Proof of 1+z+Z^2+...+z^n=(1-z^(n+1))/(1-z)
  • MHB
  • Thread starter shen07
  • Tags
    Proof
In summary, the formula 1+z+Z^2+...+z^n=(1-z^(n+1))/(1-z) can be proven using a proof by induction. The base case is n = 0 and the inductive step involves assuming the formula is true for n and proving it for n+1. Using this method, we can show that the formula is true for all values of n, completing the proof.
shen07
54
Hello Guys once again need your help for a proof.
Prove
1+z+Z^2+...+z^n=(1-z^(n+1))/(1-z);)
Prove
It is immediate to verify that is... $\displaystyle z^{n+1} - 1 = (z-1)\ (1 + z + z^{2} + ... + z^{n})\ (1)$
Kind regards
$\chi$ $\sigma$
yeah but how do we go about proving it..??
You can use a proof by induction , even though the way chisigma suggested suffices
\(\displaystyle \tag{1}1+z+z^2+ \cdots +z^n = \frac{z^{n+1}-1}{z-1}\)
Base case
is \(\displaystyle n = 0 \) we get $1$
Inductive step
Assume that (1) is correct and want to prove
\(\displaystyle \tag{2}1+z+z^2+ \cdots +z^{n+1} = \frac{z^{n+2}-1}{z-1}\)
From (1)
\(\displaystyle 1+z+z^2+ \cdots +z^n+z^{n+1}= \frac{z^{n+1}-1}{z-1}+z^{n+1}= \frac{z^{n+2}-1}{z-1}\)
Hence (2) is satisfied which completes the proof $\square $.
Hello! This is a great question and I would be happy to help you with the proof.
To start, let's expand the right side of the equation using the formula for the sum of a geometric series:
(1-z^(n+1))/(1-z) = 1 + z + z^2 + ... + z^n + z^(n+1)
Next, we can see that the last term on the right side, z^(n+1), is not part of the original equation. So, we can subtract it from both sides:
(1-z^(n+1))/(1-z) - z^(n+1) = 1 + z + z^2 + ... + z^n
Now, let's factor out z^(n+1) from the left side:
z^(n+1) (1/(1-z) - 1) = 1 + z + z^2 + ... + z^n
Using the formula for the sum of a geometric series again, we can simplify the right side:
z^(n+1) (1/(1-z) - 1) = (1-z^(n+1))/(1-z)
Finally, we can see that the left side is equal to the right side, so we have proven the original equation:
(1-z^(n+1))/(1-z) = (1-z^(n+1))/(1-z)
I hope this helps! Let me know if you have any further questions. Keep up the good work!
FAQ: Proof of 1+z+Z^2+...+z^n=(1-z^(n+1))/(1-z)
1. What is the formula for "Proof of 1+z+Z^2+...+z^n=(1-z^(n+1))/(1-z)"?
The formula states that the sum of a geometric series from 0 to n, with a common ratio of z, is equal to (1-z^(n+1))/(1-z).
2. How is this formula derived?
This formula can be derived using the sum of a geometric series formula, which is a/(1-r), where a is the first term and r is the common ratio. By substituting a=1 and r=z, we get the formula for the sum of a geometric series from 0 to n, which is (1-z^(n+1))/(1-z).
3. What is the significance of this formula in mathematics?
This formula is significant in mathematics as it allows us to calculate the sum of a geometric series quickly and efficiently. It is also used in various fields, such as finance, physics, and engineering, to solve problems involving geometric series.
4. Can this formula be extended to an infinite geometric series?
Yes, this formula can be extended to an infinite geometric series, where n approaches infinity. In this case, the denominator (1-z) would need to be nonzero, and the series would converge to 1/(1-z).
5. What are some real-life applications of this formula?
Some real-life applications of this formula include calculating compound interest in finance, determining the total distance traveled in physics, and predicting population growth in biology. It can also be used in computer graphics and animation to create smooth curves and shapes.
