Properties Of Estimators Question
In summary, we have found an unbiased estimator for theta, which is 18, and the third order statistic, y'3, which is also 18. We can determine if our estimate for theta is incorrect by comparing it with other estimators or the true value of theta. I hope this helps you understand the problem better. Let me know if you have any other questions or need further clarification.
dipset1011
suppose that 14, 10, 18, 21 constitute a random sample of size 4 drawn from a uniform pdf defined over the interval [0, theta], where theta is unknown. Find an unbiased estimator for theta and y'3, the third order statistic. What numerical value does the estimator have for these particular observations? Is it possible that we would know that an estimate for theta based on y'3 was incorrect, even if we have no idea what the true value of theta might be? explain.
I am not entirely sure how to go about solving this problem and help or a kick in the right direction would be great.
Is the third order statistic 18? isn't the estimator just the summation of all the observations divided by n, the number of samples or observations. Please, any help would be greatly appreciated.
Hello there! Thank you for posting this question in the forum. Let me help you with finding an unbiased estimator for theta and y'3, the third order statistic.
Firstly, let's define some terms and equations that will help us solve this problem.
- A random sample is a subset of a population that is selected in a way that each member of the population has an equal probability of being chosen.
- A uniform probability density function (pdf) is a type of probability distribution in which all outcomes are equally likely.
- The third order statistic, y'3, is the third smallest value in a set of observations.
Now, to find an unbiased estimator for theta, we can use the method of moments. This involves equating the theoretical moments of a distribution to the sample moments calculated from the data.
In this case, since we have a uniform distribution over the interval [0, theta], the theoretical mean and variance are given by:
μ = (theta + 0)/2 = theta/2
σ^2 = (theta^2 - 0^2)/12 = theta^2/12
The sample mean and variance can be calculated from the given data as:
x̄ = (14 + 10 + 18 + 21)/4 = 15.75
s^2 = [(14-15.75)^2 + (10-15.75)^2 + (18-15.75)^2 + (21-15.75)^2]/3 = 12.25
Now, equating the theoretical and sample moments, we get:
theta/2 = 15.75
theta^2/12 = 12.25
Solving these equations simultaneously, we get theta = 18.
Therefore, an unbiased estimator for theta is 18.
Moving on to finding the third order statistic, y'3, we can simply arrange the given data in ascending order: 10, 14, 18, 21. The third smallest value is 18, so y'3 = 18.
To answer your question about whether it is possible to know if an estimate for theta based on y'3 is incorrect, the answer is yes. This is because we can compare our estimate of theta with other unbiased estimators or with the true value of theta (if known). If our estimate is significantly different from these values, then we can conclude that our estimate
Related to Properties Of Estimators Question
1. What are the properties of a good estimator?
A good estimator should have the following properties:
  • Unbiasedness: The expected value of the estimator should be equal to the true value of the parameter being estimated.
  • Consistency: As the sample size increases, the value of the estimator should converge to the true value of the parameter.
  • Efficiency: The estimator should have the smallest possible variance among all unbiased estimators.
  • Sufficiency: The estimator should use all available information from the sample to estimate the parameter.
  • Robustness: The estimator should be able to produce reasonable estimates even when the underlying assumptions are not met.
2. How do we determine the bias of an estimator?
The bias of an estimator can be determined by taking the difference between the expected value of the estimator and the true value of the parameter being estimated. If this difference is equal to 0, the estimator is unbiased. If it is positive, the estimator is overestimating the parameter, and if it is negative, the estimator is underestimating the parameter.
3. What is the relationship between variance and efficiency of an estimator?
Variance and efficiency have an inverse relationship. This means that as the variance of an estimator decreases, its efficiency increases. A more efficient estimator will have a smaller variance, leading to more accurate and precise estimates of the parameter.
4. How do we determine the consistency of an estimator?
The consistency of an estimator can be determined by taking the limit of the estimator as the sample size approaches infinity. If this limit is equal to the true value of the parameter being estimated, the estimator is consistent. In other words, as the sample size increases, the value of the estimator should converge to the true value of the parameter.
5. What is the role of sufficiency in an estimator?
Sufficiency is an important property of an estimator as it ensures that the estimator uses all available information from the sample to estimate the parameter. This means that a sufficient estimator will produce the same estimate as any other estimator that uses the same amount of information from the sample. A sufficient estimator is also more efficient than an insufficient estimator, as it uses all available information to estimate the parameter.
