Properties of Matter in Vacuum (Space)
In summary: Liquids for a discussion of vapor pressure.In summary, the conversation discusses the properties of phase diagrams and how they relate to the presence of liquid and solid phases in a vacuum. It also brings up the question of how substances such as lava and comets can exist in a vacuum without evaporating. The concept of vapor pressure is mentioned as a possible explanation for this phenomenon.
sshai45
86
Hi.
This is something I've been wondering about. If one looks at a phase chart like this:
http://en.wikipedia.org/wiki/Phase_diagram#mediaviewer/File:Phase_diagram_of_water.svg
you notice something. First off, as the pressure is reduced, the liquid range shrinks and then disappears at the "triple point". So you cannot have any liquid water in a vacuum. However, wouldn't this also apply to any liquid as well? If so, then how do you get big flows of lava on vacuum-exposed bodies like Jupiter's moon Io, for example, or even our own Moon? Wouldn't lava ejected from a volcano, for example, boil rapidly due to the lack of pressure, thereby sucking its heat out and leaving what remains frozen, just like with water? And so then at the bottom of your volcano you don't get a nice lava flow but a bunch of "lava pellets" that froze while transiting the vacuum?
Second off, the other thing that one notices is that the gap between absolute zero and the solid-gas line seems to continue to shrink with a reduction in pressure. Linear-scale, or more like it, anyways, diagrams show this line even converging right on absolute zero at zero pressure! So does that mean that under zero pressure (total vacuum), no solid phase even is possible? Does this also apply with substances other than water? But then how does one reconcile that with the existence of solid bodies like comets (in large part water) and asteroids which have been in space for billions of years and haven't just evaporated away?
Astronomy news on Phys.org
It depends upon the "vapor pressure" of the liquid. Vibration free vacuum chambers - such as electron microscopes - often used oil diffusion pumps to reduce the vacuum. The oil used has a very high vapor pressure - and costs about $500 per ounce. Yes, it evaporates, but very slowly.
I would expect the same or similar cause for the presence of an apparent fluid flow on the moon.
See https://en.wikipedia.org/wiki/Vapor_pressure
FAQ: Properties of Matter in Vacuum (Space)
What is the difference between matter in a vacuum and matter in Earth's atmosphere?
Matter in a vacuum refers to any substance that exists in a space devoid of air or any other gas. This means that there is no air pressure or any other external forces acting on the matter. In contrast, matter in Earth's atmosphere is subject to air pressure, gravity, and other environmental factors.
How does matter behave in a vacuum?
In a vacuum, matter behaves differently compared to in Earth's atmosphere. Without any external forces, matter in a vacuum will expand and spread out. Additionally, without air molecules to collide with, matter in a vacuum will not experience friction or resistance, allowing it to travel at high speeds.
Can matter exist in a complete vacuum?
While a complete vacuum, with absolutely no matter or particles, is impossible to achieve in reality, matter can exist in a near-vacuum environment. This means that there is a very low concentration of particles, making it similar to a vacuum. In these conditions, matter can still exist and behave differently than in Earth's atmosphere.
How do scientists study matter in a vacuum?
To study matter in a vacuum, scientists use specialized equipment such as vacuum chambers and particle accelerators. These tools allow them to create and control a vacuum environment and observe the behavior of matter under these conditions. They also use various instruments to measure and analyze the properties of matter in a vacuum.
What are some real-world applications of understanding matter in a vacuum?
Understanding the properties of matter in a vacuum has various real-world applications. It is crucial in space exploration, as it helps scientists design and test equipment that can function in the extreme conditions of outer space. It is also essential in the development of technologies such as vacuum pumps, vacuum tubes, and vacuum insulation, which have a wide range of uses in industries such as electronics, aerospace, and healthcare.
