Proper Lorentz transformations from group theory?
The group structure of Lorentz transformations arises from the fundamental properties expected of spacetime and inertial frames, ensuring that transformations between different frames are invertible. Linear transformations are necessary to maintain consistency across reference points, as non-linear transformations would depend on a specific reference point. The requirement for linearity also ensures that uniform motion of particles is preserved across frames. Additionally, the derivation of these transformations is linked to the homogeneity and isotropy of spacetime. Overall, these principles are essential for establishing the framework of special relativity.
xxxyyy
The requirement that the set of Lorentz transformations forms a group comes from the basic properties that we expect of spacetime and inertial frames of reference.
The transformations must be linear, otherwise the transformation would depend on a particular reference point for ##(t, x, y, z) = (0,0,0,0)##.
There's a derivation from homogeneity and isotropy here:
http://www2.physics.umd.edu/~yakovenk/teaching/Lorentz.pdf
The group structure comes from the demand that transformations between different inertial reference frames should be invertible. The transformation from a frame to itself, i.e., doing in fact nothing, for sure is a symmetry and doing two transformations is also just a transformation from one inertial reference frame to another one.
The transformations should be linear because it should map any uniform motion of any point particle in one frame to such a motion in any other.
To get Minkowski space and the Poincare transformations you have to assume in addition also that any inertial observer describes his space as Euclidean.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
