MHB Proof with Induction 3/2-5/6+7/12-9/20+11/30-....
  • Thread starter Thread starter Yankel
    Induction Proof
The discussion focuses on proving a mathematical expression by induction, specifically the sum represented by the series involving alternating signs and odd numerators. The participants identify the general form of the numerators as odd numbers (2n + 1) and derive the denominators as a quadratic expression (n^2 + n). They utilize Newton's divided difference formula to analyze the sequence of denominators and confirm their pattern. The challenge arises at the induction step for n=k+1, where the proof requires careful manipulation of terms to establish the equality. The conversation highlights the complexities involved in mathematical induction and the need for clarity in deriving general expressions.
Yankel
Hello all,
In the attached picture there is an equation. I need to fill the general expression on the left hand side, and to prove by induction that the sum is equal to the expression in the right hand side.
I am not sure how to find the general expression. Can you kindly assist ?
Thank you !
Mathematics news on Phys.org
$\dfrac{(-1)^{n+1}(2n+1)}{n^2+n}$
The numerators are clearly the odd numbers so: 2n+ 1.
The denominators are a little harder! I would have used "Newton's "divided difference" formula: adding a first term of "0", the "first differences" are 2- 0= 2, 6- 2= 4, 12- 6= 6, 20- 12= 8, 30- 20= 10; the "second differences" are 4- 2= 2, 6- 4= 2, 8- 6= 2, 10- 8= 2. Those are all "2" so all further "differences" are 0. The denominators are given by the quadratic 0+ 2n+ (2/2)n(n-1)= n^2+ n.
Of course, since the +/- sign alternates we need -1 to a power. The first term, with n= 1, is positive so that can be either (-1)^{n+1} or (-1)^{n-1}.
I saw sequence of denominators, $2 ,6,12,20,30,...$, as
$(1\cdot 2), (2 \cdot 3), (3 \cdot 4), ( 4 \cdot 5),(5 \cdot 6), ... , [n \cdot (n+1)] , ...$
I tried proving this by induction using the general statement that skeeter wrote, but I couldn't do it.
I am stuck at the n=k+1 stage...
note $1 + \dfrac{(-1)^{n+1}}{n+1} = \dfrac{(n+1) + (-1)^{n+1}}{n+1}$
${\color{red}{\dfrac{3}{2} - \dfrac{5}{6} + \dfrac{7}{12} - \dfrac{9}{20} + ... + \dfrac{(-1)^{n+1}(2n+1)}{n(n+1)}}} + \dfrac{(-1)^{(n+1)+1}[2(n+1)+1]}{(n+1)[(n+1)+1]}$
${\color{red}\dfrac{(n+1) + (-1)^{n+1}}{n+1}} + \dfrac{(-1)^{n+2}(2n+3)}{(n+1)(n+2)}$
$\dfrac{(n+1)(n+2) + (-1)^{n+1}(n+2)}{(n+1)(n+2)} + \dfrac{(-1)^{n+2}(2n+3)}{(n+1)(n+2)}$
$\dfrac{(n+1)(n+2) + (-1)^{n+1}(n+2) - (-1)^{n+1}(2n+3) }{(n+1)(n+2)}$
$\dfrac{(n+1)(n+2) + (-1)^{n+1}[(n+2) - (2n+3)] }{(n+1)(n+2)}$
$\dfrac{(n+1)(n+2) + (-1)^{n+2}(n+1) }{(n+1)(n+2)}$
$\dfrac{(n+1)(n+2)}{(n+1)(n+2)}+ \dfrac{(-1)^{n+2}(n+1)}{(n+1)(n+2)}$
$ 1 + \dfrac{(-1)^{(n+1)+1}}{(n+1)+1}$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 68 ·
12K
