Proofs of various integral properties
In summary, the speaker has been trying to prove two properties of integrals using the Riemann sum definition. They are 1. ##\int_{a}^{b}f(x)dx=-\int_{b}^{a}f(x)dx## and 2. ##\int_{a}^{a}f(x)dx=0##. They have provided attempts at proving these using the definition of the Riemann integral and are now wondering if these proofs are valid and if there is an alternative way to prove these properties using the alternative definition of the Riemann integral. The expert summarizer explains that these two properties cannot be proved and must be taken as definitions. They also suggest using
Frank Castle
580
23
I've been trying to prove a couple of properties of integrals using the Riemann sum definition: $$\int_{a}^{b}f(x)dx:=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\Delta x$$ where the interval ##[a,b]## has been partitioned (such that ##a=x_{1}<x_{2}<\cdots <x_{i-1}<x_{i}<\cdots <x_{n-1}<x_{n}##) into $n$ sub-intervals of equal width ##\Delta x=\frac{b-a}{n}##, where ##x^{\ast}_{i}\in [x_{i-1},x_{i}]## is an arbitrary point within the ##i^{th}## sub-interval ##[x_{i-1},x_{i}]##.
Given this, I'm trying to prove that
Here are my attempts:
1. Using the definition of the Riemann integral, we have that
$$\int_{a}^{b}f(x)dx:=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\Delta x=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\frac{b-a}{n}=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\frac{-(a-b)}{n}\\ =-\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\frac{a-b}{n}=-\int_{b}^{a}f(x)dx\qquad\qquad\qquad\quad$$
2. This follows from 1. for ##a=b##, we have $$\int_{a}^{a}f(x)dx=-\int_{a}^{a}f(x)dx\Rightarrow \int_{a}^{a}f(x)dx=0$$ or, from the definition of the Riemann integral $$\int_{a}^{b}f(x)dx:=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\Delta x=\lim_{n\rightarrow\infty}\sum_{i=1}^{n}f(x^{\ast}_{i})\frac{a-a}{n}=\lim_{n\rightarrow\infty}0=0$$
Are these valid proofs?
Furthermore, how can one prove these using the alternative definition of the Riemann integral: $$\int_{a}^{b}f(x)dx:=\lim_{n\rightarrow\infty}\lim_{\text{Max}\,\Delta x_{i}\rightarrow 0}\sum_{i=1}^{n}f(\zeta_{i})\Delta x_{i}$$ where ##\Delta x_{i}=x_{i}-x_{i-1}## is the width of the ##i^{th}## sub-interval and ##\zeta_{i}\in [x_{i},x_{i-1}]## is an arbitrary point within this interval, with ##\text{Max}\,\Delta x_{i}=\lbrace x_{2}-x_{1},\ldots , x_{i}-x_{i-1},\ldots , x_{n}-x_{n-1}\rbrace##?!
Finally, is there an easy way to prove the additivity property of integrals, i.e. $$\int_{a}^{c}f(x)dx=\int_{a}^{b}f(x)dx+\int_{b}^{c}f(x)dx\;?$$
These two properties cannot be proved, they must be taken as definitions. In your definition, and in all alternative definitions of the Riemann Integral, it is assumed that ##a<b## when we write ##\int_a^b f(x)dx##, so using this definition alone, the expression ##\int_b^a f(x)dx## is not defined for ##b<a##. In this case, we define ##\int_b^a f(x)dx=-\int_a^b f(x)dx##, and we also define ##\int_a^a f(x)dx =0##.
Edit: The additivity property should be quite easy to prove if you use your "alternative definition". Personally, I prefer the definitions based upon upper and lower sums.
This leaves me confused as in some notes I've read the authors all proceed to prove these properties (for example http://tutorial.math.lamar.edu/Classes/CalcI/ProofIntProp.aspx), whereas others confirm what you've said and simply give them as definitions (for example https://www.math.ucdavis.edu/~hunter/intro_analysis_pdf/ch11.pdf)? ?!
