Proof: Every convergent sequence is Cauchy
In summary: ProofSuppose that the sequence is not Cauchy. Then there exists a positive number ε such that for every m, n > N there exists a number a such that | am...an| < ε.Since the terms of the sequence eventually all become arbitrarily close to one another, this contradicts the assumption that the sequence is not Cauchy.
zigzagdoom
27
Hi,
I am trying to prove that every convergent sequence is Cauchy - just wanted to see if my reasoning is valid and that the proof is correct.
Thanks!
1. Homework Statement
Prove that every convergent sequence is Cauchy
/ Theorems[/B]
Theorem 1: Every convergent set is bounded
Theorem 2: Every non-empty bounded set has a supremum (through the completeness axiom)
Theorem 3: Limit of sequence with above properties = Sup S (proved elsewhere) Incorrect - not taken as true in second attempt of proof
Suppose (sn) is a convergent sequence with limit L. Let S = {sn: n∈ℕ}
By Theorem 1, every convergent set is bounded. By Theorem 2, sup S exists, let Sup S = M.
Since (sn) is convergent, for every ε > 0, ∃N such that ∀n > N, | sn - L | < ε, where L = M
Now, since M = Sup S, consider some M - φ < M for some 0 < φ < ε.
But then this means ∃sn such that M - φ < sn < M.
i.e. sn + α = M for some α > 0
So M - ε < M - φ < sn < M.
This is the same as M - ε < M - φ < M - α < M
But then | (M - ε) - (M - φ) | > | (M - φ) - (M - α) |.
I.e. the sequence is Cauchy.
zigzagdoom said:
Hi,
Thanks!
/ Theorems[/B]
There is no reason to suppose L = M. And your theorem 3 above, whatever it means, is false. And you have not even stated what a Cauchy sequence is, let alone proved that property.
Thanks LCKurtz,
I think i implcitly assumed that the sequence is monotonically increasing. But the Theorem 3 is not true as a a sequence denoted by the sine function would be bounded, yet not convergent I suppose.
I will give it another crack
Start by writing the definition of a Cauchy sequence. Then use:
(sn) is convergent [to L if], for every ε > 0, ∃N such that ∀n > N, | sn - L | < ε, where L = M
without the incorrect part in red, to prove it. It has nothing to do with sup.
No. See my post #4 which I apparently posted the same time you were posting #5.
Attempt
A sequence is called a Cauchy sequence if the terms of the sequence eventually all become arbitrarily close to one another
That is, given ε > 0 there exists N such that if m, n > N then | am - an | < ε
(sn) is convergent to L if for every ε > 0, ∃N such that ∀n > N, | sn - L | < ε
which implies sn < ε + L
Now consider three consecutive numbers in the sequence sn, so, sp. It follows that
sn < ε + L
so < α + L
sp < β + L
where β ≤ α ≤ ε by notion of convergence.
it then follows that the distance between sn and so; | sn - so | = | ε - α | ≥ | so - sp | = | α - β |.
Hence the terms get closer and closer, so the sequence is Cauchy.
Thanks,
Would the argument I posted before be incorrect? I essentially just used the supremum as a point of reference to gauge distance between points.
None of your arguments look good, sorry to say. You have the definitions you have given earlier (I have edited them slightly for clarity):
The sequence ##\{s_n\}## is convergent to L if for every ε > 0, ∃N such that ∀n > N, ##|s_n-L|<\epsilon##. That is what you are given to work with.
And the sequence ##\{s_n\}## is Cauchy means that given ε > 0 there exists N such that if m, n > N then ##|s_m-s_n|<\epsilon##. That is what you have to prove.
Now if you think about that, you are informally saying that ##s_n## gets close to L for large n because the sequence converges to it. So for large n and m, both ##s_n## and ##s_m## get close to L. That is what you are given. Now, if they both get close to L, wouldn't they have to get close to each other? Intuitively it makes sense. Your problem is to write down the appropriate inequalities to prove it. I hope that's enough of a hint to get you going.
Likes zigzagdoom and PeroK
OK so from the above, I would do as follows:
Third Attempt
Since ##|s_n-L| < \epsilon##
##|s_n| < |L + \epsilon|##
##|s_n - s_m| < |L + \epsilon - s_m|##
##| (s_n - L) - (s_m - L) | < |L + \epsilon - s_m|##
But ##|s_n-L| < \epsilon## and ##|s_m-L| < \epsilon## as the both ##s_m## and ##s_n## converge to L, for ##∀m,n##
So ##| (s_n - L) - (s_m - L) | < 2\epsilon## (by triangle inequality)
i.e. ##| s_n - s_m | < 2\epsilon##, that is ##s_n## and ##s_m## get arbitrarily close. The sequence is therefore Cauchy.
Third Attempt
This last inequality isn't necessarily true.
Take ##s_n=L-\frac{9}{10}\epsilon## and ##s_m=L+\frac{9}{10}\epsilon##
Then ##|s_n - s_m|=\frac{18}{10}\epsilon##, and ##|L + \epsilon - s_m|=\frac{1}{10}\epsilon##
But it doesn't really matter because you don't use that inequality.
The core argument is here:
Now you have to word this correctly (for example, writing "both ##s_m## and ##s_n## converge to L" is sloppy).
Thanks Samy,
I did not realize a sequence can converge to a Limit from both the left and the right - will keep that handy fact in mind.
So in terms of wording I would approach as follows;
##∀\epsilon > 0, ∃N ∋## ##∀n,m > N, | s_n - L | < \epsilon## and ##| s_m - L | < \epsilon##.
By the trianle inequality, ## | s_n - L + L - s_m | ≤ | s_n - L | + | s_m - L | < \epsilon + \epsilon = 2\epsilon##
Since ##2\epsilon## is arbitrarily large, we can make both ##s_n## and ##s_m## as close together as we like, for ##∀n,m > N##.
Therefore, the sequence is Cauchy.
Would this be a more rigid argument?
There is a typo, as you write "arbitrarily large", while you clearly mean "arbitrarily small".
One can nitpick about details, but I think this proof is correct.
Likes zigzagdoom
Thank you for the help
And if you want to spiff it up a little, pick N so that if n,m > N then ##|s_n-L|<\frac \epsilon 2## and ##|s_m-L|<\frac \epsilon 2## in the first place, so ##|s_m-s_n|<\epsilon##.
Likes zigzagdoom
FAQ: Proof: Every convergent sequence is Cauchy
What does it mean for a sequence to be convergent?
A convergent sequence is one in which the elements of the sequence approach a single, finite value as the sequence progresses. This value is known as the limit of the sequence.
What is the significance of a sequence being Cauchy?
A sequence being Cauchy means that the elements of the sequence get closer and closer together as the sequence progresses. This is an important concept in real analysis and is often used as a criterion for convergence.
How is the proof that every convergent sequence is Cauchy typically approached?
The proof usually begins by assuming that the sequence is convergent and then using the definition of convergence to show that the sequence is also Cauchy. This involves manipulating the terms of the sequence and using the triangle inequality to show that the differences between terms get smaller and smaller.
Why is the converse of this statement not necessarily true?
The converse of the statement, "Every convergent sequence is Cauchy," is "Every Cauchy sequence is convergent." However, this statement is not always true. There are some cases where a sequence can be Cauchy but not convergent, such as in the field of p-adic numbers.
How does this proof relate to other concepts in real analysis?
The proof that every convergent sequence is Cauchy is closely related to other concepts in real analysis, such as continuity and completeness. It relies on the concept of limits and the properties of convergent and Cauchy sequences to show that they are equivalent in certain cases.
