Proof by Contradiction || Prove that an equation can never be a square number
In summary, the conversation is about proving that for any positive integer n, the expression n^2+n+1 can never be a square number. The person attempted to use the quadratic formula but found it too messy and is looking for an easier way to solve the problem. Another person points out that the statement is not true, as (-1)^2+(-1)+1=1=(1)^2. The original poster then realizes that the question was for positive integers only and asks for the thread to be closed.
haxan7
Prove that for any integer n n^2+n+1, can never be a square number.
None.
We could put the equation to a^2, (where a^2 is a square number) and solve for n and show that n can not be an integer.
I tried quadratic formula on the equation but the solution gets too messy, and i can't prove that the answer is not an integer.
There must be an easier way to solve this. Just point me in the right direction.
That's going to be very hard to prove, as it isn't true: (-1)2+(-1)+1=1=(1)^2
Sorry, the question was "for any positive integer n", how do i edit the thread?
There should just be a button that says edit in the bottom right of your post.
You can't edit your posts after 700 minutes.
Problem Solved, close this thread.
Related to Proof by Contradiction || Prove that an equation can never be a square number
1. Can you explain what a proof by contradiction is?
A proof by contradiction is a mathematical method that involves assuming the opposite of what we want to prove and showing that it leads to a contradiction or an impossibility. This allows us to conclude that our original assumption must be true.
2. How does proof by contradiction work in proving that an equation can never be a square number?
In the case of proving that an equation can never be a square number, we assume that the equation can be a square number. Then, we manipulate the equation and show that it leads to a contradiction, such as an irrational or imaginary number. This proves that our initial assumption was false and the equation can never be a square number.
3. Why is proof by contradiction a useful method in mathematics?
Proof by contradiction is useful because it allows us to prove statements that may be difficult to prove directly. It also provides a clear and logical structure to our proof and helps to eliminate any potential flaws in our reasoning.
4. Can you give an example of a proof by contradiction in proving that an equation can never be a square number?
Sure, let's take the equation x^2 + 2 = 0. Assuming that this equation can be a square number, we can rewrite it as x^2 = -2. However, this leads to a contradiction because -2 is not a perfect square. Therefore, our initial assumption was false and the equation can never be a square number.
5. Are there any limitations to using proof by contradiction in mathematics?
Yes, there are limitations to using proof by contradiction. This method can only be used for statements that can be proven by showing that their negation leads to a contradiction. It also relies on logical reasoning and may not be suitable for more abstract or complex mathematical concepts.
