Proof of Equality for Odd Integers with Floor Function
  • MHB
  • Thread starter tmt1
  • Tags
    Proof
In summary, the conversation discusses proving or disproving the equation $ \left\lfloor{\frac{n}{2}}\right\rfloor= \left\lfloor{ \frac{n - 1}{ 2}}\right\rfloor$ where n is an odd integer. The speaker starts by showing that $ \left\lfloor{\frac{2k + 1}{2}}\right\rfloor = k$, and then concludes that $k = \frac{n - 1}{2}$, which should be sufficient to prove the equation.
tmt1
234
I need to prove or disprove that
$$ \left\lfloor{\frac{n}{2}}\right\rfloor= \left\lfloor{ \frac{n - 1}{ 2}}\right\rfloor$$ where n is an odd integer.I start with something like,
$$\left\lfloor{\frac{2k + 1}{2}}\right\rfloor$$
and then
$$\left\lfloor{k + \frac{1}{2}}\right\rfloor$$ which equals $$k$$
But
$$ k = \frac{n - 1}{2}$$
So is that enough proof for the question? or is it wrong?
and then
But
as n is odd a and n = 2k+1 so $ k = \frac{n - 1}{2}$ so it should be sufficient
FAQ: Proof of Equality for Odd Integers with Floor Function
What is "Proof of equality of floors"?
"Proof of equality of floors" is a mathematical concept that refers to demonstrating that two mathematical expressions or equations are equal. This is typically done through a series of logical steps and mathematical operations.
Why is proving equality of floors important?
Proving equality of floors is important because it helps to verify the accuracy of mathematical equations and expressions. It also allows us to make deductions and draw conclusions about the relationships between different mathematical quantities.
How is "Proof of equality of floors" used in real life?
Proof of equality of floors is used in various fields such as physics, engineering, and computer science. It helps to ensure the correctness of mathematical models and calculations in these fields. It is also used in everyday situations, such as calculating discounts or determining the number of items needed to fill a given space.
What are some common techniques used to prove equality of floors?
Some common techniques used to prove equality of floors include using mathematical identities, simplifying expressions, and manipulating equations using algebraic properties. Induction and proof by contradiction are also commonly used methods.
Are there any limitations or exceptions to "Proof of equality of floors"?
Yes, there are some limitations and exceptions to "Proof of equality of floors". For example, in some cases, it may be impossible to prove equality of floors due to the complexity of the expressions involved. Additionally, certain mathematical operations, such as division by zero, may result in undefined or indeterminate expressions, making it impossible to prove equality. It is important to carefully consider the assumptions and conditions when using proof of equality of floors in mathematical arguments.
