Proof that v'(t) is orthogonal to v(t)
In summary, the problem is to prove that if a vector v(t) depends on time, then its derivative v'(t) is orthogonal to v(t). The hint suggests considering the derivative of v^2, which is equal to 2v d/dt. However, this only holds true for vectors with constant magnitude. The correct approach is to focus on the time derivative of v.v, which is equal to the dot product of v and v' and is equal to 0 when v has a constant magnitude. This proves that v and v' are orthogonal.
Nano-Passion
1,291
Prove that if v(t) is any vector that depends on time, then v'(t) is orthogonal to v(t).
Hint given: Consider the derivative of v^2.
V'^2 = d/dt (v * v)
= v d/dt + v d/dt
= d/dt (v+v)
= 2v d/dt
For ANY vector that's not true. E.g., the displacement, velocity and acceleration vectors of a body falling from rest are all parallel.
The statement is true for vectors whose magnitude is constant (but direction changes). Can you see the relevance of the hint given?
V'^2 = d/dt (v * v)
= v d/dt + v d/dt
= d/dt (v+v)
= 2v d/dt
Your notation is atrocious, frankly. What you wrote, [itex]{(v')}^2[/itex] represents the square of the derivative, not the derivative of the square.
There are many other errors in the rest of the working as well. It's hard to tell if they represent typos or errors in thinking. Please use LaTex.
What you're supposed to be focussing on is the time derivative of [itex]\overrightarrow{v}.\overrightarrow{v}[/itex], i.e. [itex]\frac{d}{dt}(\overrightarrow{v}.\overrightarrow{v})[/itex]. What happens when the velocity has a constant magnitude?
FAQ: Proof that v'(t) is orthogonal to v(t)
1)
What does it mean for v'(t) to be orthogonal to v(t)?
When two vectors are orthogonal, it means that they are perpendicular to each other. In this case, it means that the instantaneous velocity vector (v'(t)) and the position vector (v(t)) are perpendicular to each other at a given point in time.
2)
Why is it important to prove that v'(t) is orthogonal to v(t)?
Proving that v'(t) is orthogonal to v(t) is important because it helps us understand the relationship between velocity and position. It also plays a crucial role in many mathematical and physical concepts, such as calculating the rate of change of acceleration and determining the direction of motion.
3)
What is the mathematical formula for proving that v'(t) is orthogonal to v(t)?
The mathematical formula for proving that v'(t) is orthogonal to v(t) is the dot product, which is given by v'(t)·v(t)=0. This means that the dot product of the two vectors is equal to zero, indicating that they are perpendicular to each other.
4)
Can v'(t) and v(t) be orthogonal at all points in time?
No, v'(t) and v(t) cannot be orthogonal at all points in time. They can only be orthogonal at a specific point in time, when the dot product between the two vectors is equal to zero. At other points in time, they may have a non-zero dot product and therefore, will not be orthogonal.
5)
What are some real-world applications of proving that v'(t) is orthogonal to v(t)?
There are many real-world applications of proving that v'(t) is orthogonal to v(t), such as in physics, engineering, and computer graphics. For example, in physics, this concept is used to calculate the work done by a force on an object. In engineering, it is used to determine the direction of motion of a moving object. In computer graphics, it is used to create 3D animations and simulations.
