Proof about a real-valued continuous function?
In summary: If p1 is first and f(p0) is greater than or equal to f(p2), then p2 is the intersection point and the value of f(p0) is written as f(p2). If p1 is first and f(p0) is less than f(p2), then p2 is the intersection point and the value of f(p0) is written as f(p1). If p2 is first and f(p0) is greater than or equal to f(p1), then p1 is the intersection point and the value of f(p0) is written as f(p2). If p2 is first and f(p0) is less than f
cookiesyum
78
Proof about a real-valued continuous function??
Five line segments meet at a point. Show that any continuous real-valued function defined on this set must take the same value three times.
Take the values f(0,0,0) f(0,0,1) f(1,0,0) f(0,1,0) f(-1,0,0) f(-1,0,0). If three of the values are the same, the proof is done.
Assume all of the values are different.
At least three of f(0,0,1) f(1,0,0) f(0,1,0) f(-1,0,0) f(0,-1,0) are greater than or less than f(0,0,0).
Without loss of generality, assume f(-1,0,0) < f(0,0,0) < f(0,1,0) < f(0,0,1).
Then, by the Intermediate Value Theorem, there is a point p1 between f(-1,0,0) and f(0,0,1). Then p would be on the line segment from (-1,0,0) to (0,0,1) and also on two other line segments...but which??
Hence, the real-valued function takes the same value three times.
You were given only five line segments. How can you assume these particular points are on the segments? Also are you assuming that one of the points is the point of intersection and the other five are on fived different segments?
How can you do that? If three are not the same, it might still be that two are the same, another two different from the first two but the same, the fifth different from the previous.
You just said "At least three of f(0,0,1) f(1,0,0) f(0,1,0) f(-1,0,0) f(0,-1,0) are greater than or less than f(0,0,0)" which I interpret to mean "at least three above or at least three below". How does it follow that there are two above and one below? Why not all five above?
How do you know that the line segment from (-1,0,0) to (0,0,1) is one of the five given line segments? And unless p is the point of intersection of the five line segments, if p is on one segment, it can't be on any other!
For notation let's just call the intersection point p0, and the other five endpoints p1,p2,p3,p4,p5. It'll save you writing a lot of ones and zeros. And pick the indices so that f(p1)<=f(p2)<=f(p3)<=f(p4)<=f(p5). Now consider all of the cases of where the value of f(p0) lies in the order relationship of the other p's.
FAQ: Proof about a real-valued continuous function?
What is a real-valued continuous function?
A real-valued continuous function is a type of mathematical function that has a domain and range of real numbers. It is considered continuous if its graph is unbroken, meaning there are no gaps or holes in the curve. This means that the function can be drawn without lifting the pen from the paper.
How can I prove that a function is continuous?
To prove that a function is continuous, you must show that it satisfies the three conditions of continuity: existence, uniqueness, and limit. This means that the function must have a defined value at every point in its domain, the value must be the same regardless of how the point is approached, and the limit of the function as the input approaches a certain value must equal the function's value at that point.
What is the importance of continuous functions?
Continuous functions are important in mathematics because they have many practical applications in real-world problems. They allow us to model and analyze real-world phenomena, such as motion and growth, and make predictions based on the behavior of the function. They also provide a foundation for more advanced mathematical concepts such as calculus.
Can a function be continuous at some points and not at others?
Yes, a function can be continuous at some points and not at others. This is known as a piecewise continuous function. It means that the function is continuous on each individual interval, but there may be a break or discontinuity at the point where the intervals meet.
How can I use the intermediate value theorem to prove continuity?
The intermediate value theorem states that if a function is continuous on a closed interval [a, b], and it takes on two values, y1 and y2, at the endpoints a and b, then it must also take on every value between y1 and y2 at some point within the interval. This can be used as a proof of continuity by showing that the function satisfies this condition on a given interval.
