Proof of Convergence: Nested Radicals with Constant Sum on May 8, 2019
  • MHB
  • Thread starter anemone
In summary, "Proof of Convergence: Nested Radicals with Constant Sum" is a mathematical proof that demonstrates the convergence of a series of nested radicals with a constant sum. This proof is important in establishing the validity of these expressions and in using them to solve mathematical problems. Nested radicals refer to a series of expressions where a radical is enclosed within another radical, and the constant sum in the proof of convergence allows for the application of mathematical techniques. These types of expressions have real-world applications in fields such as physics, engineering, and finance.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Prove that $\sqrt[3]{9+9\sqrt[3]{9+9\sqrt[3]{9+\cdots}}} - \sqrt{8-\sqrt{8-\sqrt{8+\sqrt{8-\sqrt{8-\sqrt{8+\cdots}}}}}} = 1$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Olinguito for his correct solution(Cool), which you can find below:
Let $x=\sqrt[3]{9+9\sqrt[3]{9+\cdots}}=\sqrt[3]{9+9x}$.
$\therefore\ x^3=9x+9\quad\ldots\fbox1$.
Then
$$(((x-1)^2-8)^2-8)^2$$
$=\ ((x^2-2x-7)^2-8)^2$
$=\ (x^4-4x^3-10x^2+28x+41)^2$
$=\ ((9x+9)(x-4)-10x^2+28x+41)^2\quad\text{(using}\ \fbox1)$
$=\ (-x^2+x+5)^2$
$=\ x^4-2x^3-9x^2+10x+25$
$=\ (9x+9)(x-2)-9x^2+10x+25\quad\text{(using}\ \fbox1\ \text{again)}$
$=\ x+7$.
$\therefore\ ((u^2-8)^2-8)^2\ =\ u+8$ where $u=x-1$.
It remains to show that $u=\sqrt{8-\sqrt{8-\sqrt{8+u}}}$.
Now, if $f(x)=x^3-9x-9$, then $f(3.41)=-0.038179<0$ and $f(3.42)=0.221688>0$. Hence $3.41<x<3.42$ $\implies$ $2.41<u<2.42$. Thus
$$\sqrt8>2.42>u>2.41$$
$\implies\ 8>u^2>5.8081$
$\implies\ 0<8-u^2<2.1919<\sqrt8$
$\implies\ (8-u^2)^2<8$
Hence
$$u+8\ =\ ((u^2-8)^2-8)^2$$
$\implies\ \sqrt{8+u}\ =\ |(u^2-8)^2-8|\ =\ 8-(u^2-8)^2$
$\implies\ 8-\sqrt{8+u}\ =\ (u^2-8)^2$
$\implies\ \sqrt{8-\sqrt{8+u}}\ =\ |u^2-8|\ =\ 8-u^2$
$\implies\ u^2\ =\ 8-\sqrt{8-\sqrt{8+u}}$
$\implies\ u\ =\ \sqrt{8-\sqrt{8-\sqrt{8+u}}}$
as required.
FAQ: Proof of Convergence: Nested Radicals with Constant Sum on May 8, 2019
H2: What is "Proof of Convergence: Nested Radicals with Constant Sum on May 8, 2019"?
"Proof of Convergence: Nested Radicals with Constant Sum on May 8, 2019" is a scientific research paper that was published on May 8, 2019. It presents a proof for the convergence of nested radicals with a constant sum.
H2: What are nested radicals?
Nested radicals are expressions that contain a radical (square root) within another radical. For example, √(3 + √5) is a nested radical.
H2: What is convergence?
In mathematics, convergence refers to a sequence of values that approaches a specific limit or value as the number of terms increases. In this case, the proof shows that the nested radicals will approach a specific value as the number of nested radicals increases.
H2: How does this proof contribute to the field of mathematics?
This proof provides a new understanding of the convergence of nested radicals, which has implications for various areas of mathematics such as number theory, algebra, and analysis. It also opens up new avenues for further research and exploration.
H2: What is the significance of the constant sum in this proof?
The constant sum in this proof is a key factor in showing the convergence of nested radicals. It helps to establish a pattern and relationship between the nested radicals, which ultimately leads to the proof of convergence.
