Properties of Univariate statistics.
In summary, the conversation discusses univariate statistics, specifically the concepts of PMF and PDF, and how to estimate these quantities using a random sample of observations. It also touches on the idea of independent and identically distributed random variables and how they relate to the first four moments of a distribution (mean, variance, skewness, and kurtosis). Kurtosis is explained as a measure of how close a distribution is to a normal distribution, with a higher value indicating a more peaked distribution and a lower value indicating a flatter distribution.
zyQuzA0e5esy2y
Hi PF, i have several questions about univariate statistics that doesn't seem to be covered in my notes or online, i hope the question is not redundant on the forums, but i ran a search and saw nothing.
In univariate statistics, you can have a PMF which is a discrete random variable (RV) and a PDF which is a continuous RV.
"We can estimate these quantities given a random sample of observations on a random variable, specifically, a random sample of n independently sampled observations on the random variable X is a set of random variable, each of which has the same distribution as X. That is, letting Fx(x) denote the CDF of Xi."
we can say that random variables, are independent and identically distributed (IID), since each observation has the same distribution, E(X) and variance are the same thus COV(Xi,Xj) = 0"
What happens if it was a PMF or is it not possible?
A normal distribution of method of moments tell us:
1st mom = E(X)
2nd mom = Variance
3rd mom = skewness
4th mom = Kurtosis
Does the skewness tell us the direction which the curve is skewed and if the E(X) and variance is on the left side or right side of the curve?
What is kurtosis and what does it tell us?
in my notes i have that the kurtosis tells me that it is a function of the first 4 moments which tells me the E(X), variance, skewness and kurtosis, but doesn't exactly tell me about kurtosis. could i possibly get an explanation?
"What happens if it was a PMF or is it not possible?"
Same - if your sample is from a continuous distribution or discrete distribution (your only two distinctions) is immaterial: you can obtain the same information about moments, etc.
Roughly speaking (you can get more details by googling kurtosis)
Kurtosis gives one way to indicate how close the data's distribution is to a normal distribution
• Normal distributions have kurtosis equal to zero
• A distribution "flatter" than a normal has negative kurtosis
• A distribution more strongly peaked than a normal has positive kurtosis
Thank you very much, this actually helped. i tried googling kurtosis but didn't understand it as much.
FAQ: Properties of Univariate statistics.
What is the definition of univariate statistics?
Univariate statistics refers to the analysis of a single variable or a single set of data. This involves examining the distribution, central tendency, and variability of the data to understand its characteristics.
What are the main properties of univariate statistics?
The main properties of univariate statistics include measures of central tendency (such as mean, median, and mode), measures of variability (such as range and standard deviation), and measures of shape (such as skewness and kurtosis).
How are univariate statistics used in research?
Univariate statistics are commonly used in research to describe and summarize data, as well as to make inferences about a larger population. They can also be used to identify patterns and relationships within a dataset.
What are the benefits of using univariate statistics?
Using univariate statistics allows for a better understanding of a single variable or set of data, which can then inform further analysis and decision-making. It also provides a solid foundation for more advanced statistical techniques.
What are some common examples of univariate statistics?
Some common examples of univariate statistics include calculating the mean score on a test, determining the range of salaries in a company, and examining the distribution of heights in a population.
