Proof of convergence theory in optimization
In summary: T\cdot Q \Lambda Q^T(x-x_*)$$ Since $Q$ is orthogonal, we have $||x-x_*|| = ||Q^T(x-x_*)||$, which means that $||x-x_*||$ and $||Q^T(x-x_*)||$ converge at the same rate.Now, let's consider the sequence $\left\{f(x_k)-f(x_*)\right\}$. By Taylor's theorem, we know that $$f(x_k)-f(x_*) = \triangledown f(x_*)\cdot (x_k-x_*) + \
i_a_n
83
The question is:Suppose that lim $x_k=x_*$, where $x_*$ is a local minimizer of the nonlinear function $f$. Assume that $\triangledown^2 f(x_*)$ is symmetric positive definite. Prove that the sequence $\left \{ f(x_k)-f(x_*) \right \}$ converges linearly if and only if $\left \{ ||x_k-x_*|| \right \}$ converges linearly. Prove that the two sequences converge at the same rate, regardless of what the rate is. What is the relationship between the rate constant for the two sequences?
(I guess we may use the orthogonal diagonalization of a symmetric matrix and $f(x_k)-f(x_*)=\triangledown f(x_*)+\frac{1}{2}(x_k-x_*)^T\cdot\triangledown^2 f(\xi)(x_k-x_*)$ and $\triangledown f(x_*)=0$... But I got stuck here. So what's your answer?)
Mathematics news on Phys.org
Answer:
The statement is true. To prove this, we will use Taylor's theorem and the orthogonal diagonalization of a symmetric matrix.
First, recall Taylor's theorem, which states that for any point $x_*$ in the domain of a function $f$, there exists an open neighborhood of $x_*$ such that for any $x$ in this neighborhood, $$f(x) = f(x_*) + \triangledown f(x_*)\cdot (x-x_*) + \frac{1}{2}(x-x_*)^T\cdot\triangledown^2 f(\xi)(x-x_*)$$ for some $\xi$ between $x_*$ and $x$.
Since $\triangledown^2 f(x_*)$ is symmetric positive definite, it can be orthogonally diagonalized. That is, there exists an orthogonal matrix $Q$ such that $\triangledown^2 f(x_*) = Q \Lambda Q^T$, where $\Lambda$ is a diagonal matrix with the eigenvalues of $\triangledown^2 f(x_*)$ on its diagonal. Therefore, we can rewrite the second term as $$\frac{1}{2}(x-x_*)^T\cdot\triangledown^
FAQ: Proof of convergence theory in optimization
What is proof of convergence theory in optimization?
Proof of convergence theory in optimization is a mathematical concept used to prove that an optimization algorithm will reach the optimal solution. It verifies the performance of the algorithm, and guarantees that it will eventually converge to the best possible solution.
Why is proof of convergence theory important in optimization?
Proof of convergence theory is important because it provides a way to validate the effectiveness of an optimization algorithm. It allows researchers and practitioners to have confidence in the results produced by the algorithm and ensures that the solution obtained is the best possible one.
How is proof of convergence theory determined?
Proof of convergence theory is determined by analyzing the properties of the optimization algorithm and its convergence criteria. This involves mathematical proofs and analysis of the algorithm's behavior in different scenarios to determine its convergence to the optimal solution.
What are the different types of convergence in optimization?
The two main types of convergence in optimization are global convergence and local convergence. Global convergence guarantees that the algorithm will converge to the global optimal solution, while local convergence ensures that it will converge to a local optimal solution.
Can proof of convergence theory be applied to all optimization problems?
No, proof of convergence theory cannot be applied to all optimization problems. It is dependent on the properties and characteristics of the specific optimization algorithm being used. Some algorithms may have not been proven to converge, while others may have different levels of convergence guarantees.
