Proof of an expression concerning an RLC circuit
In summary, you can prove that in a damped RLC circuit, the logarithmic decrement equals the period times the damping factor.
batshwa
Hi,
How can you prove that, in a damped RLC circuit, the logarithmic decrement equals the period times the damping factor:
[tex]\delta=T\zeta[/tex]
(I'm using [tex]\delta=\ln\frac{x(t_n)}{x(t_n+T)}\quad
\zeta=\frac{R}{2L}
[/tex] )
Thanks in advance!
What equation do you get for v(t) for a parallel RLC circuit that has initial conditions v(0) = Vo and I(0) = 0 in the inductor?
I don't quite understand... but it seems to be my fault -- I forgot to mention that I'm talking about a series RLC circuit, not a parallel one.
Okay, but my question still applies, just with different initial conditions. I'm trying to see what equation you have for the ringout response of the RLC circuit. I'm not familiar with the equations you wrote above, so I'm hoping that once you write the equation for the response of the RLC circuit, I'll be able to map that familiar equation onto what you are asking above. (Or maybe you will see the answer to your question too, once you write the equation for how the RLC circuit works...)
I'm sorry, but I'm a total newbie regarding electric oscillations and RLC stuff. I don't quite underastand what equations you have in mind. I don't think you meant the differential equation of a damped oscillation, did you?
I hope there is no misunderstanding: I believe the expression above is generally valid (which is why I'm a bit troubled by your mentioning initial conditions).
Excuse any awkwardness my ignorance in physics is causing :) Can you recommend me any special (introductory) documents about RLC circuits on internet (apart from the Wikipedia article, which is somewhat unclear for me)?
Thanks a lot!
No worries. Yes, I was referring to the differential equation for the voltage (parallel RLC ) or current (series RLC) as a function of time. I'm not familiar with the term you mentioned in your first post ("logarithmic decrement"), but I'd imagine it is one way of expressing the damping factor of the circuit. I was hoping that by seeing how you wrote the equations for the V(t) or I(t) for the circuit, I'd be able to infer what the logarithmic decrement was and maybe answer your question.
I googled rlc circuit tutorial damped, and got lots of great hits. Try that google to see if some of those web pages help out. -Mike-
Right, this is the differential equation of my RLC circuit:
[tex]L\ddot q+R\dot q+\frac 1Cq=0[/tex]
Its solution is the following:
[tex]q(t)=\hat q\:e^{-\zeta t}\sin\left(\omega t+\varphi_0\right)[/tex]
where [tex]\hat q[/tex] symbolizes the maximum charge (or peak charge?).
I'll continue searching on Google, but until now I have found that expression I've posted here only once, unfortunately. It doesn't seem to be current.
You're getting closer, but yes, for the series RLC circuit, solve for the series current. You get an integral term, a differential term, and a linear term, then differentiate to get the DiffEq to solve. You should see some things that you can manipulate to answer your original question...
FAQ: Proof of an expression concerning an RLC circuit
What is an RLC circuit?
An RLC circuit is an electrical circuit that contains a resistor (R), an inductor (L), and a capacitor (C). These components are connected in series or parallel and work together to control the flow of electricity in the circuit.
How does an RLC circuit work?
An RLC circuit works by using the properties of the resistor, inductor, and capacitor to regulate the flow of electricity in the circuit. The resistor limits the current, the inductor stores energy, and the capacitor stores and releases charge.
What is the proof of an expression concerning an RLC circuit?
The proof of an expression concerning an RLC circuit is a mathematical representation that shows the relationship between the voltage, current, and impedance (resistance to the flow of electricity) in the circuit. This proof is based on the principles of Ohm's law and the properties of the components in the circuit.
How is an RLC circuit used in practical applications?
An RLC circuit is used in various practical applications, such as in electronic filters, tuning circuits, and oscillators. It is also commonly used in electronic devices like radios, televisions, and computers to regulate the flow of electricity and improve the performance of the circuit.
What are the benefits of using an RLC circuit?
Using an RLC circuit has several benefits, including its ability to regulate the flow of electricity, improve the stability and performance of the circuit, and filter out unwanted frequencies. It is also a cost-effective and versatile solution for various electronic applications.
