Projective measurement and correlations: examples
In summary, projective measurement is a method used in quantum mechanics to obtain information about a quantum system by measuring it in a particular basis. This collapses the system into one of the basis states, with the probability of the outcome determined by the overlap between the initial state and the basis state. One example of projective measurement is the Stern-Gerlach experiment, which measures the spin of silver atoms in an inhomogeneous magnetic field. Unlike other types of measurement, projective measurement collapses the system into one of the basis states. Correlations between quantum systems can be measured by comparing the outcomes of individual measurements. However, projective measurement has limitations such as only being able to measure certain properties and being a destructive process.
kaje
23
Hello,
Can anybody help me to understand the solved example as attached here. How can I follow that using dirac, bra notations.
Regards
  • Scan3.pdf
  • Scan1.pdf
  • Scan.pdf
How to delete my post and question here please?
No need to delete it -- you got good advice, and others may benefit from seeing that good advice too. :smile:
FAQ: Projective measurement and correlations: examples
What is projective measurement and how does it work?
Projective measurement is a method used in quantum mechanics to obtain information about a quantum system. It involves measuring the system in a particular basis, which collapses the system into one of the basis states. The probability of obtaining a particular outcome is determined by the overlap between the initial state and the basis state.
Can you give an example of projective measurement in quantum mechanics?
One example of projective measurement is the Stern-Gerlach experiment, in which a beam of silver atoms is passed through an inhomogeneous magnetic field. The atoms are measured in the z-direction, and the outcome is either spin up or spin down, depending on the orientation of their magnetic moment relative to the field.
What is the difference between projective measurement and other types of measurement in quantum mechanics?
Unlike other types of measurement, projective measurement has the unique property of collapsing the quantum system into one of the basis states. This means that the outcome of the measurement is completely determined by the initial state of the system and the basis chosen for the measurement.
How are correlations between quantum systems measured in projective measurement?
In projective measurement, correlations between quantum systems are measured by performing measurements on each individual system and comparing the outcomes. The degree of correlation can be quantified using mathematical tools such as the correlation coefficient.
Are there any limitations to projective measurement in quantum mechanics?
One limitation of projective measurement is that it can only measure certain properties of a quantum system, such as position or momentum. It cannot simultaneously measure both of these properties with arbitrary precision, due to the uncertainty principle. Additionally, projective measurement is a destructive process, meaning it changes the state of the system and prevents further measurements from being made in the same basis.
