How to Prove a Congruence Relation for Prime Numbers?
In summary: So the proof is complete I guess.In summary, the conversation discusses proving a congruence relation involving prime numbers and natural numbers. The proposed proof involves simplifying the fraction in the left-hand side of the equation and using Wilson's theorem to show that the first and last terms must not have a factor of p, while the middle term must have at least one factor of p. This holds true for any n greater than p.
DaTario
1,056
39
TL;DR Summary
Hi All, I would like to ask for help in proving the following congruence relation:
Let p be a prime number and let ##n## be a natural such that ##p < n < p^2##. Then
$$ {n-1 \choose p-1} {n \choose p-1} \equiv 0 (\mbox{mod p}) $$
Hi,
I would like to prove the following congruence relation:
Then
$$ {n-1 \choose p-1} {n \choose p-1} \equiv 0 (\mbox{mod p}) .$$
I am expecting it to have a rather trivial proof. Thanks in advance for any contribution, ...
Best Regards,
DaTario
Write LHS in the form of fraction. Numerator includes p successive multiples, i.e.
[tex]n(n-1)...(n-p+1)[/tex] so we know it must have factor p. Denominator ##(p-1)!^2## cannot have factor p.
But the denominators also have ##(n-p)!## and ##(n-p+1)!##.
And now I realize that ##n## need not to have an upper bound.
Please show me full form of fraction to check your claim.
Ok, now I got it (you showed a part of the numerator and made some simplifications). But I am still not so confident that the whole proposition is demonstrated. Firstly because it seems that you have made the simplification exactly with the factorial of (p-1), which you claim appears in the denominator at the end. Forgive me if I am asking too much. Can we go step by step in this proof?
We have:
$$ \frac{(n-1)!}{(p-1)! (n-p)!}\frac{(n)!}{(p-1)! (n-p+1)!} \equiv 0 (\mbox{mod p}) $$
So it is written as
[tex]\frac{(n-1)(n-2)...(n-p+1)}{(p-1)!}\frac{n(n-1)(n-2)...(n-p+2)}{(p-1)!}[/tex][tex]=\frac{n(n-1)^2(n-2)^2...(n-p+2)^2(n-p+1)}{(p-1)!^2}[/tex]
You see n(n-1)(n-2)...(n-p+1) in the numerator.
I see it. Twice, almost (there are ##(n-1)!## and ##n!##.)
The formalization of this proof requires one to point out that between ##n## and ##(n-p+1)## there is certainly at least one multiple of ##p##, doesn't it?
(I still have the impression that you are simplifying the numerator with the (p-1)! instead of doing so with the factor (n-p)!)
Likes anuttarasammyak
An idea:
You could look at the factors of ##p## generally in numbers between ##p## and ##p^2##.
PS There is an elementary proof based on that idea. Try with ##p = 5## first, perhaps, then generalise.
DaTario said:
And now I realize that n need not to have an upper bound.
PeroK said:
You could look at the factors of p generally in numbers between p and p2.
I would like to know ##p^2## is mentioned in what intention.
It's generally true for ##n > p##.
I think you could prove this using Kummer’s theorem, which expresses the p-adic valuation of ##{n\choose m}## in terms of digit sums. I worked through it partially, and you end up with something like ##v_p({n\choose p-1})=1+\frac{s_p(n+1)-s_p(n)}{p-1}## if ##p|n+1##, or otherwise just ##1##. Assuming that ##n\geq p##.
Thank you very much, suremarc, but could you show, please, more steps of this proposed demonstration?
I changed my mind while writing out my steps, because I made some mistakes and there is a much simpler proof along the lines of what PeroK stated. Mainly, use Wilson’s theorem to show that ##v_p((p-1)!)=0##, and then one has $$v_p\Bigg({n\choose p-1}\Bigg)=v_p((n)_{p-1})$$ which is nonzero if and only if there is a multiple of ##p## between ##n-(p-1)## and ##n,## inclusive. (##(n)_k## is a falling factorial, or just ##\frac{n!}{k!}##.)
$$ {n-1 \choose p-1} {n \choose p-1} = \big ( \frac{1}{(p-1)!} \big )^2\big ( \frac{n!}{(n-p)!} \big ) \big (\frac{(n-1)!}{(n-p+1)!} \big ) $$
Now count the factors of ##p##. The first term has none, the last term must have at least as many in the numerator as the denominator. And, the middle term must have at least one more factor of ##p## in the numerator. This holds for any ##n > p##.
Likes suremarc
D’oh. Why do I keep bringing in number theory theorems? (p-1)! is obviously not divisible by p, no need for Wilson’s theorem.
Thank you very much, suremarc and PeroK.
Related to How to Prove a Congruence Relation for Prime Numbers?
What is a congruence relation?
A congruence relation is a mathematical concept that describes the relationship between two objects or shapes that have the same size and shape, but may be oriented differently. It is often denoted by the symbol "≅" and is used to show that two objects are congruent, or identical.
How is a congruence relation proven?
A congruence relation can be proven using several methods, such as the Side-Side-Side (SSS) criterion, the Side-Angle-Side (SAS) criterion, or the Angle-Angle-Side (AAS) criterion. These methods involve comparing the corresponding sides and angles of two objects and showing that they are equal.
What is the difference between congruence and similarity?
Congruence and similarity are both ways to describe the relationship between two objects or shapes. Congruence means that two objects are identical in size and shape, while similarity means that two objects have the same shape but may be different in size.
Can a congruence relation be proven for all shapes?
Yes, a congruence relation can be proven for all shapes, as long as they have the same size and shape. This includes two-dimensional shapes, such as triangles and squares, as well as three-dimensional shapes, such as cubes and spheres.
Why are congruence relations important in mathematics?
Congruence relations are important in mathematics because they allow us to identify and describe the relationships between objects and shapes. They also help us to solve problems involving measurement, geometry, and symmetry. In addition, congruence relations are used in many real-world applications, such as architecture, engineering, and art.
  • Linear and Abstract Algebra
