Proof involving the sum of squared integers
In summary, the conversation discusses the theorem that the numbers in the set {99, 999, 9999, ... } cannot be written as two squared integers, but at least one can be expressed as the sum of 3 squared integers. The conversation also mentions using Euclid's division algorithm and testing for remainders to show that none of the numbers can be the sum of two squares.
Entropee
Theorem: the numbers in the set {99, 999, 9999, ... } cannot be written as two squared integers, but at least one can be expressed as the sum of 3 squared integers.
Well there are a lot of examples but let's go with 32 + 32 + 92 = 99
We may have to use Euclid's division algorithm as well.
If we call the first part P and the second part Q then we can assume [itex]\neg[/itex]P [itex]\vee[/itex] [itex]\neg[/itex]Q, and try to show a contradiction here.
What is P, what is Q?
I would consider remainders here.
Sorry I'm on an ipad and was being lazy haha. Let p stand for "the numbers in that set cannot be written as two squared integers" and Q stand for "at least one number in the set can be represented as three integers squared." How should remainders be used here?
Just show both of them separately, there is no need to start with logical statements. You found an example how at least one of those numbers can be written as sum of three squares. Fine, this part is done. Now you have to show that none of those numbers is the sum of two squares.
As always. Test if an equality can hold mod some number - if not, it cannot be true at all.
FAQ: Proof involving the sum of squared integers
What is the concept of "Proof involving the sum of squared integers"?
The concept of "Proof involving the sum of squared integers" is a mathematical proof technique that involves proving a statement by using the sum of squared integers. This technique is commonly used in number theory and algebra.
What is the formula for calculating the sum of squared integers?
The formula for calculating the sum of squared integers is n(n+1)(2n+1)/6, where n is the number of integers being summed.
How can "Proof involving the sum of squared integers" be applied in real-life situations?
One real-life application of "Proof involving the sum of squared integers" is in cryptography, specifically in the RSA encryption algorithm. This algorithm relies on the difficulty of factoring large integers, which can be proven using the sum of squared integers technique.
What are some common strategies used in proofs involving the sum of squared integers?
Some common strategies used in proofs involving the sum of squared integers include using mathematical induction, using the properties of perfect squares, and manipulating the formula for calculating the sum of squared integers.
What are some common misconceptions about "Proof involving the sum of squared integers"?
One common misconception is that this proof technique can only be applied to perfect squares. In reality, it can be applied to any set of integers, whether perfect squares or not. Another misconception is that this technique can only be used to prove statements about integers, when it can also be applied to other mathematical concepts such as polynomials.
