Proof that x=0 for Integers with Perfect Square Property
In summary, the Perfect Square Property is a mathematical property that states a number is a perfect square if it can be expressed as the product of two equal integers. To prove that x=0 for integers with this property, we use the definition of a perfect square and properties of integers to show that x must equal 0. This proof applies to all integers with the Perfect Square Property and has important implications in mathematics and real-life applications, such as in computer programming and engineering.
anemone
MHB
POTW Director
3,883
115
The integers $x$ and $y$ have the property that for every non-negative integer $n$, the number $2^nx+y$ is a perfect square.
Show that $x=0$.
Mathematics news on Phys.org
This is far from the simplest proof, as it relies on an open (but very likely true, proven conditionally under GRH, etc) conjecture, but I thought it was neat especially since it generalizes to many bases other than $2$. I think it's correct.
Definition: A pair of integers $(x, y)$ is a solution if and only if $2^n x + y$ is a perfect square for all nonnegative integers $n \geq 0$.
Proposition: There are infinitely many (odd) primes $p$ such that $2$ is a primitive root modulo $p$.
Note: This is Artin's conjecture on primitive roots for the case $g = 2$.
Theorem: If $(x, y)$ is a solution and $p > 3$ is an odd prime such that $2$ is a primitive root modulo $p$ then $x$ must be a multiple of $p$.
Proof: Note that there are exactly $1 + (p - 1)/2$ different quadratic residues modulo $p$ (including zero) however the primitive root $2$ generates $p - 1$ different residues modulo $p$, since it generates the group, that is, $\lvert \langle 2 \rangle_p \rvert = p - 1$. Now if $x$ is coprime to $p$ then $\lvert x \langle 2 \rangle_p \rvert = p - 1$ as the multiplication by $x$ modulo $p$ is invertible, and of course $\lvert x \langle 2 \rangle_p + y \rvert = p - 1$ since addition of $y$ modulo $p$ is also invertible for any integer $y$.
Hence if $x$ is coprime to $p$ then $2^n x + y$ assumes $p - 1$ distinct residues modulo $p$ over all $n \geq 0$ whereas perfect squares can only have $1 + (p - 1)/2$ distinct residues modulo $p$, and $1 + (p - 1)/2 < p - 1$ for all $p > 3$, so that $2^n x + y$ cannot be a perfect square for all $n \geq 0$. Thus if $(x, y)$ is a solution then $x$ must be a multiple of $p$. $\blacksquare$
Corollary: If $(x, y)$ is a solution then $x = 0$.
Proof: This follows immediately from the above theorem and proposition which imply that $x$ must be a multiple of infinitely many primes, and the only way this can hold is if $x$ is zero. $\blacksquare$
The argument generalizes for different (non-square) bases other than $2$ by assuming the validity of Artin's conjecture for different primitive roots and some minor modifications. I think you can also adapt it for the case of perfect cubes and such, but I haven't checked. Anyway this is some heavy machinery and I'm sure there's a more elementary proof for this particular challenge.
Thanks for your well-written solution, Bacterius!
And yes, your intuition is spot on and I would post it (if no one else solved it with elementary method) when this challenge has come close to its "expiration" date. :eek:
FAQ: Proof that x=0 for Integers with Perfect Square Property
What is the "Perfect Square Property" for integers?
The Perfect Square Property is a mathematical property that states that a number is a perfect square if it can be expressed as the product of two equal integers. For example, 9 is a perfect square because it can be written as 3 x 3.
How can we prove that x=0 for integers with Perfect Square Property?
The proof for this statement involves using the definition of a perfect square and the properties of integers. We can start by assuming that x is an integer with the Perfect Square Property. Then, we can express x as the product of two equal integers, say a and a. This means that x = a x a. Since we know that x is an integer, a must also be an integer. Therefore, x is the product of two integers, which means it is also an integer. However, the only integer that can be multiplied by itself to get 0 is 0. Hence, we can conclude that x must equal 0.
Can we prove that x=0 for all integers with Perfect Square Property?
Yes, we can prove that x=0 for all integers with Perfect Square Property. This is because the proof we used in the previous question is a general proof that applies to all integers with the Perfect Square Property. Since the definition of a perfect square applies to all integers, the proof also applies to all integers.
What implications does this proof have in mathematics?
This proof has important implications in mathematics because it provides a clear understanding of the Perfect Square Property and its relationship to the integer 0. It also helps to establish the concept of perfect squares as a fundamental mathematical concept that can be used in various calculations and proofs.
How can we use this proof in real-life applications?
This proof can be used in various real-life applications, such as in computer programming and engineering. In computer programming, the concept of perfect squares is often used in algorithms to efficiently calculate square roots. In engineering, the Perfect Square Property can be applied when designing structures or systems that require equal measurements or dimensions, such as in building bridges or circuits.
