUGHT:- If this were not so it would violate the fact that not 3 points should be in a straight line in this system. Can you see why?
Cheers.
Ah, got it. Thank you so much!
Related to Projective geometry question: 4 points no 3 on a line
1. What is projective geometry?
Projective geometry is a branch of mathematics that studies the properties of objects and figures that are invariant under projection. It is a more abstract and general form of geometry compared to Euclidean geometry, as it does not rely on the concept of distance or angles.
2. What does it mean to have 4 points with no 3 on a line in projective geometry?
In projective geometry, having 4 points with no 3 on a line means that the points cannot be connected by a straight line. This is because in projective geometry, a line can be thought of as a circle that intersects at infinity, so any 3 points will always lie on a line.
3. What is the significance of having 4 points with no 3 on a line in projective geometry?
Having 4 points with no 3 on a line in projective geometry is significant because it allows for the study of properties that are not dependent on the specific arrangement or position of the points. This concept is crucial in projective geometry as it allows for the exploration of more abstract and general geometric principles.
4. Can 4 points with no 3 on a line exist in the real world?
No, in the context of projective geometry, 4 points with no 3 on a line cannot exist in the real world because it is a theoretical concept that does not depend on physical space or measurements. However, it can be applied to real-world objects and figures to describe their properties in a more abstract and general way.
5. What are some real-world applications of projective geometry?
Projective geometry has various applications in fields such as computer graphics, computer vision, and projective mapping. It is also used in art, architecture, and design to create perspective drawings and paintings. Other applications include projective transformations in photography and projective duality in graph theory.
