Proof of Subspace: x-y-3z=0 in R^3
In summary: But, just to frame it in a better (and clearer) way, write\vec{r}(s,t) = (x,y,z) = \vec{0}+s\vec{u}+t\vec{v}So any point on this space is determined by specifying s and t.
pokgai
1. prove whether x-y-3z=0 is a subspace of R^3 or not
for proofs
1. set must not be empty
2. set is closed under vector addition
3. set is closed under scalar multiplication
Not sure if this is correct, but what I did was find the vector equation of the x-y-3z=0
which equals (x,y,z) = (0,0,0) +s(1,1,0)+t(3,0,1)
i defined (1,1,0) as v and (3,0,1) as u
so i added v+u and it remains true in that it equals 0
and then the scalar i just used any real value and either v or u and found that also equals 0
so hence it was a subset of R^3.. and also that (0,0,0) was defined..
not sure if that's what you're meant to do but yeah does that sound right?
your basic plan of action is correct. But, just to frame it in a better (and clearer) way, write
[tex]\vec{r}(s,t) = (x,y,z) = \vec{0}+s\vec{u}+t\vec{v}[/tex]
1. Show that it is not empty (Set some particular values of s and t, and show that there is atleast one point.
2. Closed under vector addition - Show that for a particular choice of (s1,t1) and (s2,t2), there always exists (s3,t3) such that [tex]\vec{r}(s_1,t_1)+\vec{r}(s_2,t_2)=\vec{r}(s_3,t_3)[/tex]
4. Closed under scalar multiplication - Show that for every choice of (s,t) and 'a' there exists a (s',t') such that [tex]a\vec{r}(s,t) = \vec{r}(s',t')[/tex]
Though you have already done all of the above, you should frame it as shown.
for proofs
Be careful with your grammar! You used "it" to mean two different things in this sentence. I think what you are saying is that v+ u also satisfies the equation x- y- 3z= 0 and so is in the set.
Since every vector in the set is of the form su+ tv for some numbers a and b, and the set is closed under scalar multiplication, yes, that is sufficient- except that you haven't yet proved the set is closed under scalar multiplication.
Again with the "it"! Use fewer pronouns and you will be clearer- you mean that ku and kv still satisfied the equation. And, you really needed to put this before the the proof of closure of addition.
You were given that this is a subset! You mean it was a subspace. Of course, you can't say that until after you said it was non-empty. Finally, you don't mean to say that (0, 0, 0) was "defined"- of course the 0 vector is defined the question is whether or not it is in the subset. And you should specifically point out that it is because 0- 0- 3(0)= 0.
FAQ: Proof of Subspace: x-y-3z=0 in R^3
What is a subspace?
A subspace is a subset of a vector space that has the same properties as the vector space itself. It is closed under addition and scalar multiplication, and contains the zero vector.
How do you determine if a set of vectors forms a subspace?
To determine if a set of vectors forms a subspace, it must satisfy the three conditions: closure under addition, closure under scalar multiplication, and contains the zero vector. This means that when you add two vectors together, the resulting vector must also be in the set, and when you multiply a vector by a scalar, the resulting vector must also be in the set.
How do you prove that a set of vectors forms a subspace?
To prove that a set of vectors forms a subspace, you must show that it satisfies the three conditions: closure under addition, closure under scalar multiplication, and contains the zero vector. This can be done by using algebraic manipulation to show that the resulting vectors from addition and scalar multiplication are also in the set.
What is the proof of subspace for the equation x-y-3z=0 in R^3?
The proof of subspace for this equation involves showing that it satisfies the three conditions for a subspace: closure under addition, closure under scalar multiplication, and contains the zero vector. This can be done by showing that when two vectors that satisfy this equation are added together, the resulting vector also satisfies the equation, and when a vector that satisfies the equation is multiplied by a scalar, the resulting vector also satisfies the equation.
How is the concept of subspace used in real-world applications?
The concept of subspace is used in various fields such as physics, engineering, and computer science. In physics, subspaces are used to model physical systems and analyze their behavior. In engineering, subspaces are used to solve complex problems by breaking them down into smaller, more manageable subproblems. In computer science, subspaces are used in linear algebra and machine learning algorithms.
