Proof about inner automorphism of a group
So for two inner automorphisms $\gamma_a$ and $\gamma_b$, their composition would be $\gamma_a\circ\gamma_b=\gamma_{ab}$, which is also an inner automorphism.
i_a_n
83
Let $G$ be a group. Let $a ∈ G$. An inner automorphism of $G$ is a
function of the form $\gamma_a : G → G$ given by $\gamma_a(g) = aga^{-1}$.
Let $Inn(G)$ be the set of all inner automorphisms of G.
(a) Prove that $Inn(G)$ forms a group. (starting by identifying an appropriate binary operation.)
(b) Define $\varphi : G → Inn(G)$ by $\varphi(a) = \varphi_a$. Verify that $\varphi$ is surjective homomorphism and identify the kernel of $\varphi$.
Hint: For all $g\in G$:
$$(\gamma_a\circ \gamma_b)(g)=\gamma_a[\gamma_b(g)]= \gamma_a(bgb^{-1})=a(bgb^{-1})a^{-1}=(ab)g(ab)^{-1}=\gamma_{ab}(g)$$
That is, $\gamma_a\circ \gamma_b=\gamma_{ab}$.
Thanks! But how to prove it's a surjective homomorphism and what's the kernel of φ[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]?[/FONT]
ianchenmu said:
Thanks! But how to prove it's a surjective homomorphism and what's the kernel of φ?
isn't every element in Inn(G) of the form $f_a$, where $a \in G$? So for every element, $f_a \in$ Inn(G), there is a corresponding a which lives in G, so indeed the homomorphism $\varphi$ is surjective.
I think the more important question is whether $\varphi$ is even a homomorphism. which means for $a,b \in G$, $\varphi(ab) = f_{ab}$, by fernandos assertition this equals $f_a f_b = \varphi(a)\varphi(b)$. So indeed it a Homomorphism.
The kernel is all elements $a \in G$, such that $f_a = f_e$, the identity map, which would mean $f_a = a^{-1} x a = a^{-1} a x = x$, (note: $a^{-1}$ is also in the center if a is in the center) or basically elements which commutate with every element in G. or the center Z(G).
$\varphi$ is surjective by construction, that is if $\gamma_a\in\mbox{Inn } G$ then $\varphi(a)=\gamma_a$. On the other hand:
\begin{aligned}
\ker \varphi=&\{a\in G:\varphi(a)=id_G\}\\=&\{a\in G:aga^{-1}=g\;\forall g\in G\}\\=&\{a\in G:ag=ga\;\forall g\in G\}\\=&Z(G)
\end{aligned}
That is, $\ker \varphi$ is the center of $G$.
And therefore, by the First Isomorphism Theorem:
$\text{Inn}(G) \cong G/Z(G)$.
\begin{aligned}
\end{aligned}
why $id_G=g$? Is $g$ the identity of G? why not 1?
The identity element of $(\mbox{Inn }G,\circ)$ is the identity map $id_G(g)=g$ for all $g\in G$. So, $\varphi(a)=id_G$ is equivalent to say $\varphi(a)(g)=id_G(g)$ for all $g\in G$, or equivalent to say $aga^{-1}=g$ for all $g\in G$.
and is the binary operation of $Inn(G)$ the function composition?
Yes, the function composition.
FAQ: Proof about inner automorphism of a group
What is an inner automorphism of a group?
An inner automorphism of a group is a type of automorphism that maps every element of the group to another element in the group by conjugation. This means that the inner automorphism is defined by a fixed element of the group, and it essentially reorders the elements of the group without changing their underlying structure.
Why is it important to study inner automorphisms of a group?
Studying inner automorphisms of a group allows us to gain a deeper understanding of the group's structure and properties. It also helps us to identify certain subgroups and to classify groups into different isomorphism classes.
How is an inner automorphism different from an outer automorphism?
An inner automorphism is defined by an element within the group, while an outer automorphism is a mapping of the group to itself that is not defined by an element within the group. Outer automorphisms can only exist in non-abelian groups, while inner automorphisms can exist in both abelian and non-abelian groups.
Is every element of a group an inner automorphism?
No, not every element of a group is an inner automorphism. Only certain elements, called conjugate elements, can define inner automorphisms. These conjugate elements have the property that they commute with all elements in the group.
Can inner automorphisms be used to prove the isomorphism between two groups?
Yes, inner automorphisms can be used as a tool in proving the isomorphism between two groups. If two groups have the same inner automorphisms, they are considered to be isomorphic. This can be a useful approach in proving isomorphism, especially when dealing with larger or more complex groups.
