Propagation of transverse pulse on a string
In summary, when a horizontal string at tension T is tapped at the midpoint to create a small transverse pulse, the pulse will split into two smaller pulses moving in opposite directions at the speed v=\sqrt{\frac{T}{\mu}}. This will happen regardless of where the pulse is created on the string, as the pulse is not initially influenced by the boundaries. When the pulses reach the ends, assuming no losses, they will be inverted and reflected, maintaining their shape and size and propagation speed. They will continue to bounce back and forth, meeting at the initial midpoint or at a distance from the other boundary depending on the number of reflections.
Terry Bing
48
A horizontal string at tension T is tapped at the midpoint to create a small transverse pulse. What happens to the pulse as time passes? If the pulse is instead created at a point other than the midpoint, what happens to it? Neglect damping.
Speed of transverse waves on a string stretched to a tension T is [itex]v=\sqrt{\frac{T}{\mu}}[/itex], where [itex]\mu[/itex] is the mass per unit length of the string.
In the first case (pulse at midpoint), by symmetry, the pulse splits into two smaller pulses moving in opposite directions at the speed [itex]v[/itex] mentioned above.
In the second case (pulse not at midpoint) the same thing should happen, because even though the pulse is closer to one of the boundaries, it is not aware of where the boundaries are till it reaches it. Any transverse mechanical disturbance cannot propagate faster than the speed [itex] v[/itex].So there is no way the pulse is initially influenced by where the boundaries are.
Is this line of reasoning correct?
Yes, but what happens when the pulses reach the ends?
Assuming there are no losses (Reflection coefficient is 1), they are inverted and reflected. Shape and size of the pulses remains the same, propagation speed remains the same (since it is a property of the medium). So the pulses just bounce about, inverting at each reflection. And whenever and whenever they meet, they superpose to give the initial larger pulse (only for an instant).
Is this correct?
Is this correct?
Where do they meet?
ehild said:
Where d they meet?
In the first case, they would meet at the midpoint again.
In the 2nd case, if say the pulse was initially at a distance d from one boundary, then after an even no. of reflections, they will meet at the same initial position of the pulse. After an odd no. of reflections, they will meet at a distance of d from the other boundary to give an inverted pulse there.
Correct!
Likes Terry Bing
ehild said:
Correct!
Thanks!
Related to Propagation of transverse pulse on a string
1. What is a transverse pulse on a string?
A transverse pulse on a string is a type of mechanical wave that moves perpendicular to the direction of the string. It is caused by a disturbance or vibration at one end of the string, which travels along the string to the other end.
2. How does a transverse pulse propagate on a string?
The propagation of a transverse pulse on a string can be explained by the principle of superposition. This means that when two or more waves interact, the resulting wave is the sum of the individual waves. As the pulse travels along the string, it causes the particles of the string to vibrate up and down, creating a wave-like motion.
3. What factors affect the speed of propagation for a transverse pulse on a string?
The speed of propagation for a transverse pulse on a string is affected by several factors, including the tension of the string, the mass per unit length of the string, and the properties of the medium through which the pulse is traveling. In general, a higher tension and lower mass per unit length will result in a faster propagation speed.
4. Can a transverse pulse on a string change direction?
Yes, a transverse pulse on a string can change direction when it encounters a boundary between two media with different properties. This is known as reflection and can occur when the pulse encounters a fixed end or a boundary with a different density or tension.
5. How is the amplitude of a transverse pulse affected by propagation?
As a transverse pulse propagates along a string, its amplitude will decrease due to energy losses. This is known as damping and can be caused by factors such as friction and air resistance. The rate of damping can also be affected by the tension and mass per unit length of the string.
