Proof involving exponential of anticommuting operators
The discussion centers on proving a relation involving the exponential of anticommuting operators for cases where N=1 and N>1. A successful proof for N=1 is presented, showing that the relation holds with specific substitutions and manipulations. However, the transition to N>1 presents significant challenges, particularly in achieving a meaningful result. The author references Fradkin's work on Grassmann variables, noting potential complications due to non-trivial anticommutation relations in their current context. Assistance or guidance from others in the forum is sought to navigate these difficulties.
Joker93
The problem is to prove equation (5.31) from the book "Quarks, gluons and lattices" by Creutz. It involves anticommuting operators and functions of them acting on defined states, which I give below.
On page 23 of the book "Quarks, gluons and lattices" by Creutz, he defines a state
$$\langle\psi|=\langle 0|e^{bFc}e^{\lambda b^\dagger G c^\dagger}$$
where ##\lambda## is a number, ##F, G## are ##N\times N## symmetric matrices and ##b, c## are vectors whose components ##b_m, c_m## are operators such that their anticommutators satisfy
$$\{b_m^\dagger, b_n\}=\{c_m^\dagger, c_n\}=\delta_{mn}$$
with every other anti-commutator being zero, and the state ##\langle 0 |## such that
$$\langle 0 |c^\dagger_m=\langle 0 |b^\dagger_m=0$$
Creutz says that a straightfoward calculation can lead us to proving that
$$\langle\psi|b^\dagger=-\langle\psi|(F^{-1}-\lambda G)^{-1} c=-\langle\psi|(1-\lambda FG)^{-1}Fc$$
For ##N=1##, I have managed to prove this, but for ##N>1##, I am struggling with how to show this. Something that I managed to prove is that
$$\langle\psi |b_k^\dagger=-\langle 0 | \sum_{n=1}^N F_{kn}c_n \prod_{m=1\neq k, l}^N \left(1+b_m F_{ml}c_l \right)$$
which generalizes what I initially found for the ##N=1## case, which is ##\langle\psi|b^\dagger=-\langle 0|Fc##. For this last result for the ##N=1## case, I then substituted ##\langle 0 |=\langle \psi | e^{-\lambda b^\dagger G c^\dagger}e^{-bFc}##, and after some manipulations, I reached the end of the proof. Doing something similar for the ##N>1## case, I found it too difficult to get to a meaningful result (or even close to the final result).
Note that for the ##N>1## case, I have used that, for example,
$$e^{bFc}=e^{\sum_{ij}b_i F_{ij} c_j}=\prod_{ij}(1+b_iF_{ij}c_j)$$
which is found on page 193 of Fradkin's book "Quantum Field theory: an integrated approach". Note that there, Fradkin was talking about Grassmann variables being on the exponential, whereas here we have the above non-trivial anticommutation relations; so, this might have been where I got it wrong.
If anybody can give a hint or some guidance on this, or even provide with some reference that can help, it would be greatly appreciated.
Note that I have proved that the last relation holds.
If anybody could help with the problem by just even a suggestion, It would be appreciated.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
