Proof / derivation of d'Alembert principle?
In summary, the d'Alembert principle states that constraint and internal forces do not produce a change in momentum of that body. It is important because it allows for incorporation of holonomous and anholonomous constraints into mechanics. It is historically earlier than the Hamilton action principle, which nowadays is the fundamental starting point of all dynamical theories.
DoobleD
259
I can't find a derivation of d'Alembert principle. Wikipédia says there is no general proof of it. Same with stackexchange. I find it surprising so I thought I'd come here to check with you guys. D'Alembert principle has indeed no proof ?
I always thought of it as a general expression of the definition of force in Newton's second law.
ie. it is a definition of a concept - or a consequence of a definition. There is no proof - outside of demonstrating that the concept is empirically useful.
Thank you !
Well, I'd say the d'Alembert principle can be derived from the Hamilton principle, which is the fundamental principle of all contemporary physics. You could, of course, as well argue the other way around and take the d'Alembert principle as fundamental and derive Hamilton's from it (as is the tradition in many textbooks on analytical mechanics).
Any chance you'd have this derivation available somewhere ?
After going through the stackexchange link it seems to me that D'Alembert's principle is just a restatement of Newton's 2nd law.
Can one succintly describe the relevance of d'Alembert's principle ? I've taken two courses in classical mechanics (Newtonian and "analytical") and never heard of it. Since this bears no relevance to real theories of physics (electrodynamics, relativity, QM and QFT), I don[t understand why bring it in the first place...
What I understood is that this is true only in under certain conditions.
I find it peculiar as well. It seems it's useful to solve mechanic problems.
It states that constraint and internal forces do not produce a change in momentum of that body. I guess because it is so obvious many have a hard time understanding why it's so important.
I also never understood the relevance of the d'Alembert principle from a modern point of view. It's just historically earlier than the Hamilton action principle, which nowadays is the fundamental starting point of all dynamical theories. It's an extension of naive Newtonian mechanics in so far as it allows to incorporate holonomous and anholonomous constraints as does of course the action principle. Given the fundamental lemma of variational calculus the principles are pretty much equivalent:
The Hamilton principle defines the dynamics by the stationarity of the action
$$A[q]=\int_{t_1}^{t_2} \mathrm{d} t L(q,\dot{q},t),$$
where ##q## are ##f## generalized coordinates. If there are constraints, they have to be incorporated as restrictions on the allowed variations, i.e.,
$$\delta q^j f_j^{(\alpha)}(q,t)=0,$$
where ##j## runs from ##1,\ldots,f## (Einstein summation implied), and ##\alpha## labels the constraints, ##\alpha \in \{1,\ldots,k \}##, ##k<f##.
Then the constraints can be worked in with help of Lagrange parameters, leading to
$$\delta A[q]=\int_{t_1}^{t_2} \mathrm{d} t \left (\frac{\partial L}{\partial q^j} -\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{q}^j} + \sum_{\alpha} \lambda^{\alpha} f_j^{(\alpha)} \right ) \delta q^j \stackrel{!}{=}0,$$
and since this should be true for all ##\delta q^j##, you can leave out the integral, and what you get is d'Alembert's principle.
Likes DoobleD
The time independent constraints restrict the number of degrees of freedom one naïvely computes (number of particles times the dimension of space), hence the Lagrangian variables (generalized coordinates) are the ones encoding the true dynamics. Their variations are free.
For time dependent constraints, things are not easily separated.
I once asked a similar question. The Hamilton's principle can be derived as a classical limit of the QM path integral formulation.
However I still don't now if this is more fundamental, since the path integrals also make use of Hamiltonian or Lagrange formulations.
Thank you for the answers !
Related to Proof / derivation of d'Alembert principle?
1. What is d'Alembert's principle?
D'Alembert's principle is a fundamental concept in classical mechanics that states that the sum of the forces acting on a body is equal to the product of the mass of the body and its acceleration, taking into account the inertial forces. It is named after French mathematician and physicist Jean le Rond d'Alembert.
2. How is d'Alembert's principle derived?
D'Alembert's principle can be derived from Newton's second law of motion, which states that the net force acting on an object is equal to its mass multiplied by its acceleration. By considering the sum of all forces acting on a body and incorporating the concept of inertial forces, d'Alembert's principle is obtained.
3. What is the significance of d'Alembert's principle?
D'Alembert's principle is significant because it provides a mathematical framework for analyzing the motion of rigid bodies. It allows for the simplification of complex systems by considering only the external forces acting on a body, rather than all the internal forces. This principle is also used in the study of vibrations and oscillations.
4. Can d'Alembert's principle be applied to non-rigid bodies?
No, d'Alembert's principle is only applicable to rigid bodies. This is because it assumes that the body has a constant mass and does not deform under external forces. For non-rigid bodies, other principles and equations must be used to analyze their motion.
5. Are there any limitations to d'Alembert's principle?
Yes, there are limitations to d'Alembert's principle. It is only applicable to systems that are in equilibrium or in a state of constant motion. It also does not take into account friction or other dissipative forces, which can significantly affect the motion of a body. In some cases, the principle may also lead to incorrect results, and other methods must be used to accurately analyze the system.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
