Proof: Twin Primes Always Result in Perfect Squares
Math100
If ## 1 ## is added to a product of twin primes, prove that a perfect square is always obtained.
None.
Proof:
Suppose ## p ## and ## p+2 ## are twin primes.
Then we have ## p(p+2)+1=p^2+2p+1=(p+1)^2 ##.
Thus, ## (p+1)^2 ## is a perfect square.
Therefore, if ## 1 ## is added to a product of twin primes,
then a perfect square is always obtained.
Likes fresh_42 and fishturtle1
Looks good to me. Stylistically, one might write "Thus, ##p(p+2)+1## is a perfect square." instead of "Thus, ##(p+1)^2## is a perfect square.".
… although the restriction to twin primes is unnecessary. As should be clear from the proof, it holds for any two integers that differ by two.
Edit: There is also a rather intuitive geometric interpretation: Make a square out of (p+1)^2 unit boxes. Take the top row containing p+1 unit boxes and place p of them in a column on the right side of the rectangle, thus leaving you with a rectangle of side lengths p and p+2 with a single leftover unit box.
Edit 2: Illustration
Edit 3: Even easier to see with ##q = p+1##, i.e.,
(q-1)(q+1) = q^2 - 1 \quad \Leftrightarrow \quad q^2 = (q-1)(q+1) + 1.
Edit 4: The generalisation being cutting a strip of width b from the top of a square of side length a and placing a portion of length a-b of the strip to the right of the square, leaving a rectangle with sides a-b and a+b and a square of side length b:
a^2 = (a-b)(a+b) + b^2.
Regardless of ##a## and ##b## being integers or not.
Likes jim mcnamara, SammyS and PeroK
This is more than a stylistic point: if you say "Thus, ##(p+1)^2## is a perfect square" then you are saying "because ## p(p+2)+1=p^2+2p+1=(p+1)^2 ## then ##(p+1)^2## is a perfect square" which is not correct (note 1). The words "Then we have" are also not appropriate here because that is saying "because ## p ## and ## p+2 ## are twin primes then ## p(p+2)+1=p^2+2p+1##" which is not correct (note 2).
The proof simply needs to be:
## p(p+2)+1=p^2+2p+1=(p+1)^2 ##, which is a perfect square.
Note 1: ##(p+1)^2## is a perfect square independent of the fact that ## p(p+2)+1=p^2+2p+1=(p+1)^2 ##.
Note 2: ## p(p+2)+1=p^2+2p+1## independent of whether ## p ## and ## p+2 ## are twin primes.
Likes fishturtle1 and Mark44
