Proof of the preliminary test for infinite series
In summary, the conversation discusses the preliminary test for determining whether an infinite series converges or diverges. The test states that if the terms of the series do not approach zero as n approaches infinity, then the series diverges. The conversation also introduces a condition where the series satisfies the test, but further testing is needed. The condition is proven using a limit calculation and it is concluded that if the terms of the series do not approach zero, then the series must diverge. The discussion also mentions that the main task is to prove the validity of the test according to members of the PF community.
Seydlitz
263
Preliminary test: If the terms of an infinite series do not tend to zero, the series diverges. In other words if ##\lim_{ n \to \infty}a_n \neq 0## then the series diverges. But if the limit is 0 we have to test further.
Suppose a series a series satisfy this condition, ##lim_{ n \to \infty}S_n= S##, and consequently ##\lim_{ n \to \infty}S_{n-1}=S##
##S_n-S_{n-1}=a_n##
##\lim_{ n \to \infty}(S_n-S_{n-1})=\lim_{ n \to \infty}S_n - \lim_{ n \to \infty}S_{n-1} = \lim_{ n \to \infty}a_n##
##S-S=\lim_{ n \to \infty}a_n=0##
But if the terms of the series does not tend to 0, then this ##lim_{ n \to \infty}S_n=lim_{ n \to \infty}S_{n-1}=S## is not true, and the series cannot be convergent, or equivalently the series must diverge.
Did you have a question?
The only task is to prove the test, and I just want to know if it's valid according to the PF members.
Related to Proof of the preliminary test for infinite series
1. What is the purpose of a preliminary test for infinite series?
The purpose of a preliminary test for infinite series is to determine whether a given series converges or diverges before applying more complex convergence tests. It helps to save time and effort by quickly identifying series that do not converge.
2. What is the process of conducting a preliminary test for infinite series?
The process of conducting a preliminary test for infinite series involves finding a comparison series, which is a simpler series with known convergence properties. Then, we compare the given series to the comparison series and use the properties of the comparison series to determine the convergence or divergence of the given series.
3. What are some common comparison series used in preliminary tests for infinite series?
Some common comparison series used in preliminary tests for infinite series are the geometric series, p-series, and harmonic series. These series have well-known convergence properties and can be used to quickly determine the convergence or divergence of a given series.
4. Can a preliminary test for infinite series definitively determine the convergence or divergence of a series?
No, a preliminary test for infinite series can only determine whether a series converges or diverges. It cannot provide information about the limit of a convergent series or the divergence rate of a divergent series. Further tests may be needed to determine these properties.
5. Are there any limitations to using a preliminary test for infinite series?
Yes, there are some limitations to using a preliminary test for infinite series. These tests may not always provide a definite answer, and further tests may be needed to determine the convergence or divergence of a series. Additionally, these tests may not work for more complex series with alternating signs or terms that do not follow a clear pattern.
