Proof of lower bound of a nonempty set of real numbers
In summary, if A is a nonempty set of real numbers bounded below, and -A is the set of numbers -x where x ∈ A, then it can be proven that the infimum of A is equal to the negative of the supremum of -A. This can be seen intuitively by drawing it on a number line, but a formal proof can be established by showing that -sup(-A) is a lower bound of A and is the least lower bound.
tronter
185
1. Let [itex] A [/itex] be a nonempty set of real numbers which is bounded below. Let [itex] -A [/itex] be the set of numbers [itex] -x [/itex], where [itex] x \in A [/itex]. Prove that [itex] \inf(A) = -\sup(-A) [/itex].
Intuitively this makes sense if you draw it on a number line. But I am not sure how to formally prove it.
If -x is in -A then -x<sup(-A)
this implies:
x>-sup(-A)
Therefor -sup(-A) is a lower bound of A.
Now establish it is the least lower bound (probably via contradiction).
FAQ: Proof of lower bound of a nonempty set of real numbers
What is a lower bound?
A lower bound is a number that is greater than or equal to all the numbers in a given set. It provides a limit or boundary for the set.
What is a proof of lower bound?
A proof of lower bound is a mathematical justification or evidence that shows that a given set of real numbers has a lower bound.
Why is it important to prove the lower bound of a set of real numbers?
Proving the lower bound of a set of real numbers is important because it helps to establish the existence and limit of the set. It also provides a foundation for further mathematical analysis and calculations.
What are the different methods used to prove the lower bound of a set of real numbers?
There are several methods used to prove the lower bound of a set of real numbers, including the method of contradiction, the method of mathematical induction, and the method of direct proof.
Can a set of real numbers have more than one lower bound?
Yes, a set of real numbers can have more than one lower bound. In fact, a set can have infinitely many lower bounds, as long as they are all greater than or equal to all the numbers in the set.
