MHB Proof That $\lim\limits_{n\to\infty}\frac{1}{a^n}=0$ if $a>1$
  • Thread starter Thread starter Dustinsfl
    Proof
The discussion focuses on proving that the limit $\lim_{n\to\infty}\frac{1}{a^n}=0$ holds true when $a>1$. Participants suggest that to establish this limit, one must demonstrate the existence of an integer $N_0$ such that for all $n \geq N_0$, the inequality $\left| \frac{1}{a^n} - 0 \right| < \varepsilon$ is satisfied for any $\varepsilon > 0$. The approach involves manipulating inequalities and logarithmic properties to show that $a^n$ grows sufficiently large, leading to the conclusion that $\frac{1}{a^n}$ approaches zero. Additionally, the use of the Sandwich theorem is mentioned as a simpler method to reach the same conclusion. The overall consensus is that the limit is proven effectively under the condition that $a > 1$.
Dustinsfl
$\lim\limits_{n\to\infty}\frac{1}{a^n} = 0$ if $a > 1$.
Not sure how to handle this one. Do I want have $\frac{1}{\sqrt[n]{\epsilon}} < a$?
To prove this limit, we need to show that exists $N_0 \in \mathbb{N}$ such that for all $n \geq N_0$ we have that
$$\left| \frac{1}{a^n} - 0 \right| < \varepsilon,$$
for all $\varepsilon >0$.
Not sure what tools you have available, but if perhaps you could do
$$\frac{1}{a^n} < \varepsilon \leadsto a^n > \frac{1}{\varepsilon} \leadsto n \log_a a = n > \log_a \left( \frac{1}{\varepsilon} \right).$$
Therefore, take $N_0 = \left\lceil \log_a \left( \frac{1}{\varepsilon} \right) \right\rceil$.
Not entirely sure, but the whole process looks okay.
How do I now show $a > 1$?
Let $\epsilon > 0$ be given. Then $a^n < \frac{1}{\epsilon}$. Let's take the $\log_a$ of both sides.
Then
\begin{alignat}{1}
n\log_a a = n < \log_a\frac{1}{\epsilon}.
\end{alignat}
Let $N\in\mathbb{Z}$ such that $\log_a\frac{1}{\epsilon} < N$. For all $n > N$, we have that $\log_a\frac{1}{\epsilon} < N < n$.
\begin{alignat*}{3}
\log_a\frac{1}{\epsilon} & < & n\\
\frac{1}{\epsilon} & < & a^n\\
\left|\frac{1}{a^n} - 0\right| & < & \epsilon
\end{alignat*}
Since you said "if $a>1$", it seems like you're given this information. It is your hypothesis. It is because of this that we can take $\log_a r$. :D
if $a>1$, we can write $a=1+y$ where $y>0$. We have $a^n = (1+y)^n > 1+ny>ny$ by the binomial law. Then, $\displaystyle \frac{1}{(1+y)^n}<\frac{1}{ny}$.
Claim: $\displaystyle \frac{1}{ny}$ goes to zero. Fix $\epsilon>0$, for $\forall n > \displaystyle \frac{1}{y\epsilon}$, we have $\displaystyle -\epsilon<0< \frac{1}{yn}<\epsilon$.
We have $\displaystyle 0<\frac{1}{a^n}<\frac{1}{ny}$, so $1/a^n$ converges to $0$ by the Sandwich theorem.
Nice solution! It is by far more elementary than mine. :D Doesn't require the use of functions as the logarithm.
We all know the definition of n-dimensional topological manifold uses open sets and homeomorphisms onto the image as open set in ##\mathbb R^n##. It should be possible to reformulate the definition of n-dimensional topological manifold using closed sets on the manifold's topology and on ##\mathbb R^n## ? I'm positive for this. Perhaps the definition of smooth manifold would be problematic, though.
  • · Replies 48 ·
