Proof of Inequality Between Lower and Upper Bounds
In summary: But this seems like an easier task than proving convergence.The criterion of Abel looks promising. It's a criterion for a sequence to converge if it's bounded and either nondecreasing or nonincreasing. So it seems like it would work for our case.
muzak
44
Convergence of Divergent Series Whose Sequence Has a Limit
Suppose [itex]∑a_{n}[/itex] is a series with lim [itex]a_{n}[/itex] = L ≠ 0. Obviously this diverges since L ≠ 0. Suppose we make the new series, [itex]∑(a_{n} - L)[/itex]. My question is this: is there some sufficient condition we could put solely on [itex]a_{n}[/itex] (or maybe its sum) without calculating the limit or referencing it other than the existence of a limit so that the new series converges?
I can't think of anything here; I could list all of the convergence tests from Ch. 3 of Baby Rudin but doesn't seem wholly relevant with the way I phrased the question. Feels like this is probably something trivial from some higher level analysis course or analytic number theory course that I haven't had the chance to take yet.
There's one thing that seems possibly relevant (from Rudin):
Theorem Suppose [itex]a_{1}≥a_{2}≥a_{3}≥...≥0.[/itex] Then the series [itex]∑a_{n}[/itex] converges if and only if the series [itex]∑2^{k}a_{2^{k}}[/itex] converges.
I really don't know how to approach this without introducing the L somehow into the proof which isn't what I really wish to explore.
I thought to make some simple conditions first to try and reduce the nature of the problem, like making the sequence monotonic and non-negative. With the theorem, I was thinking of maybe introducing some sort of scaling maybe with the [itex]2^{k}[/itex] factor? I don't know.
I think the root test gives convergence for 0 < L < 1, but what about for L > 1? But this sort of references the limit.
That's a pretty vague question. Is this an actual book problem or a question you invented yourself? I don't see any reason why there would be such a simple condition. Well, obviously you can try all the series tests you've seen and adapt it to this case. But I don't really know what kind of answer you want here.
Invented. Just curious if there exists any such condition to give convergence. I don't know anything about techniques to deal with divergent series, so I'd be satisfied with any specific reference material in lieu of some answer.
Alright, thanks. Messed up the title of this thread but think I corrected it. Guess I can't fix the thread title, ah well.
Criterion of Abel looks promising maybe:
Let ∑+∞n=0an be a (real or complex) convergent series . Let (vn)n be a bounded sequence of real numbers which is either nondecreasing or nonincreasing. Then the sequence ∑+∞n=0vnan converges.
[itex]v_{n}[/itex] could be the [itex]a_{n}[/itex] and would have to figure out some convergent sequence so that the product equals (L - [itex]a_{n}[/itex]).
FAQ: Proof of Inequality Between Lower and Upper Bounds
What is "Proof of Inequality Between Lower and Upper Bounds"?
"Proof of Inequality Between Lower and Upper Bounds" is a mathematical concept that involves determining the minimum and maximum possible values for a given variable or set of variables. This is often used in optimization problems and to analyze the efficiency of algorithms.
Why is "Proof of Inequality Between Lower and Upper Bounds" important?
"Proof of Inequality Between Lower and Upper Bounds" is important because it allows us to understand the range of possible values for a variable or set of variables. This can help us make informed decisions and optimize our solutions.
What is the difference between lower and upper bounds?
The lower bound is the smallest possible value for a variable, while the upper bound is the largest possible value. These bounds help to define the range of values that a variable can take on.
How is "Proof of Inequality Between Lower and Upper Bounds" used in real-world applications?
Proof of Inequality Between Lower and Upper Bounds is used in various real-world applications, such as in finance to analyze the potential return on investment or in computer science to determine the efficiency of algorithms. It can also be applied in engineering, statistics, and many other fields.
What are some common techniques for proving inequality between lower and upper bounds?
Some common techniques for proving inequality between lower and upper bounds include using mathematical induction, contradiction, and direct proof. Other techniques such as using inequalities and limits may also be used depending on the specific problem at hand.
