MHB Proof that ax^2 + bx + c has No Rational Zeroes if a,b, and c are Odd
The discussion centers on proving that the quadratic equation ax^2 + bx + c has no rational zeroes when a, b, and c are all odd integers. It explores the implications of having one or two zeroes, leading to the conclusion that if the coefficients are odd, then the sum of the roots (b) must be even, creating a contradiction. The conversation also touches on the relationship between the discriminant (b^2 - 4ac) and the nature of the roots, emphasizing that if b^2 - 4ac is a perfect square, it must be odd, which is impossible under the given conditions. Ultimately, the argument suggests that the initial premise holds true, reinforcing the impossibility of rational zeroes in this scenario.
IHateFactorial
Well, let's look at how this works.
Quadratic equations can have either 1, 2, or no zeroes. If it has no real zeroes, the zeroes it DOES have are complex, so that's obviously not it.
Let's imagine $$ax^2 + bx + c = 0$$ has one zero, call it $$ \alpha$$ (Cuz it looks pretty).
Then that means $$ax^2 + bx + c = (x+\alpha)(x+\alpha) = x^2 + 2\alpha x + \alpha^2$$
Seeing that, we see that $$b = 2\alpha$$, which isn't odd an odd number.
The above example is imagining $$\alpha < 0$$; if $$\alpha > 0$$, it'd be the same thing: $$b = -2\alpha$$
Now, let's take it as if it had two zeroes: $$\alpha$$ and $$\beta$$.
$$ax^2 + bx + c = (x+\alpha)(x+\beta) = x^2 + x\beta + x\alpha + \alpha\beta = x^2 + x(\alpha+\beta) + \alpha\beta$$
So, let's imagine now that all coefficients are odd.
a = 1, because the coefficient of x squared is 1.
b = $$\alpha + \beta$$, so one of those most be even not both.
c = $$\alpha \beta$$, this leads to a contradiction with b, because if either alpha or beta is even, then b is even.
Is this right? If I show this to my teacher, will she accept it?
Mathematics news on Phys.org
This is untrue. For example, $x^2 - 2x + 1$ and $4x - 8x + 4$ both have the single root 1, but the coefficient of the $x^2$ term in the second polynomial isn't $a = 1$.
Furthermore, if $\alpha$ is our single root, all we know is that $(x - \alpha)^2$ is a factor (not $(x + \alpha)^2$).
The problem states that the roots under consideration are RATIONAL, so there is reason to suppose $\alpha$ is an integer, for example, the polynomial $4x^2 - 4x + 1$ has integer coefficients, but its only root is $\frac{1}{2}$.
It could be if $\alpha = \dfrac{2k+1}{2}$ for an integer $k$.
I seriously doubt it.
I think you're lost in useless territory here, what you want to show is that:
$ax^2 + bx + c$ has a rational root if and only if $b^2 - 4ac$ is a perfect square of a rational number. Since $a,b,c$ are all integers, this means $b^2 - 4ac$ is the square of an integer.
If $a,b,c$ are all ODD, then $b^2 - 4ac$ must likewise be an odd integer, and thus if it is a square, is the square of an odd integer.
See if you can prove $b^2-1 = (b+1)(b-1)$ is an odd multiple of $4$. Why is this a contradiction?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
