Properties of Tensor Products - Cooperstein, Theorem 10.3
In summary, tensor products are a mathematical concept used to combine two vector spaces into a larger one. They have properties such as linearity and associativity, and are related to the direct product. In Theorem 10.3 of Cooperstein's work, it is proven that the tensor product of linear transformations is also a linear transformation. In practical applications, tensor products are used in fields such as physics and engineering to analyze physical phenomena and in areas such as signal processing and image recognition.
Math Amateur
MHB
3,998
48
I am reading Bruce N. Coopersteins book: Advanced Linear Algebra (Second Edition) ... ...
I am focused on Section 10.2 Properties of Tensor Products ... ...
I need help with an aspect of the proof of Theorem 10.3 regarding a property of tensor products ... ... The relevant part of Theorem 10.3 reads as follows:View attachment 5451In the above text from Cooperstein (Second Edition, page 355) we read the following:" ... ... The map \(\displaystyle f\) is multilinear and therefore by the universality of \(\displaystyle Y\) there is a linear map \(\displaystyle T \ : \ Y \longrightarrow X\) such that\(\displaystyle T(v_1 \otimes \ ... \ v_s \otimes w_1 \otimes \ ... \ w_t )\)
\(\displaystyle = (v_1 \otimes \ ... \ v_s ) \otimes (w_1 \otimes \ ... \ w_t ) \)
My question is as follows:
What does Cooperstein mean by "the universality of \(\displaystyle Y\)" and how does the universality of \(\displaystyle Y\) justify the existence of the linear map \(\displaystyle T \ : \ Y \longrightarrow X\) ... and further, if \(\displaystyle T\) does exist, then how do we know it has the form shown ...
Hope someone can help ...
Peter
*** Note ***
Presumably, Cooperstein is referring to some "universal mapping property" or "universal mapping problem" such as he describes is his Section 10.1 Introduction to Tensor Products as follows:https://www.physicsforums.com/attachments/5452
... ... BUT ... ... there is no equivalent of the logic surrounding the mapping \(\displaystyle j\) ... unless we are supposed to assume the existence of \(\displaystyle j\) and its relation to the existence of \(\displaystyle T\) ... ?Indeed reading Cooperstein's definition of a tensor product ... it reads like the tensor product is the solution to the UMP ... but I am having some trouble fitting the definition and the UMP to the situation in Theorem 10.3 ...
Again, hope someone can help ...
Peter
Dear Peter,
Thank you for bringing up this question regarding Theorem 10.3 in Cooperstein's book. The universality of Y in this case refers to the universal mapping property of the tensor product, which states that for any multilinear map f: V1 x V2 x ... x Vs x W1 x W2 x ... x Wt --> X, there exists a unique linear map T: Y --> X such that f(v1, v2, ..., vs, w1, w2, ..., wt) = T(v1 ⊗ v2 ⊗ ... ⊗ vs ⊗ w1 ⊗ w2 ⊗ ... ⊗ wt). In other words, the tensor product Y is the "best" object that can be used to represent the multilinear map f.
The existence of the linear map T can be justified by the definition of the tensor product, which states that Y is the quotient space of the free vector space generated by the elements of V1 x V2 x ... x Vs x W1 x W2 x ... x Wt by the subspace generated by the elements of the form (v1 ⊗ v2 ⊗ ... ⊗ vs ⊗ w1 ⊗ w2 ⊗ ... ⊗ wt) - f(v1, v2, ..., vs, w1, w2, ..., wt). This quotient space is constructed in such a way that the elements in Y correspond to the multilinear maps from V1 x V2 x ... x Vs x W1 x W2 x ... x Wt to X. Therefore, the linear map T: Y --> X with the specified form exists by construction.
I hope this helps clarify the concept of universality and the existence of the linear map T in Theorem 10.3. Please let me know if you have any further questions.
FAQ: Properties of Tensor Products - Cooperstein, Theorem 10.3
What are tensor products in mathematics?
Tensor products are a mathematical concept used to describe the relationship between two vector spaces. It is a way to combine two vector spaces to create a new, larger vector space.
What are the properties of tensor products?
Some of the key properties of tensor products include linearity, associativity, and distributivity. The tensor product is also commutative, meaning that the order of the vector spaces does not affect the result.
How is the tensor product related to the direct product?
The tensor product is a generalization of the direct product, which is used to combine two sets. In the case of vector spaces, the direct product combines two vectors to create a new vector, while the tensor product combines two vector spaces to create a new, larger vector space.
What is Theorem 10.3 in Cooperstein's work on Properties of Tensor Products?
Theorem 10.3 in Cooperstein's work states that for any vector spaces V, W, and Z, and any linear transformations A:V → W and B:W → Z, there exists a unique linear transformation A ⊗ B: V ⊗ W → Z, where ⊗ represents the tensor product. This means that the tensor product of linear transformations is also a linear transformation.
How are tensor products used in practical applications?
Tensor products have many practical applications, particularly in fields such as physics and engineering. They are used to describe and analyze physical phenomena, such as electromagnetic fields, and are also essential in the study of quantum mechanics. In engineering, tensor products are used in areas such as signal processing and image recognition.
