Proof of Euler's Formula with No Angle Addition
  • MHB
  • Thread starter mathbalarka
  • Tags
    Formula
In summary, the conversation discusses different approaches to prove Euler's formula $e^{i\theta} = \cos(\theta) + i\sin(\theta)$ without using the angle addition formula for sine and cosine. One approach involves using the formal derivative of $z(t)$ and justifying that it does not involve the angle sum identity. Another approach involves defining the functions $e^{i\theta}$, $\cos\theta$, and $\sin\theta$ by their power series and deriving all other properties, including the angle sum identity, from that. A third approach involves proving $e^{i(\theta+\phi)} = e^{i\theta}e^{i\phi}$ using the Cauchy product theorem and deducing
  • #36
As I see it, you've proved:
$e^{iz} = \cos\theta + i \sin\theta$ for some $\theta \in [0,2\pi)$
I see no problem with assuming $z \in \Bbb R$ but I think you still have to show:
$z - \theta = 2k\pi,\ k \in \Bbb Z$
Mathematics news on Phys.org
  • #37
Ah, you're right, we are at the point of differentiating sin and cos again, true. :p
  • #38
Recall that differentiating geometrically is the limit of a certain ratio (of two differences), and that trig functions are themselves ratios. Can you show geometrically that:
$(\sin)'(x) = \cos x$?
(I believe you CAN if you have the angle-sum formulas already established...but...)
  • #39
Yes, I had a proof for it in my mind and was trying to prove it the other way around. Nevermind, here it is :
The beginning of the proof of mine starts similarly as chisigma's : Let $\vec{r}$ be a point moving along the unit circle with uniform velocity and with co-ordinate $r(t) = (\cos(t), \sin(t))$. We have $|\vec{r}| = 1$ as well as $\vec{r} \cdot \vec{r} = 1$.
Differentiating, we obtain
$$\vec{\frac{dr}{dt}} \cdot \vec{r} + \vec{r} \vec{\cdot \frac{dr}{dt}} = 0$$
i.e., $\vec{r} \cdot \vec{\frac{dr}{dt}} = 0$. This implies the vectors $\vec{r}$ and $\vec{\frac{dr}{dt}}$ are orthogonal. Then all the co-ordinates of $\vec{r}$ are shifted by a sum of $\pi/2$. Hence,
$$ r'(t) = (\cos(t + \pi/2), \sin(t + \pi/2)) = (-\sin(t), \cos(t))$$
Note that these are obtained by noting the symmetries of circle, so has nothing to do with the angle-sum formula. Note further that the equality still doesn't follow as we have no knowledge about the scalar $\left | \vec{\frac{dr}{dt}} \right |$. This can be proved to be 1 by noting that the it is the velocity of the vector $r$ which is in turn equals to $\frac{d}{T}$ where $d$ is the distance, i.e, $2\pi$ and $T$ is the period of motion, i.e, $2\pi$. This proves that
$$\frac{d}{dt} \left ( \sin(t) \right ) = \cos(t)$$
$$\frac{d}{dt} \left ( \cos(t) \right ) = -\sin(t)$$
Does this look good?
  • #40
The beginning of the proof of mine starts similarly as chisigma's : Let $\vec{r}$ be a point moving along the unit circle with uniform angular speed $\frac{1}{2\pi}$ and with co-ordinate $r(t) = (\cos(t), \sin(t))$. We have $|\vec{r}| = 1$ as well as $\vec{r} \cdot \vec{r} = 1$.
A couple of minor notes:
It is the arguments of the coordinates that are shifted by $\dfrac{\pi}{2}$.
We can't say "which way" the shift occurs from your argument, it could be plus or minus, yes? Also, orthogonality only gives $r'(t)$ up to a scalar, so your FIRST equation involving it is not quite correct (which is why you need to find $|r'(t)|$). So I think you still need to show whether we have:
$r'(t) = (\cos t, -\sin t)$ or:
$r'(t) = (-\cos t, \sin t)$
  • #41
As $\vec{\frac{dr}{dt}}$ is the velocity vector of the point, it has the same direction as the position vector $\vec{r}$. Hence, no sign change is possible.
