Proof of Cosine law using vectors
In summary, to prove the length of a resultant vector r when two vectors of lengths a and b make an angle θ with each other, components along two perpendicular axes can be taken. The resultant vector can be simplified to r=√(a^2+b^2+2abcos θ ) by finding the net x and y components and using the Pythagorean theorem.
Andrewlorenzo
Two vectors of lengths a and b make an angle θ with each other when placed tail to tail. Prove, by taking components along two perpendicular axes, that the length of the resultant vector is r=√(a^2+b^2+2abcos θ )
Would this be correct?
How would you simplify it?:rolleyes:
So ax = acos θ , bx = bcos θ , ay = asin θ , by = bsin θ. So rx = ax + bx and ry = ay + by . So r=√(r_x+r_y ) .
Which means that, √(〖[(a+b)cosθ]〗^2+〖[(a+b)sinθ]〗^2 )
Let vector a be along x-axis and vector b makes an angle theta with x-axis.
Now take the component of b along x and y axis. Find net x component and y component and find the resultant.
=√((a+b)^2 (cos^2θ+sin^2θ))=√((a+b)^2 )=√(a^2+b^2+2abcos θ )
Hello,
Your attempt at a solution is correct. To simplify it, you can use the Pythagorean identity (cos^2 θ + sin^2 θ = 1) to simplify the expression inside the square root to (a + b)^2. This will give you a final result of r = √(a^2 + b^2 + 2abcos θ).
FAQ: Proof of Cosine law using vectors
What is the Cosine Law?
The Cosine Law, also known as the Law of Cosines, is a mathematical rule that relates the sides and angles of a triangle. It states that the square of one side of a triangle is equal to the sum of the squares of the other two sides minus twice the product of the two sides multiplied by the cosine of the angle between them.
How is the Cosine Law used to prove the relationship between vectors?
The Cosine Law can be used to prove the relationship between vectors by using the formula a² = b² + c² - 2bc*cos(A), where a, b, and c are the magnitudes of the vectors and A is the angle between them. By plugging in the vector magnitudes and angle values, the equation can be simplified to show that the cosine of the angle between the vectors is equal to their dot product divided by the product of their magnitudes.
Why is the Cosine Law important in vector mathematics?
The Cosine Law is important in vector mathematics because it allows us to determine the relationship between vectors and their angles. It is a useful tool in solving problems involving vectors, such as finding the resultant vector of two given vectors or determining the angle between two vectors.
Can the Cosine Law be used to prove other mathematical concepts?
Yes, the Cosine Law can be used to prove other mathematical concepts, such as the Pythagorean Theorem. By setting the angle between two vectors to 90 degrees, the Cosine Law equation simplifies to the Pythagorean Theorem formula, showing that the two concepts are equivalent.
Are there any limitations to using the Cosine Law in vector mathematics?
There are certain limitations to using the Cosine Law in vector mathematics. It can only be used for 2D or 3D vectors, and it assumes that the vectors are in a closed system (such as a triangle). Additionally, it cannot be used for non-right triangles or for vectors in higher dimensions.
