Proof of irrationality of sqrt(2)
  • Thread starter ViolentCorpse
  • Tags
    Proof
In summary, the popular "proof by contradiction" of sqrt(2) assumes that the fraction a/b is irreducible, but this assumption must be made explicitly clear in the proof. The proof then proceeds to show that this assumption leads to a contradiction, proving that the original assumption was false.
ViolentCorpse
190
Hi,
There's something I don't understand in the popular "proof by contradiction" of sqrt(2) after the following step:
a2/b2 = 2
a2=2b2
The above equation implies that a2 is even. Fair enough. But the way I see it, the above equation also makes it impossible for a to be even, as
a=sqrt(2)*b.
This implies that a should actually be an irrational number as it is a multiple of sqrt(2). Though it seems obvious to me that if some number n^2 is even, then n must also be even, but in the context of the equation a2=2b2, it doesn't seem possible.
Shouldn't this be the end of the proof? We started by assuming that a and b are whole numbers and a/b can be used to represent sqrt(2), but found that a, at least, is actually irrational. Doesn't that count as a contradiction?
I'm really confused. :(
Mathematics news on Phys.org
ViolentCorpse said:
Hi,
a2/b2 = 2
a2=2b2
a=sqrt(2)*b.
It does, but you don't know that a priori. At this stage of the proof, you don't know yet that ##\sqrt{2}## is irrational.
Likes ViolentCorpse
Ohhhhh! I'm an utter idiot! I can't help laughing at myself now. Literally. :p
Thank you so much, micromass! I really appreciate it!
One another thing I would like to ask. When we say that we are assuming an irreducible fraction, are we just saying it? I'm trying to say that our math should be aware of the assumptions we are making so when we write down the premise of the proof, we should be translating that assumption into mathematical form.
How does the math know that a/b is not supposed to be a reducible fraction?
The irreducibility of a/b is assumed by the prover. At a later stage in the proof we show that a and b must have a common factor - there lies the contadiction that is the heart of the proof.
The proof goes like this: Assume that [itex](\frac{a}{b})^{2} = 2[/itex] where a and b are integers (and b≠0). We can also assume that the fraction is irreducible (a and b have no common factors). Then [itex] a^{2}=2\cdot b^{2}[/itex], which implies that a2 is even. But the only way a2 can be even is that a is even. Therefore you can write a = 2⋅p, where p is an integer. This gives [itex](\frac{2p}{b})^{2}=2 [/itex] or [itex] 4\cdot p^{2} = 2\cdot b^{2}[/itex] which gives [itex]b^{2}=2\cdot p^{2} [/itex] which implies that b2 is even. But the only way b2 can be even is that b is even. Therefore you can write b = 2⋅q, where q is an integer. But this again says that [itex]\frac{a}{b}=\frac{2p}{2q} [/itex] which means that a and b have a common factor (2) which is contrary to the assumption.
Likes ViolentCorpse
Thanks I understand pretty much all of the proof now except the use of assumption which is troubling me.
The first step of the proof is:
sqrt(2) = a/b.
Then we just tell ourselves that a/b is an irreducible fraction. There should be a way of letting the math know precisely what assumptions we are making because the statement (a/b)^2 = 2 could mean anything, so if it gives us a fraction with common factors, it's not really a contradiction because we only made that assumption verbally.
I'm sorry if I sound obnoxious. I'm just a bit of a dimwit.
No we don't, we make sure it is an irreducible fraction. How? You have given the answer yourself...
ViolentCorpse said:
... if it gives us a fraction with common factors ...
then what do you think you should do?
I'm sorry I don't get it. How do we make sure it is an irreducible fraction?
Basis knowledge of fractions: If there is a common factor in the numerator and denominator, we can remove it in both places (if the common factor is c, we have [itex]\frac{a}{b}=\frac{c\cdot p}{c\cdot q}= \frac{c}{c}\cdot\frac{p}{q}=1\cdot \frac{p}{q} [/itex].
Likes ViolentCorpse
I think the thing I'm having trouble grasping is how we are to make sure that a/b is already in its reduced form when we start the proof. Sure we could cancel it out later (even a and b can be reduced when we find they are both even), but I think it is important to the proof that a/b be already written in its reduced form. For example, if I write x = p/q, does that guarantee that I will get a value of x that is already reduced to it lowest form?
No. But you know that if it is not, you can reduce it.
You have to make some assumption when it comes to fractions, otherwise you will have to deal with an infinity of fractions all representing the same number. For example 1 = n/n for all n.
Likes ViolentCorpse
Right. Thank you very much!
Well, maybe there's one number for which this isn't true... All is a very general term.
Yes. I was a bit sloppy there. I should have said (∀n∈ℕ), but that is a bit unreadable.
FAQ: Proof of irrationality of sqrt(2)
1. What is the proof of irrationality of sqrt(2)?
The proof of irrationality of sqrt(2) is a mathematical proof that shows that the square root of 2 cannot be expressed as a fraction of two integers. In other words, it is not a rational number.
2. Who discovered the proof of irrationality of sqrt(2)?
The proof of irrationality of sqrt(2) is attributed to the ancient Greek mathematician, Pythagoras, who is also known for the Pythagorean theorem.
3. Why is the proof of irrationality of sqrt(2) important?
The proof of irrationality of sqrt(2) is important because it is one of the first known proofs of irrationality and has paved the way for further understanding of irrational numbers and their properties. It also has many applications in fields such as geometry, number theory, and computer science.
4. Can the proof of irrationality of sqrt(2) be applied to other numbers?
Yes, the proof of irrationality of sqrt(2) can be applied to other numbers that are not perfect squares. This proof can be generalized to show that the square root of any non-perfect square number is irrational.
5. How does the proof of irrationality of sqrt(2) relate to the Pythagorean theorem?
The proof of irrationality of sqrt(2) is related to the Pythagorean theorem because it involves showing that the diagonal of a square with sides of length 1 is an irrational number. This is directly linked to the Pythagorean theorem, which states that in a right triangle, the square of the length of the hypotenuse is equal to the sum of the squares of the other two sides.