If ##\int_b^a f(x)dx## is not defined as ##-\int_a^b f(x)dx## when ##a>b##, then how is it defined? In your definition, you presuppose that ##a<b## since otherwise you cannot write the partition as ##a=x_0<x_1<\dots< x_n=b##, and the link you gave doesn't resolve this either. Of course one can generalize the definition to include "backwards" partitions ##a=x_0>x_1>...> x_n=b## and talk about subintervals ##[x_i,x_{i-1}]## instead of ##[x_{i-1},x_i]##, but then we must handle several cases in the definition. This complicates things unnecessarily, in my opinion. And then, how do we generalize this to double and triple integrals? It's just simpler to give the definition for the case ##a<b## only and define the integral from ##b## to ##a## in the case ##a<b## as ##-\int_a^b f(x)dx##.
The best way to define the Riemann integral, in my opinion, is to use upper and lower sums as here: https://en.wikipedia.org/wiki/Darboux_integral
What they call "Darboux integral" is the same thing as Riemann integral.
Is it fairly standard to take ##\int_{a}^{a}f(x)dx=0## and ##\int_{a}^{b}f(x)dx=-\int_{b}^{a}f(x)dx## as definitions then, and then prove all other properties of the definite integral, for example ##\int_{a}^{c}f(x)dx=\int_{a}^{b}f(x)dx+\int_{b}^{c}f(x)dx##, using these definitions as starting points?
I have to admit, I was never taught about definite integrals in terms of upper and lower sums, but I'd like to learn. Would you happen to know of any accessible introductions to definite integrals using this approach?
It's definitely standard. In fact, I never saw anything else before.
Well, you could look up the Robert A. Adams & Christopher Essex: Calculus, a complete course, Chapter 5. which I taught engireering students for many years.
A drawback is that it is not very general, since it assumes continuous functions. This is because otherwise we cannot ensure that the functions have a maximum and minimum on every closed interval. Adams don't want to get into the more complicated issue with supremum and infimum.
Walter Rudin's Principles of Mathematical Analyis, Chapter 6, fills this gap, but it is on the other hand a bit too general, since it introduces a more general type of integral, the Riemann-Stieltjes integral, but you can disregard that and think of the Riemann integral.
I recommend Bloch, which actually treats both definitions, i.e. the definition with lower/upper sums, and the definition in the OP. It also proves Lebesgue's theorem which gives us information about exactly which functions are integrable. https://www.amazon.com/dp/0387721762/?tag=pfamazon01-20
Note that while lower and upper sums are very intuitive and definitely serve a useful purpose, they don't exactly generalize well to more advanced settings.
Thanks for the recommendations, I'll take a look at them.
What would a better definition to use in more advanced settings?
Related to Proofs of various integral properties
What is a proof of an integral property?
A proof of an integral property is a mathematical demonstration that shows the validity of a specific property related to integrals. It involves using logical reasoning and mathematical principles to verify that a given statement or equation is true for all cases.
Why is it important to prove integral properties?
Proving integral properties is crucial because it ensures the accuracy and reliability of mathematical concepts and equations. It allows for a deeper understanding of integrals and their properties, and it provides a solid foundation for the development of new mathematical theories and applications.
What are some common techniques used in proofs of integral properties?
Some common techniques used in proofs of integral properties include the use of mathematical induction, the fundamental theorem of calculus, substitution, and integration by parts. These techniques involve manipulating equations and using logical reasoning to arrive at a solution.
How do integral proofs relate to real-world applications?
Integral proofs have a wide range of real-world applications, from physics and engineering to economics and statistics. They are used to solve real-world problems and make predictions about various phenomena, such as population growth, motion of objects, and economic trends.
What are some challenges that may arise when proving integral properties?
Some challenges that may arise when proving integral properties include complex equations, multiple variables, and the need for advanced mathematical techniques. Additionally, it is important to consider the assumptions and limitations of a proof and to ensure that the results are applicable to real-world scenarios.
  • Calculus
