[Proof] Fourier Coefficients = zero => function zero
In summary, the conversation discusses how to prove that an integrable, 2pi-periodic function is almost everywhere zero if all its Fourier coefficients are equal to zero. One suggestion is to use Parseval's theorem, which states that if the Fourier coefficients are zero, then the function itself must be zero. However, the person asking for help wants to avoid using this theorem and is looking for another approach. Another suggestion is to use the uniqueness of the Fourier transformation and the fact that it is its own inverse.
nonequilibrium
1,439
Hello!
How do I prove
If an integrable function f, 2pi-periodic, has all its Fourier coefficients equal to zero, then f is almost everywhere zero itself.
Thank you!
(it can be proven by using the convergence of the Fourier series in L_p-norm, but I want to use the above result to prove the convergence in L_2-norm, so I want to avoid that)
Mathematics news on Phys.org
Can you use Parseval's theorem? If the Fourier coefficients are zero, then the time-integrated power in the function is also zero, so the function itself must be zero.
Parseval's theorem is the L2 convergence theorem, which is what he is trying to prove.
Hm thank you both.
So is there another suggestion?
You can Google Parseval's theorem.
It's always hard to suggest what to do for a proof, because we don't know what the starting point is, but I would be inclined to use uniqueness of the Fourier transformation plus the fact that a Fourier transformation is (more or less) its own inverse.
Related to [Proof] Fourier Coefficients = zero => function zero
1. What are Fourier coefficients?
Fourier coefficients are coefficients used in Fourier series, which is a mathematical tool used to represent a periodic function as a sum of simple sine and cosine functions.
2. How are Fourier coefficients calculated?
Fourier coefficients are calculated by using the Fourier transform, which involves integrating the function over a period and then dividing by the period.
3. What does it mean for Fourier coefficients to be zero?
If the Fourier coefficients are zero, it means that the function can be represented as a sum of only sine or cosine functions. This is also known as a pure sine or cosine function.
4. What does it mean for the function to be zero if the Fourier coefficients are zero?
If the Fourier coefficients are zero, it means that the function is equal to zero at every point in its domain. This is because a pure sine or cosine function has a value of zero at every point except for its peak and trough.
5. How can the Fourier coefficients being zero be used to prove that a function is zero?
If the Fourier coefficients are zero, it can be used to prove that a function is zero by showing that the function can be represented as a sum of only sine or cosine functions, which would be equivalent to a zero function. This is a useful tool in proving mathematical identities and solving differential equations.
  • General Math
  • General Math
